Vending Machine Control
I have messed with a Maestro controller before but not an Arduino yet, I want to be able to put vending machines on wireless networks so I assume I would need an Arduino of some sort then a WiFi shield (possibly aftermarket) with an external antenna standoff so that I can use a directional antenna. These machines vend beverages and snacks so knowing what has been sold when and what is running low helps me a lot, with Arduino channels wired to the vending slot motors it will give me statistics and I should be able to wire a webcam or two to the Arduino if I wanted to mount them to the machine right?
What would I need how much hardware cost am I talking per machine? Thanks
Arduino will not do video like webcams, too light for that.
It all depends on the interfaces the vending machines offer.
Can you post the specification?
If you don't have a spec, the answer is guessing.
Thanks for the reply, I guess you can say guessing for now. I wanted to possibly tap into this 1 of 2 ways, snack machines have a motor that spins a coil and soda machines work in a similar fashion with a relay. So either tap into it before the relay or at the motor itself and use a resistor to bring the power back down for a low voltage lead to a channel on the Arduino.
Once I have a system down implementing these will be really easy into all sorts of machines.
This is how I assume vending machines work drinks or snacks, there is a low voltage analog signal from the touch-pad board or button that goes to a relay, which allows more power to a vending motor be that to spin a coil or release a beverage (negatives most likely grounded) .
This is the first of two ways the simple link to an Arduino can be made, this one being a definite at last choice I would say. The Arduino channels need a digital PWM pulse signal to operate I believe so an LM-IC chip is needed between the motor and Arduino channels to convert the signal, assuming the machines operate on 12V motors I would also need a resistor since both the converter and Arduino operate on I believe 5V.
This is the more preferred way staying on the low voltage side if possible, everything stays the same minus a resistor and working with most likely 5V. Now there are aftermarket WiFi boards for the Arduino such as the red one with a standoff for an external antenna which will be useful for something like an omnidirectional bi-quad WiFi antenna. Does anyone want to chime in on my electrical theory? Like I said I am still going to tinker with prototypes because granted you are all intimidated by the approach and setup of an internet connection on these machines I take it as a challenge and it only gets easier and easier every year, once established its 100% free unlimited live monitoring and even remote control functions such as individual rack or coil lockout/reset/power/etc.
