Due to some pin conflicts I need to alter the pins that the "official" motor shield from Arduino uses. It seems that the simplest way to do this would be to un-stack the shield from the Arduino and wire the pins header-to-header.
However when I did this I found the shield to be non-functional. (When stacked on the Arduino it was able to run the motors fine using a test sketch.) Besides the direction, brake, pwm, etc pins, are there other pins I need to connect from the Arduino to the shield (maybe a vref or vcc or ground?) in order to get it to work?
