got my Arduino..plugged it in..installed drivers.. ran blink sketch to chip through Arduino IDE.. worked fine..
tried to add it to wire it to the bread board..
opened IDE.. chose 328 as bootloader/chip..
chose COM4 (still)
chose ArduinoISP
this is the error I am getting:
avrdude: stk500_program_enable(): protocol error, expect=0x14, resp=0x50
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
I know I can always pop chips out of the arduino and into the breadboard..but am looking for another way
It's either that, or still while the chip is out of the arduino, you can just hook up the TX/RX pins on the standalone one with the arduino.
Then just program as normal, after pressing reset on the standalone (to reset and activate the bootloader). (You could try connecting the RESET pins too, but I have never tried it, cant see why I should not work).
Thanks.. yeah I read about leaving the chip out of the real Arduino board..and using the RX/TX to send sketch to chip..
not my first choice..LOL..
I also wasnt clear if that would 'erase/replace' the bootloader (I have read about that several times..usually with parallel programmer though..and lock bits not set perhaps?)
With the FTDI 'cables' I have on order.. (since I have never used them before).. do I just cut the phone side end off..
stick the other USB end into the PC.. and the wires straight to the chip on the breadboard?
Am I correct on this process for how the FTDI cables works?
I 'do' have some MAX232 chips laying around as well I have read people use them in DIY programmers..but not clear if it was to flash bootloader?? or to upload sketches? and if it wrote over the bootloader code or not?
