Just removed the library that gave me the error message and used the library that came with the video. Got a new error message:
Full sketch:
* Project Sim Racing Library for Arduino
* @author David Madison
* @link github.com/dmadison/Sim-Racing-Arduino
* @license LGPLv3 - Copyright (c) 2022 David Madison
* This file is part of the Sim Racing Library for Arduino.
* This program is free software: you can redistribute it and/or modify
* it under the terms of the GNU Lesser General Public License as published by
* the Free Software Foundation, either version 3 of the License, or
* (at your option) any later version.
* This program is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU Lesser General Public License for more details.
* You should have received a copy of the GNU Lesser General Public License
* along with this program. If not, see <http://www.gnu.org/licenses/>.
* @brief Emulates the shifter as a joystick over USB.
* @example ShiftJoystick.ino
// This example requires the Arduino Joystick Library
// Download Here: https://github.com/MHeironimus/ArduinoJoystickLibrary
#include <SimRacing.h>
#include <Joystick.h>
// Set this option to 'true' to send the shifter's X/Y position
// as a joystick. This is not needed for most games.
const bool SendAnalogAxis = false;
// Set this option to 'true' to send the raw state of the reverse
// trigger as its own button. This is not needed for any racing
// games, but can be useful for custom controller purposes.
const bool SendReverseRaw = false;
const int Pin_ShifterX = A0;
const int Pin_ShifterY = A2;
const int Pin_ShifterRev = 2;
SimRacing::LogitechShifter shifter(Pin_ShifterX, Pin_ShifterY, Pin_ShifterRev);
const int Gears[] = { 1, 2, 3, 4, 5, 6, -1 };
const int NumGears = sizeof(Gears) / sizeof(Gears[0]);
const int ADC_Max = 1023; // 10-bit on AVR
Joystick_ Joystick(
JOYSTICK_DEFAULT_REPORT_ID, // default report (no additional pages)
JOYSTICK_TYPE_JOYSTICK, // so that this shows up in Windows joystick manager
NumGears + SendReverseRaw, // number of buttons (7 gears: reverse and 1-6)
0, // number of hat switches (none)
SendAnalogAxis, SendAnalogAxis, // include X and Y axes for analog output, if set above
false, false, false, false, false, false, false, false, false); // no other axes
void updateJoystick(); // forward-declared function for non-Arduino environments
shifter.begin();
// if you have one, your calibration line should go here
Joystick.begin(false); // 'false' to disable auto-send
Joystick.setXAxisRange(0, ADC_Max);
Joystick.setYAxisRange(ADC_Max, 0); // invert axis so 'up' is up
updateJoystick(); // send initial state
shifter.update();
if (SendAnalogAxis == true || shifter.gearChanged()) {
updateJoystick();
void updateJoystick() {
// set the buttons corresponding to the gears
for (int i = 0; i < NumGears; i++) {
if (shifter.getGear() == Gears[i]) {
Joystick.pressButton(i);
else {
Joystick.releaseButton(i);
// set the analog axes (if the option is set)
if (SendAnalogAxis == true) {
int x = shifter.getPosition(SimRacing::X, 0, ADC_Max);
int y = shifter.getPosition(SimRacing::Y, 0, ADC_Max);
Joystick.setXAxis(x);
Joystick.setYAxis(y);
// set the reverse button (if the option is set)
if (SendReverseRaw == true) {
bool reverseState = shifter.getReverseButton();
Joystick.setButton(NumGears, reverseState); // "NumGears" is the 0-indexed max gear + 1
Joystick.sendState();
Error message:
C:\Users\Name\AppData\Local\Temp\.arduinoIDE-unsaved202319-25432-lof0ey.zfy7i\ShiftJoystick\ShiftJoystick.ino:54:1: error: 'Joystick_' does not name a type; did you mean 'Joystick'?
Joystick_ Joystick(
Joystick
C:\Users\Name\AppData\Local\Temp\.arduinoIDE-unsaved202319-25432-lof0ey.zfy7i\ShiftJoystick\ShiftJoystick.ino: In function 'void setup()':
C:\Users\Name\AppData\Local\Temp\.arduinoIDE-unsaved202319-25432-lof0ey.zfy7i\ShiftJoystick\ShiftJoystick.ino:70:10: error: expected unqualified-id before '.' token
C:\Users\Name\AppData\Local\Temp\.arduinoIDE-unsaved202319-25432-lof0ey.zfy7i\ShiftJoystick\ShiftJoystick.ino:71:10: error: expected unqualified-id before '.' token
C:\Users\Name\AppData\Local\Temp\.arduinoIDE-unsaved202319-25432-lof0ey.zfy7i\ShiftJoystick\ShiftJoystick.ino:72:10: error: expected unqualified-id before '.' token
C:\Users\Name\AppData\Local\Temp\.arduinoIDE-unsaved202319-25432-lof0ey.zfy7i\ShiftJoystick\ShiftJoystick.ino: In function 'void updateJoystick()':
C:\Users\Name\AppData\Local\Temp\.arduinoIDE-unsaved202319-25432-lof0ey.zfy7i\ShiftJoystick\ShiftJoystick.ino:89:12: error: expected unqualified-id before '.' token
C:\Users\Name\AppData\Local\Temp\.arduinoIDE-unsaved202319-25432-lof0ey.zfy7i\ShiftJoystick\ShiftJoystick.ino:92:12: error: expected unqualified-id before '.' token
C:\Users\Name\AppData\Local\Temp\.arduinoIDE-unsaved202319-25432-lof0ey.zfy7i\ShiftJoystick\ShiftJoystick.ino:100:11: error: expected unqualified-id before '.' token
C:\Users\Name\AppData\Local\Temp\.arduinoIDE-unsaved202319-25432-lof0ey.zfy7i\ShiftJoystick\ShiftJoystick.ino:101:11: error: expected unqualified-id before '.' token
C:\Users\Name\AppData\Local\Temp\.arduinoIDE-unsaved202319-25432-lof0ey.zfy7i\ShiftJoystick\ShiftJoystick.ino:107:11: error: expected unqualified-id before '.' token
C:\Users\Name\AppData\Local\Temp\.arduinoIDE-unsaved202319-25432-lof0ey.zfy7i\ShiftJoystick\ShiftJoystick.ino:110:10: error: expected unqualified-id before '.' token
Multiple libraries were found for "SimRacing.h"
Used: C:\Users\Name\OneDrive\Documents\Arduino\libraries\Sim-Racing-Arduino-1.1.3
Not used: C:\Users\Name\OneDrive\Documents\Arduino\libraries\Sim_Racing_Library
exit status 1
Compilation error: 'Joystick_' does not name a type; did you mean 'Joystick'?
