Using Arduino IDE with ATMEGA 32
Hello experts,
I've been playing for a while with the Arduino IDE which seems to have a nice amount of well made libraries and a quite simplified way to deal with programming.
I want to use this software to flash my programs on an ATMEGA 32 chip.
Up to now, I can upload simple programs, such as LED flashing.
I had to modify the IDE to have it work with my chip.
This is how I made it: http://www.instructables.com/id/Using-Atmega32-with-Arduino-IDE/
So I've imported the Mega32 file in my Variant folder(made the recommended modifications) and I've added this text to my Board.txt file:
mega32-8.name=ATmega32-8mhz
mega32-8.build.mcu=atmega32
mega32-8.build.f_cpu=8000000L
mega32-8.build.core=arduino:arduino
mega32-8.build.variant=mega32
mega32-8.upload.maximum_size=32000
mega32-8.upload.tool=avrdude
mega32-8.upload.speed=115200
mega32-8.bootloader.low_fuses=0xE4
mega32-8.bootloader.high_fuses=0xD9
mega32-8.bootloader.extended_fuses=0xFD
Like said, it works for simple stuff, but when I try using the wire.h library to work with the Adafruit biColor8x8 Matrix, it fails.
This is the project I wanted to run as a standalone(read:without an Arduino board):
The sketch compiles perfectly, but when I upload, using an ISP Programmer, I get this error:
avrdude: verification error, first mismatch at byte 0x1100
** 0xff != 0x59**
avrdude: verification error; content mismatch
This is my last try before actually buying the smallest Arduino Board and leaving it in my projects(which in my opinion would be a waste).
Thanks in advance!
BTW: I'm a mechanical engineer, so I've got pretty limited knowledge of deep and advanced C programming.
Uh, have you seen the prices for Arduino Pro Mini clones? It's very hard to be bothered by wasting one of those...
Wire library would probably need to be modified to work with the '32. I think it's got the same I2C interface in it as the 328, so it's probably just #defines.
But the write error is concerning - I don't know how to address that.
