Using Resistors with LEDs
I often see people online attach a resistor to each individual LED when connected to the Arduino.
Whenever I use multiple LEDs, I tie them all to common ground with a single resistor, since I only have a few 1k resistors.
Either way, it seems to work the same for the LEDs. Is there any problem with the common-ground solution I have found?
OK if you only light one LED at a time. If you light all three they will be significantly less bright - perhaps that's what you want.
Russell.
Lower brightness is kind of a good thing for me--my LEDs are blinding!
Why would it make them all dimmer?
No it doesn't.
If you think it does then you are not testing it correctly.
You will get no sympathy or support for such an idea round here because we know what we are talking about on this forum and that idea is just unbelievably wrong.
That is because these people know what they are doing unlike you.
Well at $0.01 each they are expensive ain't they.
If you don't mind, please explain to me why I am wrong, instead of talking like that.
For what you say I will talk how I like. You should not try and propagate your totally wrong ideas here trying to mislead beginners. Especially so when the slightest research into this would have pointed to the error of your ways, but no you were too lazy and thought that you had invented something that had eluded electronic engineered for 40 years. I see you have 48 posts so you are not entirely a stranger to how things work here. If you are going to give advice here, it has to be correct or people will jump on you like a ton of bricks.
  1. Just try having one red LED and the others a different colour. Light up the red one then see none of the others will light when the red one is on. This is because it takes a certain voltage before an LED can come on and the red LED is the lowest voltage and it prevents any of the others coming on.
  2. Do you know the voltage / current characteristics of an LED? They are non linear devices. Read this to see.
    http://www.thebox.myzen.co.uk/Tutorial/LEDs.html.
  3. The current in an LED circuit is controlled by the resistor. If you have one LED on then that gives you a certain current. Two LEDs with just the one resistor gives you the same current but now split between two LEDs, so it will not be as bright. But worse than that the LEDs will not share current equally so one will get more current that the other and so they will not be the same brightness. This inequality will change with the age of the LED and with the temperature. It will also be different on different individual LEDs.
Legonick, while the setup you have "seems" to work for you, without knowing the specs, you just had good luck. Whether you set up your LEDs in series or parallel just depends on your hardware and your needs. A really good site for determining a good and workable setup for your LEDs is led.linear1.org/led.wiz. You should also listen to surly, I mean Grumpy_Mike, and purchase more resistors. Grab a lot and many different values because no matter how many you have, you'll find you never have quite the one you want.
Think of it this way. If you have 3 LEDs that are rated for 20ma, you could choose a resistor that'll allow 60ma to flow through. That'll power all 3 LEDs just fine using one resistor (assuming they're perfectly matched and draw exactly the same amount of current each). Then you turn one LED off, and suddenly the other two are getting 50% more power than they're rated for. Then you turn another LED off, and the last remaining one will be drawing double what it's rated for. Well, it will for a split second before it burns out, anyways.
Think of Grumpy_Mike as a hazing that is rarely incorrect.
I have found it expedient to buy mixed packs of resistors. And then when I notice I am using a lot of a few values, I may order large-ish quantities of those resistors.
It is when you only buy a few at a time that they seem expensive.
Same for bypass capacitors in the range of 1nF to 100nF.
legonick22:
Many of today's LEDs are vastly more efficient than the original 20th century ones. But a lot of "circuit recipes" are from the old days. People wanted to get as much brightness out of them as possible because they weren't very bright to begin with. So the circuit values reflected a close to maximum "safe" value. 20 mA was very common, since a lot of LEDs had max current of 25 or 30 mA.
As the efficiency of many LEDs now allows outputs in the range of 1000-2000 mcd (even for a 3mm), the old circuits produce a somewhat blinding light if those are used. Sometimes this is a good thing. If it's just an indicator light, sometimes that's overwhelming.
I got on my thinking hat, and started using less current. It worked so well, I started to aim for the most efficient LEDs I could find. It really benefited some circuits by using less power, and loading outputs less. Sometimes I could even get away with a 10k resistor at 5V, and get about the same brightness that a 1984 LED gave with 270 ohms (in fact, that was for a 1984 computer restoration project).
People should stop blindly copying old circuits and look around at what's available today.
If I understand you correctly, you are putting several LEDs in parallel and connecting them in series with only one resistor. If you can live with the LEDs being of unequal brightness this is perfectly OK.
There is a reliability exposure if a significant fraction of the LEDs stop conducting (burn out) in which case the remaining LEDs will carry additional current. For hobby applications, no problem.
charliesixpack:
No you don't understand. legonick22 is switching the LEDs on and off.
charliesixpack:
Would you cair to defend that remark? Last time I looked the laws of physics were the same if you are doing a hobby or not.
Grumpy_Mike:
I think he means that in a hobby project it migth not matter if an LED fails, not that some parallel set of hobby-laws will prevent it burning out. In the real world, it could literally be a train smash if an LED failed although one would hope there was some redundancy.
Ah the casual indifference to component abuse and destruction. Never could get into that mind set myself.
A bit like saying my toadstool pizza is fine as I am not selling it, it's only a hobby.
My last wife I beat to death because she wouldn't eat her "miniature mushroom" pizza.
Grumpy_Mike:
I am not putting my hobby project in a situation where it might be used to do surgery on someone. My hobbies are to please only me.
Boy, that escalated quickly... I only wanted an answer to something that seemed counter intuitive.
I constructed a test sketch that turns 3 LEDs on in off in every possible combination, using a separate 200 ohm resistor for each cathode (I have lots of those!) LED brightness never changed.
I then tried using a single 1k Ohm resistor and 2 200 ohm resistors in series tied commonly to each cathode. Each turned on fine, but I could not turn on all 3 at the same time. Too much current, I guess.
I'm going to spring for some 1k resistors (I know, my maker shopping list is quite long right now...), but I find it strange that it worked with the ArduinoISP sketch, but not this test sketch.
A note to Grumpy_Mike: I'd greatly appreciate it if you wouldn't try to "haze" me. I am not trying to "mislead beginners" and I don't deserve for anybody to "come down on me like a pile of bricks". Simple questions deserve simple answers, and I don't merit insult, even if perhaps my question is ridiculous.
If you are using 200 ohms in series with one LED you must use 200/3 ohms in series with three LEDs if you are connecting the LEDs in parallel and expect to keep the light intensity the same. You must use the equivalent of three 200 ohm resistors in parallel since you are using three LEDs in parallel. If I understand you correctly you are attempting to use a higher value resistor when you connect the LEDs in parallel. This is the opposite of what is required.
If you put different colors in parallel, only the lowest voltage LED will turn on. And hog all the current.
polymorph:
As I said in reply #5
