Using two motor drivers with the same pins
Hi all,
Im planning to create a RC tank using 2 motor drivers and 4 motors (motor drivers have 2 outputs). I am thinking i can wire it it such a way to be that each motor driver would control the front and back the same way. To save space on my pin board, can i connect the motor drivers in series or parallel to only the voltage from the amount of pins needed for one motor driver and still run both?
Thanks
Not entirely sure what you are asking but at a minimum, you will need 2 pins per driver (so 4 pins in total for 2 drivers). What board are you using where you need to "save space"?
Can you draw us a schematic of what you want to do?
Im at work at the moment and doing this on breaks so cant make a full schematic right now, sorry for the long time for a reply too. Im using a transceiver (nRF24L01) with this project and from a tutorial from "how to mechatronics" says to use 6 pins (not including power or ground) https://howtomechatronics.com/tutorials/arduino/arduino-wireless-communication-nrf24l01-tutorial/
The motor drivers in using are 2x7A Dc Motor drivers from DFRobot and their product wiki says to use 6 pins as well (not including power and ground).
7A_Dual_DC_Motor_Driver_SKU__DRI0041-DFRobot
Im using the Arduino Uno Rev 3 (14 digital pins with 6 PWM)
Using the these following what those say makes 18 pins. Meaning more than the Rev 3 has and that not including using pins for other components.
My real question is, could i connect the same digital pins outputs to the same input on the two different motor drivers if i want them to do the same thing meaning only using 6 outputs instead of 12?
Or are these numbers from the tutorials and wiki overkill and i can use less.
I can make a full schematic later on in the day if i havent given enough info or hasnt answered your question.
Assuming one driver controls one side, you can run them in parallel. IN1 and IN2 are the forwards/Backwards and ENA/ENB are just enable line, which you can make always high.
2 wires for power, 2 wires for direction per driver.
The power wires will be going to both drivers so all you need to worry about are the 4 direction pins.
Thanks alot for this!
