Using a rotary encoder: simple tutorial
Hi all,
Thought I’d share this code, which might help de-mystify the inards of a rotary encoder. It’s not intended as a real-life solution- there are libraries for that and interrupts seems to be the way to go. It’s more of a tutorial so you can see how the 2 outputs vary as the encoder is rotated.
Attached is:
  • A snippet from the EC11 datasheet. It shows there are 2 detents (detent = click stop) per cycle but mine only has one.
  • My schematic
  • Sketch encoder_v3 which just uses 2x LEDs to indicate the pins’ status, and it also prints an A, a, B and b depending on that status. You have to turn very slowly between detents to see these.
  • Sketch encoder_v4 which counts the cycles, taking account of direction, and prints where you are.
Use it, don’t use it 8). As always, YMMV.
Jim
encoder_v3.ino (1.75 KB)
encoder_v4.ino (3.57 KB)
Mark2 of my encoder sketch is attached.
My encoder has a push-to-make switch in the knob, so I used that to double up and give 2 independent encoders. Seeing as the pins on the encoder are A and B, I re-used them as D and E; C is the middle pin.
If you run it with the serial monitor open, you’ll see it keeps track of where you are with the knob either pressed or not.
encoder_v5.ino (6.1 KB)
Added scope outputs from turning in either direction.
(I just bought a scope 8))
Edit… by the way, no Arduino involved there, just pulled each channel high with a 20k to 5V; see attached pic
Test circuit:
One click clockwise:
one click clockwise.bmp (219 KB)
One click anticlockwise:
one click anti clockwise.bmp (219 KB)
recently a german user posted this code that takes care of all the special situations a mechanical-switch-encoder produces if you change moving direction.
Standard-encoder code fails to count right if the direction-reversion occurs if the mechanical contacts are not exactly
“in the middle” of the contact-zone.
const byte ENCODER_A_PIN = 3;
const byte ENCODER_B_PIN = 2;
const byte SWITCH_PIN = 4;
  Serial.println("\nStart");
  pinMode(ENCODER_A_PIN, INPUT);
  pinMode(ENCODER_B_PIN, INPUT);
  pinMode(SWITCH_PIN, INPUT);
  int8_t state = 0;
  if (rotaryEncoder(state)) {
    Serial.println("- SWITCH -");
  if (state == -1) {
    Serial.println("<-- ");
  if (state == 1) {
    Serial.println(" -->");
bool rotaryEncoder(int8_t &delta) {
  delta = 0;
  enum {STATE_LOCKED, STATE_TURN_RIGHT_START, STATE_TURN_RIGHT_MIDDLE, STATE_TURN_RIGHT_END, STATE_TURN_LEFT_START, STATE_TURN_LEFT_MIDDLE, STATE_TURN_LEFT_END, STATE_UNDECIDED};
  static uint8_t encoderState = STATE_LOCKED;
  bool a = !digitalRead(ENCODER_A_PIN);
  bool b = !digitalRead(ENCODER_B_PIN);
  bool s = !digitalRead(SWITCH_PIN);
  static bool switchState = s;
  switch (encoderState) {
    case STATE_LOCKED:
      if (a && b) {
        encoderState = STATE_UNDECIDED;
      else if (!a && b) {
        encoderState = STATE_TURN_LEFT_START;
      else if (a && !b) {
        encoderState = STATE_TURN_RIGHT_START;
      else {
    case STATE_TURN_RIGHT_START:
      if (a && b) {
        encoderState = STATE_TURN_RIGHT_MIDDLE;
      else if (!a && b) {
        encoderState = STATE_TURN_RIGHT_END;
      else if (a && !b) {
      else {
    case STATE_TURN_RIGHT_MIDDLE:
    case STATE_TURN_RIGHT_END:
      if (a && b) {
      else if (!a && b) {
      else if (a && !b) {
      else {
        delta = -1;
    case STATE_TURN_LEFT_START:
      if (a && b) {
        encoderState = STATE_TURN_LEFT_MIDDLE;
      else if (!a && b) {
      else if (a && !b) {
        encoderState = STATE_TURN_LEFT_END;
      else {
    case STATE_TURN_LEFT_MIDDLE:
    case STATE_TURN_LEFT_END:
      if (a && b) {
      else if (!a && b) {
      else if (a && !b) {
      else {
        delta = 1;
    case STATE_UNDECIDED:
      if (a && b) {
      else if (!a && b) {
      else if (a && !b) {
      else {
  uint32_t current_time = millis();
  static uint32_t switch_time = 0;
  const uint32_t bounce_time = 30;
  bool back = false;
  if (current_time - switch_time >= bounce_time) {
    if (switchState != s) {
      switch_time = current_time;
      back = s;
      switchState = s;
  return back;
best regards Stefan
The german users code work really well for me on my ESP32.
I also found this blog post very useful.
Rotary Encoder : How to use the Keys KY-040 Encoder on the Arduino
Specifically the very last code example
// Robust Rotary encoder reading
// Copyright John Main - best-microcontroller-projects.com
#define CLK 2
#define DATA 7
  pinMode(CLK, INPUT);
  pinMode(CLK, INPUT_PULLUP);
  pinMode(DATA, INPUT);
  pinMode(DATA, INPUT_PULLUP);
  Serial.begin (115200);
  Serial.println("KY-040 Start:");
static uint8_t prevNextCode = 0;
static uint16_t store=0;
static int8_t c,val;
   if( val=read_rotary() ) {
      c +=val;
      Serial.print(c);Serial.print(" ");
      if ( prevNextCode==0x0b) {
         Serial.print("eleven ");
         Serial.println(store,HEX);
      if ( prevNextCode==0x07) {
         Serial.print("seven ");
// A vald CW or  CCW move returns 1, invalid returns 0.
int8_t read_rotary() {
  static int8_t rot_enc_table[] = {0,1,1,0,1,0,0,1,1,0,0,1,0,1,1,0};
  prevNextCode <<= 2;
  if (digitalRead(DATA)) prevNextCode |= 0x02;
  if (digitalRead(CLK)) prevNextCode |= 0x01;
  prevNextCode &= 0x0f;
   // If valid then store as 16 bit data.
   if  (rot_enc_table[prevNextCode] ) {
      store <<= 4;
      store |= prevNextCode;
      //if (store==0xd42b) return 1;
      //if (store==0xe817) return -1;
      if ((store&0xff)==0x2b) return -1;
      if ((store&0xff)==0x17) return 1;
   return 0;
