All of my digital pins are occupied and I want to use the analog input pins of Arduino Nano for the push button, it is connected to GND and A6.
At first I have this code...
const int buttonPin = A6;
pinMode(buttonPin, INPUT_PULLUP);
int buttonState = digitalRead(buttonPin);
if (buttonState == LOW) {
Serial.println("Button pressed!");
Serial.println("Button not pressed.");
delay(50);
but since, Nano's analog input pins don't have a pull-up resistor, I can't use the PULL_UP, I also found that the analog input pins of Nano are for analog input only. Therefore I am having a hard time using these pins for the push button as it is having fluctuations.
Is there a way for this to work? or Is there any way around this?
Welcome to the forum
You can use the Nano analogue pins A0 to A5 as digital pins, including using INPUT_PULLUP in pinMode() but pins A6 and A7 can only be used as analogue inputs, not digital
All of my analog pins are occupied for digitalWrite() and I only have A6 and A7 for my buttons. Is there a way that I can use analogRead() in a better way, so that I can use the push buttons without having floating issues.
yes! I scan up to 20 buttons without an issue on A7. I'll post a snippet scan routine later today, unless someone else beats me to it. It's not dead simple, but it can be made to work.
I use a 2.2kohm pullup, a 2.2 nF filter capacitor, and an array of 10% standard value resistors, a unique value for each button. In combination with the pullup, this results in a unique value for the ADC conversion; a lookup table is used to determine which button is pressed. I'll post the values as well; if chosen with some care, one can maintain more than 35 ADC counts between buttons, which makes them easily identifiable.
Locate the unique resistors with the buttons. This results in a 2-wire keypad lead. The shorter this is the better, though the capacitor seems to handle noise pretty well.
caveat: You must, obviously, only press one button at any one time. No multi-press, no n-button-rollover, etc. etc.
I presume there's no interest in the multibutton option, so the short answer to your question is, use an external pullup resistor for each of A6 and A7, and
buttonstateA6 = readAnalog(A6)>511?1:0;
buttonstateA7 = readAnalog(A7)>511?1:0;
Should be all you need.
I added a pullup resistor in the A6, following this schematic
