Using different pins for UART under same Sercom alternatively(SAMD21 Mini)
Hi
After the delivery of the SAMD21 mini breakout from Sparkfun,now i am able to configure different Serial ports under different sercoms.
Now,my criteria is to use different pins under same sercom alternatively.For say,the Serial1 is using Sercom0 pins(pin D0 Rx,D1 Tx).Now,i want to use D8 & D9 to communicate with another UART device(I have total 8 diffrent UART devices to read data from/send data to).But D8/D9 is also under same Sercom i.e Sercom0.
Is it possible to configure D8/D9 alternatively(Disabling D0/D1)??
My test code for using different UART ports is as follows:
#include "wiring_private.h"
Uart Serial2 (&sercom2, 3, 2, SERCOM_RX_PAD_1, UART_TX_PAD_2);
Uart Serial3 (&sercom5, 7, 6, SERCOM_RX_PAD_3, UART_TX_PAD_2);
void SERCOM2_Handler()
  Serial2.IrqHandler();
void SERCOM5_Handler()
  Serial3.IrqHandler();
  SerialUSB.begin(9600);
  Serial1.begin(9600);
  Serial2.begin(9600);
  Serial3.begin(9600);
  //Serial2
  pinPeripheral(3, PIO_SERCOM_ALT);
  pinPeripheral(2, PIO_SERCOM);
  //Serial3
  pinPeripheral(6, PIO_SERCOM);
  pinPeripheral(7, PIO_SERCOM);
  Serial1.println("Serial1 Test Success");
  Serial2.println("Serial2 Test Success");
  Serial3.println("Serial3 Test Success");
Now,my criteria is to use different pins under same sercom alternatively. For say,the Serial1 is using Sercom0 pins(pin D0 Rx,D1 Tx).Now,i want to use D8 & D9 to communicate with another UART device
I think so, at least partly. I expect that the interrupt vectors permanently bind "serial 1" to SERCOM0, but if you change the pin configurations "underneath", so that you're now using D8/9 instead of D0/1. Of couse, that would mean that any data that shows up on D0 during that time would be lost. If you only need to talk to the (some of the) serial devices one-at-a-time, it might be easier to just implement some form of SoftwareSerial so that you can use whatever pins you want, and not worry about the SERCOMs...
You should understand that what you're doing is very far beyond normal Arduino use, and pretty far beyond SAMD21 use in general. You'll need to do your own experimenting (and debugging) to see if it works.
