Continuing the discussion from Portenta C33 Incompatible with Portenta Breakout Board:
I have the same issue. Using Portenta Mid Carrier for the C33. Any solution for the mbed.h: no such file or directory?
Hi @nilsjuri.
You can learn how to use the Portenta Mid Carrier with the Portenta C33 from the user manual. This section of the manual is a good starting point for programming:
https://docs.arduino.cc/tutorials/portenta-mid-carrier/user-manual/#hello-world-with-arduino
Hey,
You'll want to use this datasheet:
The second page shows what pin numbers to use. For example, PWM9 is equal to 25. When it comes to pin numbers like D4~ at PWM4, omit the ~.
Hopefully this helps.
Thanks 25 worked!
