1 x Infrared receiver module
But when i enter this words in found on this site search mashine, it give me nothing, in spite of i make it combination by few different order.
Is't possible load here the link to this details description or just their property list or code sample for distance measuring.
I can.t find it by keywordS_ above this post and willbe very appreciate to somebody, who can show me link or some directions.
It's keyes IR_01- for distance and another is for IR remote control.
But don't find docks for it and code samples ...
ADDED LATER: the properly keyword for this board is : Reflective Infrared Sensor
it search all needed info here, so answer is closed.
It was included into robots set on my avatar. THis sensor's trademark is "Keyes IR_01"
It.s looks almost like this,
Just my board has 1 pot and 3 pins.
What you have is a retro reflective sensor where one is a LED and the other is a phototransistor. It works by emitting IR and sensing the reflection. It is only able to give on or off output, it will not give distance.
The other board is a basic IR remote. The receiver is connected to the Arduino and when you press a button on the remote, a decoded value is read. There are many examples in this forum. Search for "IR remote" in the search box at top of this page.
anton1o:
But i would like to get samples of code to use it for distance measuring
That is not a good sensor for measuring distance. I believe it just lets you know if it senses a reflection or not. It's generally used to detect lines.
It can be used to sense nearby reflective objects, such as following a line with a robot.
You might be able to use it to detect obstacles but I doubt it will work well. It will only indicate if it senses an obstacle, it won't let you know how far away the obstacle is. The color of the obstacle will likely affect how well it is detected.
