Using an HC-12
I'm currently making a quadcopter out of an arduino using 2 HC-12 for communication. I've followed the topic of tomheylen on Instructables.
Following his instruction, I have been able to parameter the whole thing with the AT command ( using channel 002, 2400 bauds, FU3 ).
I however failed to make it transmit any data. here is the test code I used (with a few lines adapted from tomheylen :
The sending module :
#include <SoftwareSerial.h>
SoftwareSerial mySerial(2, 3); //TX, RX
int buttonPin = 8;
boolean onOff = 0;
  pinMode(buttonPin, INPUT);
  mySerial.begin(2400);
  int buttonState = digitalRead(buttonPin);//read button state
  if(buttonState == 1){//if button is down
    mySerial.println(1111);//send unique code to the receiver to turn on. In this case 1111
    onOff = 1;//set boolean to 1
  if(buttonState == 0 && onOff == 1){//Verifier to send off signal once
    mySerial.println(0000);//send unique code to the receiver to turn off. In this case 0000
  delay(20);//delay little for better serial communication
The recieving Module :
//HC-12 Momentary Button Receive
//Autor Tom Heylen tomtomheylen.com
SoftwareSerial mySerial(11, 4); // TX, RX
int ledPin = 13;
  pinMode(ledPin, OUTPUT);
  if(mySerial.available() > 1){
    int input = mySerial.parseInt();//read serial input and convert to integer (-32,768 to 32,767)
    if(input == 1111){//if on code is received
      digitalWrite(ledPin, HIGH);//turn LED on
    if(input == 0000){//if off code is received
      digitalWrite(ledPin, LOW);//turn LED off
  mySerial.flush();//clear the serial buffer for unwanted inputs
One of my arduino is a UNO and the other one a 101
Both have made their job configuring the HC-12 so I think the compatibility is good.
Do you have an Idea what can cause this trouble ?
Thx in advance
Perhaps you'll get answers if you edit your post and fix the subject. Nobody knows what's an "UC-12".
DrDiettrich:
Oups Yeah my bad... I changed the component, it was dead for some unknown reason
I'd try the connection with two identical boards, and with direct wiring. If that works, add the transceivers and try again.
Doesn't the 101 have more than one hardware Serial?
