Hey gang-
Circling back on a project, that is using a computer PSU as my power source... and have some questions/looking for guidance. ![]()
My project is using stepper motor, servo, relays, solenoid vales.. (will eventually also power a RPi and a touch screen).
I figured a computer PSU would be great solution as it have +12v, +5v (and +3.3v) outputs, which covers all my components needs/requirements as far as voltage.
I'm not sure what happened. but things were mostly working fine during testing stages..etc... but the servo started to 'randomly' work.. and then now, not at all. (I can hear it trying.. and when I actually use my hands to move it where it is 'trying to'.. it moves.. and then moves back (with my aided help).. but alone it only make a 'noise' now when attempting to move.
My 'arduino' is a RoboRed (which has a different voltage regulator, and was advertised as supposed to be able to power a servo directly off the I/O pins broken (I/O, +V, GND rows)..
I have tried to use those pins to power the servo (which originally worked during initial project stages).. and also the PSU +5v/GND pins... and for some reason it will no longer 'move' on it own.
I took the servo out of the project, to see if it was servo related issues.... grabbed a different Arduino, and used my benchtop PSU set @ +5v.. the simple servo test worked and things moved.
I threw it back into my project, and the same as above. (a noise/hum) each move attempt.
I checked the wires going to the servo, and it was a +5v (actually I think it was +5.2 or something.. which should not matter for the servo since +4.8-+6.8v is the range). Its a 25g high torque servo.. when the benchtop PSU was used.. I saw it was maxing at roughly 400mA or so.. so should be a problem for the computer PSU to power.
Q: Is my PSU going bad or something?
Q: I read online some people mentioning all GND wires in the PSU should be connected together? (other places to do not mention this?)
Working on this project all day, only to have the servo stuff crap out on me after assembly..etc. I'm all burnt out now hehe, not sure what direction to go here? or what things to trouble shoot?
Clarification:
The steppers, solenoids..etc.. all work fine. (seems to be just the servo?)
Thanks!
