Using an attiny85 with SN754410: Voltage supply?
I'm building a circuit for a hobby project that runs a 12 volts DC motor (computer fan) in one direction for 30 s and then in the opposite for 30 s, on and on.
I've posted a picture of the circuit with the following components:
attiny85
SN754410
voltage regulator 5V
I'm planning on supplying the entire circuit with 9 volts (6*AA) and using a voltage regulator to lower the voltage supplied to the attiny85.
Is this the best way to do it?
I will be grateful for any help or suggestions!
Best regards
Kristian
A regular computer fan can only run in one direction, because of the electronics inside.
You have to add capacitors to your regulator.
See the datasheet of the regulator you are going to use (7805?).
Leo..
Thank you very much Wawa.
Thank you for the info on computer fans.
Do you know where to purchase dual-directions fans?
Best
Kristian
It would really be helpful if you draw an actual schematic by hand and take a photo of it with your cell phone and post the photo. A Fritzing is not a schematic. It is not completely useless but requires that the reader generate a wiring list consisting of pin numbers, names & functions and where it connects to. At the very least you should post a link to the SN754410 Datasheet and the ATtiny85 Datasheet.
In case you haven't realized it, almost all fans are manufactured for air flow in one direction only, consequently the blades are tilted specifically that direction. Anyone who has mistakenly installed their propellor backwards on an RC model aircraft can attest to the fact that the thrust is reduced when you use a propellor backwards due to the blade tilt factor. It would take you less time to add a second fan than it would to find a bidirectional fan blade.
SEE ATTACHED PHOTO (of chassis enclosure fan)
A regular prop will fly a plane if installed backwards but it won't be as efficient because the profile of the props blades is different from one side to the other.
Hi Raschemmel
Originally my plan was to use the H-bridge to control a regular DC-motor and then design a fan myself that would work both ways.
After more research I'm going for a two-fan solution.
Ok, thank you for feedback on my attached photo. It is based on the datasheets, but as you said not very informative standing alone. I won't post those from now on.
Thank you very much for your feedback!
Best
Kristian
From your post count it is obvious you are new to the forum. FYI, if you plan to post in the future you may want to invest a little time researching schematic symbols with Google and learn how to draw schematics so you can post photos of them. It will make everything go much faster.
http://www.expresspcb.com/expresssch/
This is a good schematic drawing program. It is free and easy to learn. You can easily design your own components.
Hi groundfungus and raschemmel.
Thank you both for your advices.
I have drawn a schematic, or at least tried, i hope it will be sufficient for you to give me further advice on the circuit.
It is different from before, as there is no h-bridge, but instead two fans that can be controlled by PWM.
The voltage regulator makes sure that the supply to the attiny85 is a steady 5 volts.
My question is now:
Is this the smartest way to do it, or should i avoid using a voltage regulator with the circuit?
I have attached a handdrawn schematic and datasheets for the voltage regulator.
The motors draw 0,1 amps each, and will not be running at the same time.
The middle pin on the motors are PWM inputs that control the fan speed.
I would very much appreciate any inputs and corrections on this,
and once again thank you for your help so far.
Best
Kristian
LM1117-R1.6.pdf (345 KB)
From the 1117 data sheet:
The output capacitor of 10uF or larger is needed for output stability of LM1117 as required by most of the other regulator circuits.
Do your fans have 3 wires or 4? I think that on the 3 wire fans, the third wire is a tach signal output (not a PWM input). A 4 wire fan will have the PWM input as well as the tach output.
I'm sorry, but why do you quote the datasheet? Haven't I already put that in the circuit?
Regarding the fans, they have 3, and you're right, they do not "support" PWM. However this won't be much of a problem as i will only need to spin them at either full speed. So I've changed the circuit to involve two transistors that can turn the motors on and off.
Thank you!
Best
Krisitan
Yes you did. My turn to say "sorry".
Can you post the "changed" circuit ?
No worries, it seems i used the wrong symbol for a polarized capacitor (and surely other components as well).
Rasschemmel: Yes, I've attached a drawing of the "new" circuit.
I realize that this will in fact make it possible to control the motorspeed via. PWM, and I have succesfully done so on an Arduino. Hopefully this will work with an attiny85 as well.
Best
Kristian
FYI , TO92 is the packAage type not the part #
You're right.
But if you have time, i would still very much like to have an opinion on this:
Is the solution with the voltage regulator the best way to go or is there a better way? (in terms of energy consumption, price, ect.)
That remains to be seen but FYI, your schematic is missing the GND for the 12V battery. That doesn't prevent US from understanding it but I thought you should know that technically that is considered an "error" because the battery has two terminals, only one of which is shown.
Running ANY 5V regulator off a 12V input voltage is not a good idea because you force it to dissipate the difference between what you are supplying and what it needs as an input: (12V -6.5V =5.5V) . The ideal input voltage for a 5V regulator with such a small load is 6.5 to 7V dc. The regulator will run a little hot due to the power it needs to dissipate (the 5.5V it needs to remove). Is there no way you can have a 6V battery pack for the 5V regulator and a 12V pack for the fans so the load supply is separate from the logic supply ? (preferred method)
Are you sure about that ? My understanding is that it is a Tachometer output of the fan that can be used to monitor the fan speed, and not an input
Just use a cheap TO-92 78L05 regulator.
Don't worry about power consumption of the regulator and the micro.
It will be a fraction of the power consumption of the fans.
Fans like that can draw up to ~400mA.
Make sure your transistors are rated for that. A BC337 should be ok.
You will need a lower value base resistor for that fan current.
I would use 470ohm, and even as low as 220ohm if the transistors are getting hot.
Leo..
For low current applications, yeah, a linear regulator (like the 1117) is very appropriate.
When using a linear regulator, it draws the same current from the power source as the output does, plus the quiescent current used by the regulator itself (see datasheet for details - this is usually quite small). What this means is that, say you draw 10mA at 5v (50 mW), it draws 10mA at 12v (120mW) and dissipates the 70mW as heat. For obvious reasons, linear regulators become impractical at higher current.
At higher current, DC-DC converters are available (ex, on ebay); these have higher overall efficiencies, and are available in configurations that can output a higher voltage than the input, but they're also larger, more expensive (particularly if you get the miniaturized, encapsulated ones - cheap ones on a circuit board from china start at the $1.x range on ebay), and have higher quiescent current.
That should work. One could argue for a 10uf cap on the input side of the regulator too, but you can probably get away without it.
Thank you all for your feedback.
DrAzzy:
My attiny draws 0,3 milliamps, and the motors draw 80 milliamps. As I understand what you're saying:
The regulator will draw 120,3 mW and supply 50,3 mW on the output pin resulting in 7*0,3 or 2,1 mW of energy dissipated as heat.
That doesn't seem like much?
I was worried that the dissipated energy would also involve the current drawn from the motors.
Rascemmel:
Thank you for your feedback on the schematics drawing. You correctly pointed out, just like groundfungus, that the pin is not for PWM input, but for TACH.
You are still missing the battery GND
