I need help. I have a 5MP Omnivision OV5642 camera module which has no FIFO chip.I have Genuine Arduino Board and also a data logging shield with SD card. I want to capture or take photo with this camera module every second and save it to SD card. I want also to obtain the picture in different colours: Red, Green, Blue, and Infrared. I seem not to get example codes on OV5642 using I2C interface neither Arduino code for a camera without FIFo/Buffer chip**. I therefore need an Arduino program that will perform the tasks.** I will be grateful for your kind assistance.
@oluwaalaseyori, your topic has been moved to a more suitable location on the forum. Introductory Tutorials is not for questions. Feel free to write a tutorial once you have mastered your problem ![]()
Thank you very much. What is the suitable location for asking questions on the forum please?
Perhaps post a link to the camera you are wanting to use ?
I will try to get a link posted. Meanwhile I bought it from Aliexpress. It is a parallel interface SCCB interface with 20 header pins and without FIFO Buffer-ov5642.
The OV5642 camera module has a parallel interface, it can’t be connected to Arduino or Raspberry pi directly. So the user needs to use our Arduino Camera Shield to connect to Arduino boards
Is there a camera for Arduino that operates only through an I2C interface ?
Maybe this will help?
It looks like the OV5642 uses both I2C and SPI.
My thoughts too, but I also suspect there is confusion between the OV5642 camera itself and a module\PCB that has been produced which is an OV5642 + some other controller which provides the interface for Arduino.
Arducam do make those mini camera modules that are a camera plus a controller which have an I2C interface (to control the camera) and an SPI interface to download the data.
Whilst it might be possible to produce a controller for an OV5642 that would allow the camera to be controlled by and and download the picture data via I2C, would it not be a bit slow compared to SPI ?
I imagine it can, particularly on a Mega 2560 and using direct port access. It's only 8 bits. But that may be rather slow.
Where it is now ![]()
