Using a Honeywell Sensor with I2C
Hello,
I am new to I2C and am a bit confused with how to actually read data from a Sensor. I have wired a Honeywell Zephyr Sensor to my Arduino and want to read Flow, Temperature and Pressure Data.
here is the Datasheet of the Sensor: https://4donline.ihs.com/images/VipMasterIC/IC/HWSC/HWSC-S-A0014431449/HWSC-S-A0014431449-1.pdf?hkey=6D3A4C79FDBF58556ACFDE234799DDF0
I have the Wire.h library installed but now I dont know how to get data. I know how I2C works but am a bit lost with the Datasheet. How do I get the Sensor Adress? How do I read the Data? How do I convert the Data to Bar/°C/ (liter/min)
Thank you in advance!
Hello adristo
Welcome to the worldbest Arduino forum ever.
Take a search engine of your choice and ask the WWW for 'Honeywell Zephyr Sensor +arduino' to collect some data to be sorted out to get the needed information.
Hey there! I used the recommended library. Unfortunately, when blowing through it still gives 0 SLPM. I used the example code but changed the type to SLPM
What were the results of your I2C scan and what value are the I2C pull up resistors?
