Guys im making a school project on water pump which js using 5v dc and arduino nano.Also it will be connected to 16x2 display,Soil moisture sensor and dht 11 temp sensor
Can i work with transistors.If there are any tell me.Also I currently have a BC547 and BC 557.I researched a lot on transistors and found on a reply on arduino forum only.It says that the transistor is not enough.However he is using 12v.The link to that reply is here by wvmarle.
Ukhelibob also says that 350mA is not provided by Arduino and relay/transistor/MOSFET(I dont know whats this!).See this on this link.(I still havent got my answer)
I suggest that you verify that with the seller, specifically because they show it with a crappy 9V battery that will probably be depleted in a few seconds.
Well I have to agree with @sterretje the 0.1kW rating is questionable. Also it make no sense to sell it with a 9V battery if it is a 3-6V motor. You will have to measure the actual current when you get the pump
My estimate: approx. 1 W.
Maybe hp stands for hPa?
BCxxx is a transistor....
And thise small black ones are not gonna last long with that pump...
Very simple mosfet should do.
Come on Paul, that wasn't necessary. A 1st time poster, appears to be a young student? No need to be so negative. He'll learn just as we did, by making mistakes.
Hell, back in '76 I was so gullible I thought I bought my 1st new truck. It took me 2 months to realize I actually signed a 2 year lease contact. I'm still butt-sore about that 50 years later.
