Variables not updating in MIDI code
Hello,
I'm working on a MIDI controlled drumset in which my snare drum will use 2 drumsticks activated by solenoids through a relay module.
I've written my code to alternate drumsticks with each MIDI NOTE-ON signal but for some reason, it appears that the variable that dictates which drumstick to use (snareStick) is not updating and prevents them from alternating.
At the moment, each snare NOTE-ON signal:
  1. skips the variable update
  2. turns on the built-in LED
  3. and hits with the first stick
void HandleNoteOn(byte channel, byte pitch, byte velocity) {
  switch (pitch) {
    case 38://----------------------Snare = D2/38
      if(snareStick = 1){
        snareStick = 2;             digitalWrite(LED_BUILTIN, HIGH);
        Hit(snare1);
      else{
        snareStick = 1;             digitalWrite(LED_BUILTIN, LOW);
        Hit(snare2);
    default:
This code is pretty simple so I imagine there is some disconnect in scope with the MIDI.read & HandleNoteOn functions or some other factor I wouldn't know about.
Here's my entire code:
//xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
//xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx DEFFINITIONS xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
#include <MIDI.h>
MIDI_CREATE_DEFAULT_INSTANCE();
//---------SETUP PARAMETERS---------
const int hitDur = 80;                     //solenoid ON duration for each hit (in milliseconds)
int snareStick = 1;                       //snare stick that plays first (alternates afterwards)
//---------------PINS---------------
const int snare1 = 2;
const int snare2 = 3;
const int bass = 4;
const int cymbal = 5;
//xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
//xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx MAIN-FUNCTIONS xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
//=====================================SETUP============================
  //---------------MIDI SETUP--------------
  MIDI.begin(10);
  MIDI.setHandleNoteOn(HandleNoteOn);
  //---------------PIN MODES---------------
  pinMode( snare1, OUTPUT );
  pinMode( snare2, OUTPUT );
  pinMode( bass,   OUTPUT );
  pinMode( cymbal, OUTPUT );
  pinMode(LED_BUILTIN, OUTPUT);
  //---------------RUN TEST---------------
  Test(); //test solenoids at start
//======================================LOOP============================
  MIDI.read();
//xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx SUB-FUNCTIONS xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
//===============================HandleNoteOn===========================
  switch (pitch) {
      if(snareStick = 1){
        Hit(snare1);
      else{
        Hit(snare2);
    case 35://----------------------Bass = B1/35
      Hit(bass);
    case 44://----------------------Cymbal = G#2/44
      Hit(cymbal);
    default:
//=================================== Hit ===================================
void Hit(int drum) {
  digitalWrite(drum, HIGH);       //turn solenoid on
  delay(hitDur);                  // wait
  digitalWrite(drum, LOW);        //turn solenoid off
//================================== Test ===================================
void Test() {   //for debugging
  Hit(snare1);    delay(400);
  Hit(snare2);    delay(400);
  Hit(bass);      delay(400);
  Hit(cymbal);    delay(400);
Thanks for your help!
Single = is the assignment operator, double == is the equality comparison operator.
The compiler should have warned you about this: if it didn't, go to the Arduino IDE preferences and enable all compiler warnings.
Sure enough, it works now!
Of course it would be a simple syntax error. Thanks for letting my know about the compiler settings!
Not a syntax error. Those cause the compiler to complain and stop the compilation. It is a logic error. You meant to do a comparison, but did an assignment instead. Both perfectly valid but vastly different.
A chance to illustrate what problems this can cause:-
Thanks to @Delta_G
