Hello fellow community!
I'm working on a new project for the light of my father in laws sauna. The LEDs should be controlled by the measured value of a temperature sensor. The only Problem is, that I only have three cables available for the connection between Arduino and Sensor/LEDs.
Therefore I'm trying to set the communication for both devices on one pin. But unfortunately when I do this, only the first LED lights up white and I get the temperature sensors measurement.
Here my code, currently without any temperature control:
// Include the libraries we need
#include <OneWire.h>
#include <DallasTemperature.h>
#include <FastLED.h>
#define DATA_PIN 5
#define NUM_LEDS 60
#define BRIGHTNESS 32
#define LED_TYPE WS2811
#define COLOR_ORDER GRB
CRGB leds[NUM_LEDS];
#define UPDATES_PER_SECOND 100
// Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
OneWire oneWire(DATA_PIN);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
// arrays to hold device address
DeviceAddress insideThermometer;
float tempC;
// function to print the temperature for a device
void printTemperature(DeviceAddress deviceAddress)
tempC = sensors.getTempC(deviceAddress);
Serial.print("Temp C: ");
Serial.println(tempC); // Converts tempC to Fahrenheit
delay( 3000 ); // power-up safety delay
// LED setup
FastLED.addLeds<LED_TYPE, DATA_PIN, COLOR_ORDER>(leds, NUM_LEDS).setCorrection( TypicalLEDStrip );
FastLED.setBrightness( BRIGHTNESS );
// Temperature setup
// start serial port
Serial.println("Dallas Temperature IC Control Library Demo");
// locate devices on the bus
Serial.print("Locating devices...");
sensors.begin();
Serial.print("Found ");
Serial.print(sensors.getDeviceCount(), DEC);
Serial.println(" devices.");
if (!sensors.getAddress(insideThermometer, 0)) Serial.println("Unable to find address for Device 0");
// set the resolution to 9 bit (Each Dallas/Maxim device is capable of several different resolutions)
sensors.setResolution(insideThermometer, 9);
Serial.print("Device 0 Resolution: ");
Serial.print(sensors.getResolution(insideThermometer), DEC);
void fadeall() { for(int i = 0; i < NUM_LEDS; i++) { leds[i].nscale8(250); } }
Serial.print("Requesting temperatures...");
sensors.requestTemperatures(); // Send the command to get temperatures
Serial.println("DONE");
printTemperature(insideThermometer);
static uint8_t hue = 0;
Serial.print("x");
// First slide the led in one direction
// Set the i'th led to red
leds[i] = CHSV(hue++, 255, 255);
// Show the leds
FastLED.show();
// now that we've shown the leds, reset the i'th led to black
// leds[i] = CRGB::Black;
fadeall();
// Wait a little bit before we loop around and do it again
delay(10);
Serial.print("x");
// Now go in the other direction.
for(int i = (NUM_LEDS)-1; i >= 0; i--) {
// Show the leds
FastLED.show();
fadeall();
delay(10);
I hope you can help me surpass this problem.
Thanks!
