VarSpeedServo - a modified Servo library with speed control
Attached to this message is the library VarSpeedServo, a modified version of the Servo library with one additional function slowmove() which is a replacement of write with an additional speed parameter.
Speed=0: Write is used, full speed
Speed=1: Slowest
Speed=255: Fastest. With the servos I have, with values above 127 I couldn't see any difference to write because the mechanical speed of the servo was the limiting factor.
Everything that works with Servo works with VarSpeedServo too. Important: Don't use Servo.h and VarSpeedServo.h at the same time, it will create conflicts.
Example:
#include <VarSpeedServo.h>
VarSpeedServo myServo;
myServo.attach (mainPin, ServoMin, ServoMax);
myServo.slowmove (newpos, speed);
Have fun with it.
Korman
VarSpeedServo.zip (7.91 KB)
Thank you. Saved me reinventing that particular wheel. Well, I already did it, but this is more elegant. To Be Tested ]:slight_smile:
Very nice addition, good work!
Shouldn't it be just added to the servo lib?
Or be a derived class from Servo?
Speed=1: Slowest
Would it be more natural to let speed go from 1-100% ? Granularity is not as fine, but maybe fine enough?
just thinking out loud,
Rob
I thought about this, but in the end I didn't find any useful measure for the speed, as the actual movement speed of the servo is unknown. 50% or 1% wouldn't match the reality either, so I just went with one byte speed indicator as compromise between data overhead in the Servo-library, processing overhead in the interrupt function and granularity for the speed regulation. It was good enough for what I needed - lowering model aircraft landing gears in a realistic manner.
Korman
Hi there,
Looks like this library would be the solution to my problem.
So I downloaded the library, installed it and created the following code:
VarSpeedServo servo1;
VarSpeedServo servo2;
  servo1.attach(9);
  servo2.attach(10);
  Serial.begin(19200);
  Serial.println("Ready");
  static int v = 0;
  if ( Serial.available()) {
    char ch = Serial.read();
    switch(ch) {
	case '0'...'9':
	  v = v * 10 + ch - '0';
	case 'R':
	  servo1.slowmove(v,50);
	  v = 0;
	case 'L':
	  servo2.write(v);
	  v = 0;
        case 'Z':
          servo1.write(90);
          servo2.write(90);
But it gives the following error when compiling:
cameraCodeArduino.cpp.o: In function `__static_initialization_and_destruction_0':
C:\Users\s070099\AppData\Local\Temp\build7343566564887365634.tmp/cameraCodeArduino.cpp:6: undefined reference to `VarSpeedServo::VarSpeedServo()'
C:\Users\s070099\AppData\Local\Temp\build7343566564887365634.tmp/cameraCodeArduino.cpp:7: undefined reference to `VarSpeedServo::VarSpeedServo()'
cameraCodeArduino.cpp.o: In function `loop':
C:\Users\s070099\AppData\Local\Temp\build7343566564887365634.tmp/cameraCodeArduino.cpp:29: undefined reference to `VarSpeedServo::slowmove(int, unsigned char)'
C:\Users\s070099\AppData\Local\Temp\build7343566564887365634.tmp/cameraCodeArduino.cpp:33: undefined reference to `VarSpeedServo::write(int)'
C:\Users\s070099\AppData\Local\Temp\build7343566564887365634.tmp/cameraCodeArduino.cpp:38: undefined reference to `VarSpeedServo::write(int)'
C:\Users\s070099\AppData\Local\Temp\build7343566564887365634.tmp/cameraCodeArduino.cpp:39: undefined reference to `VarSpeedServo::write(int)'
cameraCodeArduino.cpp.o: In function `setup':
C:\Users\s070099\AppData\Local\Temp\build7343566564887365634.tmp/cameraCodeArduino.cpp:10: undefined reference to `VarSpeedServo::attach(int)'
C:\Users\s070099\AppData\Local\Temp\build7343566564887365634.tmp/cameraCodeArduino.cpp:11: undefined reference to `VarSpeedServo::attach(int)'
I have no idea how to solve this, do you have any idea what's going wrong here?
Thanks in advance
I would have guessed the including didn't work properly. Did you place the library in the proper directory and import it as described here: Libraries - Arduino Reference
Korman
Hi Korman,
Yes, I have placed it correctly and it shows up in my Arduino, Sketch -> Import Library... -> VarServoSpeed. Imported it from there as well
Using Arduino 0022 btw, on Windows 7 computer.. maybe does that make any difference?
Ah never mind
Typo somewhere. Testing it now and it works fine! Thanks so much!
I have just come across this, nice job Korman.
Do you think this is a capability I should add to the core Servo library?
BTW, I posted an example sketch using this library here: Simultaneous but different servo sweeps with four servos - #12 by mem - Robotics - Arduino Forum
Hi Mem,
it's nice to know, that you like it. Whether to add it to the main Servo-library should be considered carefully. From my point of view, you're welcome to add the code or any modification from it. However, please consider a few things first:
  • The speed control adds more memory to the servo structure. It's just a few bytes, but in large setup with many servos, you should check if this causes problems
  • The speed parameter doesn't relate to any real time measure. It's just a number and you can set some speeds but others not. For many applications, like moving something at a pleasant speed to look at, this is good enough. If some specific speeds are necessary, the model I used might not offer enough granularity.
  • I didn't really check if the interaction of the position update and attach/detach works in a reasonable manner. What happens if one detaches the servo while on a slow move and then reattaches it?
  • The method-name slowMove is clumsy and not really in line with the rest of the rest of the methods
  • The spectrum of the available speeds isn't well used. Out of the speed byte, values above 128 are usually to fast to make visible differences because of the limits of the motor speed itself. I would like it improve this, but then I'd need more bits for the ticks parameter. If the memory isn't a problem, adding a byte to the tick counter will give more slower speeds. I think, it should also be considered what kind of speeds are going to be used most.
  • Some proper documentation and samples are also necessary.
In short, it was mostly a quick hack to get landing gears on model aircraft extend and retract at a more more realistic pace. Going by the general feedback, it seems to be of use for some applications. If you think part of my work is useful to be added to the main library, feel free to go ahead.
Korman
Korman:
Hi Mem,
Korman
Hi Korman,
I agree with all your points. But this thread and the other one I linked below got me thinking about possibly adding a sweep function with user setable speed that I may be able to do using just one more byte of RAM per servo. I would be interested to hear if this is something that would be generally useful and will start a new thread to discuss this if enough people are interested.
To answer your question: I needed this kind of function, so I wrote the extension. From time to time, questions about moving things slowly come up, mostly for visual reasons. I think having such a function in the servo library would be a good idea if the library doesn't suffer from it.
NB: I added one more point about the speed control to my previous message.
Korman
I am interested to know if adding variable speed sweep would be good enough for most applications? Most of the additional RAM needed in VarSpeedServo is for the target position, but this is not needed if the sweep is between the min and max positions set in the attach method because only the speed and current direction need to be stored and these can be held in a single byte if the max speed is limited to 127.
Would something like that be useful or will most people want the capability to control speed when moving the servo to any given?
I am not "most people", despite my inflated ego :slight_smile: But as you see from my reply earlier, I would have found that usefull.
My sweep used a millis() timer construct. For me - not a big hassle to program, but I know from many of the threads here, that it will be too much for many people to "do more than one thing" (ie let the sweep progress without disturbing other processing.) As I do not (yet) have any experience in accessing the hardware timers I do not know how much hassle it is to add that in the timer/interrupt code - or if it would limit the max number of servos.
(My sweep code has an advantage that I can do something synchronized with two servos. In an built in function one would need to change the sweep rate for each "ratio".)
The alternative is to let the sweep be "blocking", ie calling servo.write with asweep value will take the time it takes. I would not like a servo.updatesweep() to be called "often" for the sweep to work.
Msquare:
What do you mean by the ratio? Perhaps you can say more about the functionality.
I don't want to hijack this thread so I have created a new thread here: http://arduino.cc/forum/index.php/topic,68474.0.html
Gday all
just a quick question, just recently started with arduino and i am having trouble woth the VarSpeedServo library and slowmove.
Is there anywhere where it has been incorporated with a sweeep sketch to provide sweep at various speeds?
Thanks for the time, I could not find anything anywhere else
Cheers
Rick
There might be one, you'd have to check. Here's the test-code I use for this library. It should be fairly simple to extend.
	ServoFollowPot
	This little program controls a servo with a potentiometer.
	The button moave the servo from one end to the other, the potentiometer
	sets the speed. 0 = full speed, 1 slowest, 255 fastest.
	When pressing the button, the led is turned on to exercise it a little.
	Every few seconds the current postion of the servos is reported on the
	serial line and whenever the button is pressed.
 The circuit:
	* LED attached from pin 13 to ground: Button led
	* Pushbutton attached to pin 2 from GND
	* Linear Potentiometer attached to analog pin 2 from GND and +5V acting
	  as a voltage splitter. Any value from 10 kOhm to 100 kOhm will work.
	* Servo control line attached to pin 12.
 * Note: on most Arduinos there is already an LED on the board
 attached to pin 13.
const int buttonPin = 2;	// the number of the pushbutton pin
const int ledPin =  13;	// the number of the LED pin
const int potPin =  16;	// the number of the potentiometer pin (Analog 0)
const int mainPin = 12;	// Main servo control line
const int ServoMin = 1000;	// Minimum pulse width for servos in ms.
const int ServoMax = 2000;	// Maximum pulse width for servos in ms.
const int PotiMin = 0;	// Minimum value read from potentiometer
const int PotiMax = 1023;	// Maximum value read from potentiometer
const int ButtonDelay = 100;	// Time in ms to press button to activate tuning mode
VarSpeedServo myServo;	// Servo
	// initialize the LED pin as an output:
	pinMode(ledPin, OUTPUT);
	// initialize the pot and button pin as an input:
	pinMode(potPin, INPUT);
	pinMode(buttonPin, INPUT);
	// Activate internal pull up resistor for tuning button
	digitalWrite(buttonPin, HIGH);
	// Initialise Servos
	// Initialise Serial communication
	Serial.begin (9600);
	static unsigned long debounce = 0;         // variable for reading the pushbutton status
	static int buttonstate = HIGH;         // variable for reading the pushbutton status
	static unsigned long lasttick;
	// Report position;
	if (millis () - lasttick > 5000) {
		lasttick = millis ();
		Serial.print ("Position=");
		Serial.println (myServo.readMicroseconds());
	// Read button and debounce.
	int buttonnow = digitalRead(buttonPin);
	if (millis() - debounce >= ButtonDelay
		&& buttonnow != buttonstate) {
		buttonstate = buttonnow;
		debounce = millis();
		switch (buttonstate) {
			case LOW:
				// Button has just been pressed
				digitalWrite(ledPin, HIGH);
				// Set the servos
				int potlast = analogRead (potPin);	// Read potentiometer
				int speed = map (potlast, PotiMin, PotiMax, 1, 256) & 0xff;
				myServo.slowmove ((myServo.readMicroseconds() > ServoMin + 400
					? ServoMin + 100 : ServoMax - 100), speed);
				// Report pot position
				Serial.print ("Speed=");
				Serial.println (speed);
			case HIGH:
				// Button has just been released
				digitalWrite(ledPin, LOW);
	// Slow down
	// delay (50);
Korman
Hi, Great work on this!
Question: would this work as acceleration control on continuous-rotation servos?? Newpos sets top speed, speed sets acceleration?
terryking228:
Terry, it well could be, but to be honest I don't know. The library just increases continuously the position of the target until the set target value is reached. The consequence is that the PWM pulse increases or decreases in length over time. If the speed on continuous rotation servos is the same as the position for a regular servo, the speed parameter would be the acceleration.
Perhaps someone with access to such a servo could try that out?
Korman
Hi Korman,
I have a small 2-wheel robot that I will try it on. Maybe be a day+ as I'm busy with The Work Thing..
If it's dynamically changing the POS value, that should work. Within a reasonable range, Continuous-Rotation servos speed is proportional to the POS offset from 90 in both directions...
