*Removed import and define codes*
// Setup ========================================================================================================
void setup(void) {
//Setup serial cummunication
//Setting the Arduino I/O ports
//pinMode(BUTTON, INPUT);
pinMode(ECHOPIN, INPUT);
pinMode(TRIGPIN, OUTPUT);
pinMode(PIR, INPUT);
pinMode(RELAY, OUTPUT);
pinMode(RED, OUTPUT);
pinMode(GREEN, OUTPUT);
pinMode(BLUE, OUTPUT);
pinMode(LASER, OUTPUT);
pinMode(MIC, INPUT);
//Thermometer =================================================================
sensors.begin();
sensors.setResolution(insideThermometer, 12); // Set the resolution to 12 bit
//Clock =======================================================================
Wire.begin();
RTC.begin();
if (! RTC.isrunning())
Serial.println("RTC is NOT running!");
// following line sets the RTC to the date & time this sketch was compiled
RTC.adjust(DateTime(__DATE__, __TIME__));
// Main loop ====================================================================================================
void loop(void) {
// Microphone =============================================================
int clap = digitalRead(MIC);
//clap = 0; // For debugging purposes only
if(clap == 1)
digitalWrite(LASER, HIGH);
if(clap == 0)
digitalWrite(LASER, LOW);
Serial.print("Microphone: ");
Serial.println(clap);
// Temperature ===========================================================
sensors.requestTemperatures();
float tempC = sensors.getTempC(insideThermometer);
Serial.print("Temperatuur [C]: ");
Serial.println(tempC);
if(tempC > CMax)
CMax = tempC; // for use on LCD
Serial.print(" CMax : ");
Serial.println(CMax);
if(tempC < CMin)
CMin = tempC; // for use on LCD
Serial.print(" CMin : ");
Serial.println(CMin);
if(tempC >= 21.0) // glow red
digitalWrite(RED, HIGH);
digitalWrite(GREEN, LOW);
digitalWrite(BLUE, LOW);
if((tempC >= 15.0) && (tempC < 21.0)) // glow blue
digitalWrite(RED, LOW);
digitalWrite(GREEN, HIGH);
if(tempC < 15.0) // glow green
digitalWrite(BLUE, HIGH);
// Sonar =================================================================
// Start ranging
digitalWrite(LASER,LOW);
digitalWrite(TRIGPIN, LOW);
delayMicroseconds(2);
digitalWrite(TRIGPIN, HIGH);
delayMicroseconds(10);
// Compute distance
float distance = pulseIn(ECHOPIN, HIGH);
distance= distance/58;
if (distance > 2500)
distance = 0;
Serial.print("Afstand [cm]: ");
Serial.println(distance);
if(distance > 0.0 && distance < 10.00)
// Clock =================================================================
DateTime now = RTC.now();
unsigned long nu = now.unixtime();
// PIR ====================================================================
byte moved = digitalRead(PIR);
if (moved == 1)
Serial.println("Motion detected!");
relayAan = (now.unixtime());
relayUitLang = (now.unixtime() + 30 * 60); // relay on for 30 minutes
relayUitKort = (now.unixtime() + 1 * 60); // relay on for 1 minute
if((now.hour()) < 7) // before 7 o'clock
if(nu <= relayUitKort)
Serial.print("Time left relay on (<7h) [s]: ");
Serial.println(relayUitKort - nu);
digitalWrite(RELAY, HIGH); // turn RELAY ON
if(nu > relayUitKort)
Serial.println("Relay : OFF");
digitalWrite(RELAY, LOW); // turn RELAY OFF
if( ((now.hour()) >= 7) && ((now.hour()) < 22) ) // between 7 and 22 o'clock
if(nu <= relayUitLang)
Serial.print("Time left relay on (7-22u) [s]: ");
Serial.println(relayUitLang - nu);
if(nu > relayUitLang)
if( (now.hour()) >= 22) // after 22 o'clock
Serial.print("Time left relay on (>22h) [s]: ");
// LCD ====================================================================
u8g.firstPage();
do
draw(now, weekdays, regel, kolom, distance, tempC, CMin, CMax, moved);
while( u8g.nextPage() );
// rebuild the picture after some delay
//delay(100);
// Screensaver ================================================================
nSinceStart ++;
if(nSinceStart % 100 == 0)
regel ++;
kolom ++;
if(regel>4)
regel = 1;
if(kolom>2)
kolom = 0;
// Required Functions ===========================================================================================
// Write to LCD ===============================================================
void draw(DateTime now, String weekdays[], byte regel, byte kolom, float distance, float tempC, float CMin, float CMax, byte moved)
//DATUM ====================================
u8g.setFont(u8g_font_5x7);
u8g.setPrintPos(kolom, 10+regel);
u8g.print("=");
u8g.print(weekdays[now.dayOfWeek()]);
u8g.print(" ");
u8g.print(now.day(), DEC);
u8g.print(".");
u8g.print(now.month(), DEC);
u8g.print(".");
u8g.print(now.year(), DEC);
u8g.print(" ");
u8g.print(now.hour(), DEC);
u8g.print(":");
u8g.print(now.minute(), DEC);
u8g.print(":");
u8g.print(now.second(), DEC);
u8g.print("=");
//AFSTAND ===================================
u8g.setFont(u8g_font_7x14);
u8g.setPrintPos(kolom, 30+regel);
u8g.print("Afstand: ");
if(distance == 0)
u8g.print("- ");
u8g.print(distance);
if(moved==1)
u8g.print(" *");
//TEMPERATUUR ===============================
u8g.setPrintPos(kolom, 45+regel);
u8g.print("Temperatuur: ");
u8g.print(tempC);
u8g.setPrintPos(kolom, 57+regel);
u8g.print(" Min: ");
u8g.print(CMin);
u8g.print(" - Max: ");
u8g.print(CMax);
// Convert normal decimal numbers to binary coded decimal =====================
byte decToBcd(byte val)
return ( (val/10*16) + (val%10) );
// Convert binary coded decimal to normal decimal number ======================
byte bcdToDec(byte val)
return ( (val/16*10) + (val%16) );
