Use HCM5883L and MPU6050 on the same board
Hi everyone,
I have these two sensors boards and an Arduino Mega, what I need is to connect the two boards to Arduino and use one of them depending on a case (in the switch).
I tried both boards alone, and they work correctly.
HCM5883L
#include <Wire.h> //I2C Arduino Library
#define address 0x1E //0011110b, I2C 7bit address of HMC5883
int heading;
void setup(){
  //Initialize Serial and I2C communications
  Serial.println("TEST");
  Wire.begin();
  //Put the HMC5883 IC into the correct operating mode
  Wire.beginTransmission(address); //open communication with HMC5883
  Wire.write(0x02); //select mode register
  Wire.write(0x00); //continuous measurement mode
  Wire.endTransmission();
void loop(){
  int x,y,z; //triple axis data
  //Tell the HMC5883 where to begin reading data
  Wire.write(0x03); //select register 3, X MSB register
 //Read data from each axis, 2 registers per axis
  Wire.requestFrom(address, 6);
  if(6<=Wire.available()){
    x = Wire.read()<<8; //X msb
    x |= Wire.read(); //X lsb
    z = Wire.read()<<8; //Z msb
    z |= Wire.read(); //Z lsb
    y = Wire.read()<<8; //Y msb
    y |= Wire.read(); //Y lsb
  //Print out values of each axis
  Serial.print("x: ");
  Serial.print(x);
  Serial.print("  y: ");
  Serial.print(y);
  Serial.print("  z: ");
  Serial.println(z);
  heading=atan2(x, y)/0.0174532925;
  if(heading < 0) heading+=360;
  heading=360-heading; // N=0/360, E=90, S=180, W=270
  Serial.println(heading);
  delay(250);
MPU6050
#include <Wire.h>
    const int MPU=0x68;  // I2C address of the MPU-6050
    int16_t AcX,AcY,AcZ,Tmp,GyX,GyY,GyZ;
    void setup(){
      Wire.begin();
      Wire.beginTransmission(MPU);
      Wire.write(0x6B);  // PWR_MGMT_1 register
      Wire.write(0);     // set to zero (wakes up the MPU-6050)
      Wire.endTransmission(true);
      Wire.write(0x3B);  // starting with register 0x3B (ACCEL_XOUT_H)
      Wire.endTransmission(false);
      Wire.requestFrom(MPU,14,true);  // request a total of 14 registers
      AcX=Wire.read()<<8|Wire.read();  // 0x3B (ACCEL_XOUT_H) & 0x3C (ACCEL_XOUT_L)
      AcY=Wire.read()<<8|Wire.read();  // 0x3D (ACCEL_YOUT_H) & 0x3E (ACCEL_YOUT_L)
      AcZ=Wire.read()<<8|Wire.read();  // 0x3F (ACCEL_ZOUT_H) & 0x40 (ACCEL_ZOUT_L)
      Tmp=Wire.read()<<8|Wire.read();  // 0x41 (TEMP_OUT_H) & 0x42 (TEMP_OUT_L)
      GyX=Wire.read()<<8|Wire.read();  // 0x43 (GYRO_XOUT_H) & 0x44 (GYRO_XOUT_L)
      GyY=Wire.read()<<8|Wire.read();  // 0x45 (GYRO_YOUT_H) & 0x46 (GYRO_YOUT_L)
      GyZ=Wire.read()<<8|Wire.read();  // 0x47 (GYRO_ZOUT_H) & 0x48 (GYRO_ZOUT_L)
      Serial.print("AcX = "); Serial.print(AcX/16,384);
      Serial.print(" | AcY = "); Serial.print(AcY/16,384);
      Serial.print(" | AcZ = "); Serial.print(AcZ/16,384);
      Serial.print(" | Tmp = "); Serial.print(Tmp/340.00+36.53);  //equation for temperature in degrees C from datasheet
      Serial.print(" | GyX = "); Serial.print(GyX/131);
      Serial.print(" | GyY = "); Serial.print(GyY/131);
      Serial.print(" | GyZ = "); Serial.println(GyZ/131);
      delay(5000);
Until now, I have used the two boards with SDA and SCL pins, however on the Arduino board there is only one SDA and one SCL pin.
What should I do?
Connect both to the SDA and SCL pins. They have different I2C addresses.
