Hello,
which value has this capacitor?
Would help me very much!
Greetz Chris
It looks like .1K pF = 100pF (=0.0001uF) @ 100V.
I would agree with the interpretation of the numbers but it looks a bit big to be only 100pF.
Probably, dot is a typo, than 1k = 1000 pF
...but it looks a bit big to be only 100pF.
I was thinking the same thing. Since it's a new part (not something that needs to be replaced/duplicated in a circuit), if it's for a critical application buy a new one! Or, try it and if it doesn't work as expected, replace it.
A lot of multimeters now have a capacitance measure feature. Try it.
DVDdoug:
The size depends on the voltage rating. It might be 10,000V... ![]()
.1 is 0.1uF
K is Tolerance of capacitor +/- 10%
100 is 100V
Yes it looks the right size for a 0.1uF 100V cap I will buy that one.
If only component manufacturers used straightforward values printed on, rather than
daft codes! "100n 100V" isn't that hard to print ![]()
You are right. ![]()
Thanks to all. ![]()
Why not use Arduino Capacitance Meter?
Here is Atmel/Arduino forum, not Microchip/Pic forum ! ![]()
