Using Not Connected Pins on RA4M1
The RA4M1 used in the R4 Minima has a lot of pins that are not connected. If I wanted to use 8 ADC pins and I2C plus 8 GPIO pins, can other pins not available to the UNO format be used/accessed using a sketch if I build my own board with a RA4M1?
P003, P004, P011, P012, P013 could be used as ADC.
Yes.
What is more if you choose the 100 pin chip you can access things that are not even possible on the 44 pin version. Like the I2S interface.
Thanks, do you have any examples of using pinMode(), digitalWrite() and analogRead() for pins outside of the range of the UNO R4?
There are no and can't be such examples, since the extra pins are not defined in arduino core files. You must first add the pin definitions (and perhaps edit a pin accessing functions) yourself.
A couple of different ways:
Update pin tables: either directly in their variant or make your own variant.
for example to update MINIMA, go to the variant folder and update variant.cpp.
You will see a table near the start that looks like:
extern "C" const PinMuxCfg_t g_pin_cfg[] = {
  { BSP_IO_PORT_03_PIN_01,    P301   }, /* (0) D0  -------------------------  DIGITAL  */
  { BSP_IO_PORT_03_PIN_02,    P302   }, /* (1) D1  */
  { BSP_IO_PORT_01_PIN_05,    P105   }, /* (2) D2  */
  { BSP_IO_PORT_01_PIN_04,    P104   }, /* (3) D3~ */
  { BSP_IO_PORT_01_PIN_03,    P103   }, /* (4) D4  */
  { BSP_IO_PORT_01_PIN_02,    P102   }, /* (5) D5~ */
  { BSP_IO_PORT_01_PIN_06,    P106   }, /* (6) D6~ */
  { BSP_IO_PORT_01_PIN_07,    P107   }, /* (7) D7  */
  { BSP_IO_PORT_03_PIN_04,    P304   }, /* (8) D8  */
  { BSP_IO_PORT_03_PIN_03,    P303   }, /* (9) D9~  */
  { BSP_IO_PORT_01_PIN_12,    P112   }, /* (10) D10~ */
  { BSP_IO_PORT_01_PIN_09,    P109   }, /* (11) D11~ */
  { BSP_IO_PORT_01_PIN_10,    P110   }, /* (12) D12 */
  { BSP_IO_PORT_01_PIN_11,    P111   }, /* (13) D13 */
  { BSP_IO_PORT_00_PIN_14,    P014   }, /* (14) A0  --------------------------  ANALOG  */
  { BSP_IO_PORT_00_PIN_00,    P000   }, /* (15) A1  */
  { BSP_IO_PORT_00_PIN_01,    P001   }, /* (16) A2  */
  { BSP_IO_PORT_00_PIN_02,    P002   }, /* (17) A3  */
  { BSP_IO_PORT_01_PIN_01,    P101   }, /* (18) A4/SDA  */
  { BSP_IO_PORT_01_PIN_00,    P100   }, /* (19) A5/SCL  */
  { BSP_IO_PORT_05_PIN_00,    P500   }, /* (20) Analog voltage measure pin  */
  { BSP_IO_PORT_00_PIN_12,    P012   }, /* (21) TX LED  */
  { BSP_IO_PORT_00_PIN_13,    P013   }, /* (22) RX LED  */
  { BSP_IO_PORT_05_PIN_01,    P501   }, /* (23) TX on SWD connector  */
  { BSP_IO_PORT_05_PIN_02,    P502   }, /* (24) RX on SWD connector  */
  { BSP_IO_PORT_01_PIN_08,    P108   }, /* (25) SWDIO  */
  { BSP_IO_PORT_03_PIN_00,    P300   }, /* (26) SWCLK  */
Add your new pins at the end.
You then go into the file pinmux.inc and add data for each of the pins.
Note the last pin in table above is P300 - port 3 pin 0
In the pinmux.inc you will find:
const uint16_t P300[] = {
PIN_PWM|CHANNEL_0|PWM_CHANNEL_A|GPT_ODD_CFG|LAST_ITEM_GUARD
The section depends on the pins capabilities. And you can hopefully deduce the data from other like pins that are defined.
unwind the calls like digitalWrite:
For example:
pinMode(0. OUTPUT);
digitalWrite(0, HIGH);
Could be replaced by:
R_IOPORT_PinCfg(NULL,BSP_IO_PORT_03_PIN_01,IOPORT_CFG_PORT_DIRECTION_OUTPUT | IOPORT_CFG_PMOS_ENABLE);
R_IOPORT_PinWrite(NULL, BSP_IO_PORT_03_PIN_01, BSP_IO_LEVEL_HIGH);`
Write your own tables and methods:
Combination of the two. - That is create your own table for the added pins,
And duplicate the functions like digitalWrite -> digitalWriteAdded
Where it looks at your table of added pins to then call off to the underlying system.
Actually, there are/were examples, like in the thread @susan-parker :
showed an example of setting the TX/RX leds before the latest update was released.
Do RX/TX LEDS glow? - UNO R4 / UNO R4 Minima - Arduino Forum
Here is an alternative version of it, like I mentioned in previous post:
R_IOPORT_PinCfg(NULL,BSP_IO_PORT_00_PIN_12,IOPORT_CFG_PORT_DIRECTION_OUTPUT | IOPORT_CFG_PMOS_ENABLE); // TX LED
  R_IOPORT_PinCfg(NULL,BSP_IO_PORT_00_PIN_13,IOPORT_CFG_PORT_DIRECTION_OUTPUT | IOPORT_CFG_PMOS_ENABLE); // RX LED
  R_IOPORT_PinWrite(NULL, BSP_IO_PORT_00_PIN_12, BSP_IO_LEVEL_HIGH);
  R_IOPORT_PinWrite(NULL, BSP_IO_PORT_00_PIN_13, BSP_IO_LEVEL_LOW);
  R_IOPORT_PinWrite(NULL, BSP_IO_PORT_00_PIN_12, BSP_IO_LEVEL_LOW);
  R_IOPORT_PinWrite(NULL, BSP_IO_PORT_00_PIN_13, BSP_IO_LEVEL_HIGH);
It alternates turning TX and RX led on and off...
It are not an examples of using digitalWrite() etc... functions. These lines uses a specific methods, unknown in arduino ecosystem.
Thank you @KurtE. All of these approaches are good for me. I want to try and limit my use of IDEs and didn't want to need to learn e2 which is the Renesas development platform for RA4M1.
These alternate examples work in the Arduino IDE...
Point to note - the standard Arduino IDE pin write with digitalWrite(); IS VERY SLOW!!!
Thanks
Not doing any time critical pin control with digitalWrite().
@KurtE I do not appear to have a variants.cpp file under the ArduinoData/packages folder. I have tried removing the support for Arduino R4 UNO boards and then re-installing but no such file is being installed? Any idea what is going on here?
Not sure what folder that is? Which OS are you using? What version of IDE?
Windows 10, Arduino IDE 2.2.1
It should be wherever your Arduino15 directory is:
On my machine W11, it is stored at:
C:\Users\kurte\AppData\Local\Arduino15
Obviously, your username will be different.
Under this directory you should see a structure like:
packages\arduino\hardware\renesas_uno
The next directory down should be which version of the board you installed,
In my case 1.0.4...
So the complete directory on machine for the MINIMA where the file exists is:
C:\Users\kurte\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.0.4\variants\MINIMA
Can you please review my custom board core files , i have updated ? i want to make a mega like board using 100 pins version of renesas Ra4m1. pins_arduino.h :-
#pragma once
#define PIN(X,Y) (X * 16 + Y)  // Ensures unique pin numbering, adjusted for RA4M1 ports
// Pin count
#ifdef __cplusplus
extern "C" unsigned int PINCOUNT_fn();
#endif
#define PINS_COUNT           (PINCOUNT_fn())
#define NUM_DIGITAL_PINS     (70u)
#define NUM_ANALOG_INPUTS    (16u)
#define NUM_ANALOG_OUTPUTS   (1u)
// Analog Pins (A0 - A15) mapped to RA4M1 analog inputs
#define PIN_A0   (54u)  // Maps to RA4M1 pin 100 (AN000)
#define PIN_A1   (55u)  // Maps to RA4M1 pin 99 (AN001)
#define PIN_A2   (56u)  // Maps to RA4M1 pin 98 (AN002)
#define PIN_A3   (57u)  // Maps to RA4M1 pin 97 (AN003)
#define PIN_A4   (58u)  // Maps to RA4M1 pin 96 (AN004)
#define PIN_A5   (59u)  // Maps to RA4M1 pin 95 (AN011)
#define PIN_A6   (60u)  // Maps to RA4M1 pin 94 (AN012)
#define PIN_A7   (61u)  // Maps to RA4M1 pin 93 (AN013)
#define PIN_A8   (62u)  // Maps to RA4M1 pin 92 (AN014)
#define PIN_A9   (63u)  // Maps to RA4M1 pin 91 (AN005)
#define PIN_A10  (64u)  // Maps to RA4M1 pin 90 (AN006)
#define PIN_A11  (65u)  // Maps to RA4M1 pin 87 (AN007)
#define PIN_A12  (66u)  // Maps to RA4M1 pin 86 (AN008)
#define PIN_A13  (67u)  // Maps to RA4M1 pin 85 (AN009, also DAC)
#define PIN_A14  (68u)  // Maps to RA4M1 pin 84 (AN010)
#define PIN_A15  (69u)  // Maps to RA4M1 pin 76 (AN016)
// DAC (Digital-to-Analog Converter)
#define DAC8_HOWMANY   (0)  // No 8-bit DAC
#define DAC12_HOWMANY  (1)  // One 12-bit DAC
#define DAC            PIN_A13   // DAC output mapped to A13, RA4M1 pin 85
#define IS_DAC(x)      (x == DAC ? true : false)
#define DAC_ADDRESS_12_CH0  R_DAC_BASE  // DAC Register Base Address
#undef A0
#undef A1
#undef A2
#undef A3
#undef A4
#undef A5
#undef A6
#undef A7
#undef A8
#undef A9
#undef A10
#undef A11
#undef A12
#undef A13
#undef A14
#undef A15
static const uint8_t A0 = PIN_A0;
static const uint8_t A1 = PIN_A1;
static const uint8_t A2 = PIN_A2;
static const uint8_t A3 = PIN_A3;
static const uint8_t A4 = PIN_A4;
static const uint8_t A5 = PIN_A5;
static const uint8_t A6 = PIN_A6;
static const uint8_t A7 = PIN_A7;
static const uint8_t A8 = PIN_A8;
static const uint8_t A9 = PIN_A9;
static const uint8_t A10 = PIN_A10;
static const uint8_t A11 = PIN_A11;
static const uint8_t A12 = PIN_A12;
static const uint8_t A13 = PIN_A13;
static const uint8_t A14 = PIN_A14;
static const uint8_t A15 = PIN_A15;
// Digital Pins (D0 - D69) mapped to RA4M1 digital I/O pins
#define PIN_D0   (0u)   // Maps to RA4M1 pin 22 (UART1 RX)
#define PIN_D1   (1u)   // Maps to RA4M1 pin 21 (UART1 TX)
#define PIN_D2   (2u)   // Maps to RA4M1 pin 26 (PWM capable)
#define PIN_D3   (3u)   // Maps to RA4M1 pin 27 (PWM capable)
#define PIN_D4   (4u)   // Maps to RA4M1 pin 52 (CAN TX)
#define PIN_D5   (5u)   // Maps to RA4M1 pin 53 (CAN RX)
#define PIN_D6   (6u)   // Maps to RA4M1 pin 28 (PWM capable)
#define PIN_D7   (7u)   // Maps to RA4M1 pin 29 (PWM capable)
#define PIN_D8   (8u)   // Maps to RA4M1 pin 30 (PWM capable)
#define PIN_D9   (9u)   // Maps to RA4M1 pin 31 (PWM capable)
#define PIN_D10  (10u)  // Maps to RA4M1 pin 32 (PWM capable)
#define PIN_D11  (11u)  // Maps to RA4M1 pin 33 (PWM capable)
#define PIN_D12  (12u)  // Maps to RA4M1 pin 34 (PWM capable)
#define PIN_D13  (13u)  // Maps to RA4M1 pin 35 (PWM capable, built-in LED)
#define PIN_D14  (14u)  // Maps to RA4M1 pin 24 (UART4 RX)
#define PIN_D15  (15u)  // Maps to RA4M1 pin 25 (UART4 TX)
#define PIN_D16  (16u)  // Maps to RA4M1 pin 16 (UART3 RX)
#define PIN_D17  (17u)  // Maps to RA4M1 pin 17 (UART3 TX)
#define PIN_D18  (18u)  // Maps to RA4M1 pin 14 (UART2 RX)
#define PIN_D19  (19u)  // Maps to RA4M1 pin 13 (UART2 TX)
#define PIN_D20  (20u)  // Maps to RA4M1 pin 36 (general digital)
#define PIN_D21  (21u)  // Maps to RA4M1 pin 37 (general digital, LED_TX)
#define PIN_D22  (22u)  // Maps to RA4M1 pin 38 (general digital, LED_RX)
#define PIN_D23  (23u)  // Maps to RA4M1 pin 39 (general digital)
#define PIN_D24  (24u)  // Maps to RA4M1 pin 40 (general digital)
#define PIN_D25  (25u)  // Maps to RA4M1 pin 41 (general digital)
#define PIN_D26  (26u)  // Maps to RA4M1 pin 42 (general digital)
#define PIN_D27  (27u)  // Maps to RA4M1 pin 43 (general digital)
#define PIN_D28  (28u)  // Maps to RA4M1 pin 44 (general digital)
#define PIN_D29  (29u)  // Maps to RA4M1 pin 45 (general digital)
#define PIN_D30  (30u)  // Maps to RA4M1 pin 46 (general digital)
#define PIN_D31  (31u)  // Maps to RA4M1 pin 47 (general digital)
#define PIN_D32  (32u)  // Maps to RA4M1 pin 48 (general digital)
#define PIN_D33  (33u)  // Maps to RA4M1 pin 49 (general digital)
#define PIN_D34  (34u)  // Maps to RA4M1 pin 50 (general digital)
#define PIN_D35  (35u)  // Maps to RA4M1 pin 51 (general digital)
#define PIN_D36  (36u)  // Maps to RA4M1 pin 54 (general digital)
#define PIN_D37  (37u)  // Maps to RA4M1 pin 55 (general digital)
#define PIN_D38  (38u)  // Maps to RA4M1 pin 56 (general digital)
#define PIN_D39  (39u)  // Maps to RA4M1 pin 57 (general digital)
#define PIN_D40  (40u)  // Maps to RA4M1 pin 58 (general digital)
#define PIN_D41  (41u)  // Maps to RA4M1 pin 59 (general digital)
#define PIN_D42  (42u)  // Maps to RA4M1 pin 60 (general digital)
#define PIN_D43  (43u)  // Maps to RA4M1 pin 61 (general digital)
#define PIN_D44  (44u)  // Maps to RA4M1 pin 62 (PWM capable)
#define PIN_D45  (45u)  // Maps to RA4M1 pin 63 (PWM capable)
#define PIN_D46  (46u)  // Maps to RA4M1 pin 64 (PWM capable)
#define PIN_D47  (47u)  // Maps to RA4M1 pin 65 (general digital)
#define PIN_D48  (48u)  // Maps to RA4M1 pin 66 (general digital)
#define PIN_D49  (49u)  // Maps to RA4M1 pin 67 (general digital)
#define PIN_D50  (50u)  // Maps to RA4M1 pin 68 (general digital, SPI MISO)
#define PIN_D51  (51u)  // Maps to RA4M1 pin 69 (general digital, SPI MOSI)
#define PIN_D52  (52u)  // Maps to RA4M1 pin 70 (general digital, SPI SCK)
#define PIN_D53  (53u)  // Maps to RA4M1 pin 71 (general digital, SPI CS)
#define PIN_D54  (54u)  // Maps to RA4M1 pin 85 (A0, analog input)
#define PIN_D55  (55u)  // Maps to RA4M1 pin 84 (A1, analog input)
#define PIN_D56  (56u)  // Maps to RA4M1 pin 83 (A2, analog input)
#define PIN_D57  (57u)  // Maps to RA4M1 pin 82 (A3, analog input)
#define PIN_D58  (58u)  // Maps to RA4M1 pin 81 (A4, analog input)
#define PIN_D59  (59u)  // Maps to RA4M1 pin 80 (A5, analog input)
#define PIN_D60  (60u)  // Maps to RA4M1 pin 79 (A6, analog input)
#define PIN_D61  (61u)  // Maps to RA4M1 pin 78 (A7, analog input)
#define PIN_D62  (62u)  // Maps to RA4M1 pin 77 (A8, analog input)
#define PIN_D63  (63u)  // Maps to RA4M1 pin 76 (A9, analog input)
#define PIN_D64  (64u)  // Maps to RA4M1 pin 75 (A10, analog input)
#define PIN_D65  (65u)  // Maps to RA4M1 pin 74 (A11, analog input)
#define PIN_D66  (66u)  // Maps to RA4M1 pin 73 (A12, analog input)
#define PIN_D67  (67u)  // Maps to RA4M1 pin 72 (A13, analog input)
#define PIN_D68  (68u)  // Maps to RA4M1 pin 71 (A14, analog input)
#define PIN_D69  (69u)  // Maps to RA4M1 pin 70 (A15, analog input)
#undef D0
#undef D1
#undef D2
#undef D3
#undef D4
#undef D5
#undef D6
#undef D7
#undef D8
#undef D9
#undef D10
#undef D11
#undef D12
#undef D13
#undef D14
#undef D15
#undef D16
#undef D17
#undef D18
#undef D19
#undef D20
#undef D21
#undef D22
#undef D23
#undef D24
#undef D25
#undef D26
#undef D27
#undef D28
#undef D29
#undef D30
#undef D31
#undef D32
#undef D33
#undef D34
#undef D35
#undef D36
#undef D37
#undef D38
#undef D39
#undef D40
#undef D41
#undef D42
#undef D43
#undef D44
#undef D45
#undef D46
#undef D47
#undef D48
#undef D49
#undef D50
#undef D51
#undef D52
#undef D53
#undef D54
#undef D55
#undef D56
#undef D57
#undef D58
#undef D59
#undef D60
#undef D61
#undef D62
#undef D63
#undef D64
#undef D65
#undef D66
#undef D67
#undef D68
#undef D69
static const uint8_t D0 = PIN_D0;
static const uint8_t D1 = PIN_D1;
static const uint8_t D2 = PIN_D2;
static const uint8_t D3 = PIN_D3;
static const uint8_t D4 = PIN_D4;
static const uint8_t D5 = PIN_D5;
static const uint8_t D6 = PIN_D6;
static const uint8_t D7 = PIN_D7;
static const uint8_t D8 = PIN_D8;
static const uint8_t D9 = PIN_D9;
static const uint8_t D10 = PIN_D10;
static const uint8_t D11 = PIN_D11;
static const uint8_t D12 = PIN_D12;
static const uint8_t D13 = PIN_D13;
static const uint8_t D14 = PIN_D14;
static const uint8_t D15 = PIN_D15;
static const uint8_t D16 = PIN_D16;
static const uint8_t D17 = PIN_D17;
static const uint8_t D18 = PIN_D18;
static const uint8_t D19 = PIN_D19;
static const uint8_t D20 = PIN_D20;
static const uint8_t D21 = PIN_D21;
static const uint8_t D22 = PIN_D22;
static const uint8_t D23 = PIN_D23;
static const uint8_t D24 = PIN_D24;
static const uint8_t D25 = PIN_D25;
static const uint8_t D26 = PIN_D26;
static const uint8_t D27 = PIN_D27;
static const uint8_t D28 = PIN_D28;
static const uint8_t D29 = PIN_D29;
static const uint8_t D30 = PIN_D30;
static const uint8_t D31 = PIN_D31;
static const uint8_t D32 = PIN_D32;
static const uint8_t D33 = PIN_D33;
static const uint8_t D34 = PIN_D34;
static const uint8_t D35 = PIN_D35;
static const uint8_t D36 = PIN_D36;
static const uint8_t D37 = PIN_D37;
static const uint8_t D38 = PIN_D38;
static const uint8_t D39 = PIN_D39;
static const uint8_t D40 = PIN_D40;
static const uint8_t D41 = PIN_D41;
static const uint8_t D42 = PIN_D42;
static const uint8_t D43 = PIN_D43;
static const uint8_t D44 = PIN_D44;
static const uint8_t D45 = PIN_D45;
static const uint8_t D46 = PIN_D46;
static const uint8_t D47 = PIN_D47;
static const uint8_t D48 = PIN_D48;
static const uint8_t D49 = PIN_D49;
static const uint8_t D50 = PIN_D50;
static const uint8_t D51 = PIN_D51;
static const uint8_t D52 = PIN_D52;
static const uint8_t D53 = PIN_D53;
static const uint8_t D54 = PIN_D54;
static const uint8_t D55 = PIN_D55;
static const uint8_t D56 = PIN_D56;
static const uint8_t D57 = PIN_D57;
static const uint8_t D58 = PIN_D58;
static const uint8_t D59 = PIN_D59;
static const uint8_t D60 = PIN_D60;
static const uint8_t D61 = PIN_D61;
static const uint8_t D62 = PIN_D62;
static const uint8_t D63 = PIN_D63;
static const uint8_t D64 = PIN_D64;
static const uint8_t D65 = PIN_D65;
static const uint8_t D66 = PIN_D66;
static const uint8_t D67 = PIN_D67;
static const uint8_t D68 = PIN_D68;
static const uint8_t D69 = PIN_D69;
// PWM (GPT Timer)
#define digitalPinHasPWM(p) (IS_PIN_PWM(getPinCfgs(p, PIN_CFG_REQ_PWM)[0]))
// LED Pins
#define PIN_LED     (13u)  // Built-in LED, maps to RA4M1 pin 35
#define LED_BUILTIN PIN_LED
#define LED_TX      (21u)  // TX LED, maps to RA4M1 pin 37
#define LED_RX      (22u)  // RX LED, maps to RA4M1 pin 38
// RTC
#define RTC_HOWMANY 1
// UART
#define SERIAL_HOWMANY   4
#define UART1_TX_PIN     1   // Maps to RA4M1 pin 21 (TXD0)
#define UART1_RX_PIN     0   // Maps to RA4M1 pin 22 (RXD0)
#define UART2_TX_PIN     19  // Maps to RA4M1 pin 13 (TXD1)
#define UART2_RX_PIN     18  // Maps to RA4M1 pin 14 (RXD1)
#define UART3_TX_PIN     17  // Maps to RA4M1 pin 17 (TXD2)
#define UART3_RX_PIN     16  // Maps to RA4M1 pin 16 (RXD2)
#define UART4_TX_PIN     15  // Maps to RA4M1 pin 25 (TXD3)
#define UART4_RX_PIN     14  // Maps to RA4M1 pin 24 (RXD3)
// I2C (Wire)
#define WIRE_HOWMANY     1
#define WIRE_SDA_PIN     20  // Maps to RA4M1 pin 2 (SDA0)
#define WIRE_SCL_PIN     21  // Maps to RA4M1 pin 1 (SCL0)
static const uint8_t SDA = WIRE_SDA_PIN;
static const uint8_t SCL = WIRE_SCL_PIN;
// SPI
#define SPI_HOWMANY      1
#define PIN_SPI_MOSI     (51)  // Maps to RA4M1 pin 30 (MOSI alternative)
#define PIN_SPI_MISO     (50)  // Maps to RA4M1 pin 31 (MISO alternative)
#define PIN_SPI_SCK      (52)  // Maps to RA4M1 pin 32 (SCK alternative)
#define PIN_SPI_CS       (53)  // Maps to RA4M1 pin 33 (CS alternative)
#define FORCE_SPI_MODE  (MODE_SPI)
static const uint8_t MOSI = PIN_SPI_MOSI;
static const uint8_t MISO = PIN_SPI_MISO;
static const uint8_t SCK  = PIN_SPI_SCK;
static const uint8_t CS   = PIN_SPI_CS;
static const uint8_t SS   = PIN_SPI_CS;
// GPT Timers
#define GTP32_HOWMANY     2
#define GTP16_HOWMANY     6
#define GPT_HOWMANY       8
// AGT Timers
#define AGT_HOWMANY       2
// CAN
#define CAN_HOWMANY       1
#define PIN_CAN0_TX       (4)   // Maps to RA4M1 pin 52 (CTX0)
#define PIN_CAN0_RX       (5)   // Maps to RA4M1 pin 53 (CRX0)
#define PIN_CAN0_STBY    (-1)
// External Interrupts
#define EXT_INTERRUPTS_HOWMANY 2
// In pins_arduino.h or equivalent
#define AVCC_MEASURE_PIN 55  // Adjusted to analog pin
#define AVCC_MULTIPLY_FACTOR 8.33
#define AR_INTERNAL_VOLTAGE 1.43f  // Matches RA4M1 spec
// USB
#define USB_VID           (0x2341)
#define USB_PID           (0x0069)
#define USB_NAME          "Mega Rev 4"
#define VUSB_LDO_ENABLE   1
// EEPROM
#define ARDUINO_FLASH_TYPE  LP_FLASH
#define FLASH_BASE_ADDRESS  0x40100000
#define FLASH_TOTAL_SIZE    0x2000
#define FLASH_BLOCK_SIZE    0x400
#ifdef __cplusplus
extern "C" {
#endif
void iic_slave_tei_isr(void);
void iic_slave_eri_isr(void);
#ifdef __cplusplus
#endif
