Hello,
I have a working program that maps a digipot to a timer. I have been trying to create a curve to the mapping that I'm struggling with. With the math the digipot is either at 0 or 127 nothing in-between. the math is with int but returns numbers that have decimal places. that should just round to the nearest whole number wouldn't it?
digitalPot = constrain(temp, 127, 0); //stay within the 0-127 range
digitalpot = sq(digitalpot)/(sq(digitalpot)/127); //math
digitalpot = map(digitalpot, 127, 0, 0, 127); // swap back to correct digipot orentation
ds3502.setWiper(digitalPot);
#include <Adafruit_DS3502.h> // <-----<<<<<
Adafruit_DS3502 ds3502 = Adafruit_DS3502(); // <-----<<<<<
//the DS3502 can be set from 0 to 127 using I2C // <-----<<<<<
#define magnetDetected HIGH
#define noMagnet LOW
#define weAreTiming true
#define weAreNotTiming false
#define BRAKE_IN_PIN A0
const byte CLUTCH_IN_PIN =A3;
const byte POTL = A1; // Pot on Analog Pin 1
const byte POTH = A2; // Pot on Analog Pin 2
bool timerRunningFlag = weAreNotTiming;
const byte sensor = 2;
const byte heartbeatLED = 13;
byte lastWheelState = noMagnet;
int brake_value = 0;
int clutch_value = 0;
int clutch_temp = 0;
int digitalPot ;
int lowspeed = 0; // Low speed set
int highspeed = 0; // High Speed set
int lowrpm = 0; // Low RPM kick in
int highrpm = 0; // High RPM kick in
int lowValue = 0;
int highValue = 0;
int digitalpot =127;
const int lowLow = 500; //reading 0
const int lowHigh = 250; //reading 1023
const int highLow = 251; //reading 0
const int highHigh = 50; //reading 1023
//timing stuff
unsigned long startTime;
unsigned long endTime;
unsigned long duration;
unsigned long timerMillis;
unsigned long heartbeatMillis;
unsigned long wheelMillis;
ds3502.setWiper(0);
pinMode (sensor, INPUT_PULLUP);
pinMode (heartbeatLED, OUTPUT);
while (!Serial)
delay(1);
Serial.println("Adafruit DS3502 Test");
if (!ds3502.begin()) // <-----<<<<<
Serial.println("Couldn't find DS3502 chip"); // <-----<<<<<
while (1); // <-----<<<<<
Serial.println("Found DS3502 chip");
} //END of setup()
//time to toggle the heartbeatLED ?
if(millis() - heartbeatMillis >= 500);
//restart the TIMER
heartbeatMillis = millis();
//toggle the LED
digitalWrite(heartbeatLED, !digitalRead(heartbeatLED));
//time to check the wheel sensor ?
if (millis() - wheelMillis >= 10)
//restart the TIMER
wheelMillis = millis();
checkWheelSensor();
//if we are timing, have we reached the upper timing limit ?
if (timerRunningFlag == weAreTiming && millis() - timerMillis >= 1000)
//disable the timing
duration = 1000;
printDigitalPot();
//Other non-blocking code goes here
while (brake_value < 900) {
ds3502.setWiper(127);
Serial.print("Brake on ");
Serial.println(brake_value);
brake_value = analogRead(BRAKE_IN_PIN);
while (clutch_value < 920 && brake_value > 900) {
clutch_temp = map(clutch_value, 800, 80, digitalPot, 127);
clutch_temp = constrain(clutch_temp, 0, 127);
ds3502.setWiper(clutch_temp);
Serial.print("Clutch on ");
Serial.print(clutch_value);
Serial.print(" Digitalpot value: ");
Serial.println(clutch_temp);
clutch_value = analogRead(CLUTCH_IN_PIN);
} //END of loop()
void checkWheelSensor()
byte thisState = digitalRead(sensor);
//was there a change in state ?
if (lastWheelState != thisState)
//update to the new state
lastWheelState = thisState;
//if we are 'not' timing has the sensor detected the magnet ?
if (timerRunningFlag == weAreNotTiming && thisState == magnetDetected)
//enable timing
timerRunningFlag = weAreTiming;
//start this TIMER
startTime = millis();
//start this TIMER
timerMillis = millis();
if (timerRunningFlag == weAreTiming && thisState == noMagnet)
endTime = millis();
duration = endTime - startTime;
printDigitalPot();
} //END of if(lastWheelState != thisState)
} //END of checkWheelSensor()
void printDigitalPot()
{brake_value = analogRead(BRAKE_IN_PIN);
//read manual pots, map to the required thresholds
lowspeed = analogRead(POTL); //0 to 1023
lowValue = map(lowspeed, 0, 1000, lowLow, lowHigh);
highspeed = analogRead(POTH); //0 to 1023
highValue = map(highspeed, 0, 1000, highLow, highHigh);
int temp = map( duration, highValue, lowValue, 127, 0); // these have been swapped since previous programs to allow for math
Serial.print("LOW ");
Serial.print(lowspeed);
Serial.print(" Time ");
Serial.print(lowValue);
Serial.print(" ");
Serial.print("HIGH ");
Serial.print(highspeed);
Serial.print(highValue);
Serial.print (" Time in millis = ");
Serial.print (duration);
Serial.print(" Digital pot set to: ");
Serial.print(digitalPot);
Serial.print("\t");
Serial.print("Brake : ");
Serial.print(brake_value);
Serial.print("Clutch : ");
Serial.println(clutch_value);
Serial.println("");
