TL/DR - I want to verify that these two phoenix connectors can handle high voltage (110V - standard household voltage, with <= 4 amps):
- https://media.digikey.com/pdf/Data%20Sheets/Phoenix%20Contact%20PDFs/1757608.pdf
- https://media.digikey.com/pdf/Data%20Sheets/Phoenix%20Contact%20PDFs/1754724.pdf
The relay I'm planning to use is this: https://www.digikey.com/products/en?keywords=CPC1965G
I realize this may be a stupid question because the datasheets clearly say the phoenix connectors support well over 110V and over 10A. But with high voltage I figure better safe than sorry and people here might have best practices.
Project overview: I'm using a NodeMCU to act as a wifi interface to turn on and off a set of outlets into which I will plug in decorative lights. My friend built a version of this using XBee years ago and I'm upgrading it to be usable via WiFi with a node MCU.
More detail:
I have 110V coming into the PCB to a 2 port phoenix connector, then going through a relay as you can see in the schematic. The NodeMCU is powered via 5V and then reads settings from an 8-dipswitch, and uses an I2C IO expander. It turns the relays on and off according to signals.
