Using If statements to control a case switch
I want to have a sonic sensor report a value, and if that value is smaller than a certain number, I want the code to switch to a certain case.
Code:
#include <PRIZM.h> // Includes the PRIZM Library
 PRIZM prizm;
int batteryVoltage;
int leftDistance;
int centerDistance;
int rightDistance;
int frontDistance;
int lineSensor;
int driveDirection;
int difference = 0;
// int difference = leftDistance - rightDistance;
u8 sensorValue[4];
float distanceForward = 30.48;         // target distance forward (cm)
float wheelRadius = 4.091;             // radius of drive wheels (cm)
int encoderStepsPerRevolution = 3955;  // number of steps per revolution (3955 for ARC motors, 1440 for Tetrix Torqnado motors) ***Tune this number for your robot.***
int speed = 150;
  prizm.PrizmBegin();
  prizm.setMotorInvert(1, 0);
  prizm.setMotorInvert(2, 1);
  sensorReadings();
  if(frontDistance <= 18)
  switch(driveDirection) {
    case 1:
      if(leftDistance >= 5.5) {
        move_left();
        move_right();
  if(rightDistance >= 4.5) {
    move_left();
    move_right();
  if(difference <= 0) {
    move_forwards();
  if(centerDistance <= 18) {
    move_backwards();
  prizm.resetEncoders();
void sensorReadings(){
  batteryVoltage = prizm.readBatteryVoltage();
  leftDistance = prizm.readSonicSensorIN(2);
  centerDistance = prizm.readSonicSensorIN(3);
  rightDistance = prizm.readSonicSensorIN(4);
  // lineSensor = prizm.readLineSensor(5);
  frontDistance = prizm.readSonicSensorIN(5);
void move_right(){
  prizm.setMotorPowers(20, 25);
  delay(90);
void move_forwards(){
  prizm.setMotorPowers(30, 30);
  delay(10);
void move_left(){
  prizm.setMotorPowers(25, 20);
  delay(90);
Hello. @roboticsisfun - Does your code work? Do you have a question?
Welcome to the forum
It is not clear what you want to do.
You have a switch/case in your sketch but only one case. The switch uses the value of driveDirection but that value never changes
You could do something like this
sensorReading = readSensor();
if (sensorReading > 0 && sensorReading <=100)
  driveDirection = 1;
else if (sensorReading > 10 && sensorReading <=200)
  driveDirection = 2
switch case (driveDirection)
  case 1:
  //code here for direction 1
  case 2:
  //code here for direction 2
Is that the sort of thing you had in mind ?
You have defined this variable as int
and.....
Have tested with float value.
look this over
String test;
enum { ST_A, ST_B, ST_C };
int state = ST_A;
void stMach (
    char stim )
    switch (state)  {
    case ST_A:
        if ('c' == stim)  {
            state = ST_C;
            Serial.println (" ST_C");
    case ST_B:
        if ('a' == stim)  {
            state = ST_A;
            Serial.println (" ST_A");
    case ST_C:
        if ('b' == stim)  {
            state = ST_B;
            Serial.println (" ST_B");
void loop ()
    if(Serial.available() > 0){
        char c = Serial.read ();
        stMach (c);
