Very easy to use stand-alone exe-file flash-tool for flashing *.BIN-files to ESP8266 Wemos D1 mini / ESP8266 nodeMCU
Hi everybody,
does somebody know a flash-tool for flashing *.bin-files into ESP8266 / ESP32 that is as easy to use as
to
not install Arduino-IDE with additional board-URL
only do
  • connect USB-cable
  • start flash-tool.exe
  • choose comport
  • choose *.bin-file
  • click flash
    done
I'm aware of the fact that ESP8266/ESP32-boards can be made with different clock-frequency and different flash-ROMsize.
So my question is a tool for "standard" ESP8266 Wemos D1 Mini or ESP8266 nodeMCU
and / or "standard" nodeMCU ESP32-boards
What I have found so far is much more complicated.
If the firmware does not include any kind of OTA a *.bin-file can't be uploaded by OTA.
This means it must be done by USB-cable
best regards Stefan
Here they talk about a "Flash Download Tool" that can be used to upload BIN files. Maybe his is of any use to you?
esptool.py is the right tool
it is just
esptool.py write_flash @download.config
where download.config is a file provided together with the binaries
No it is not. This is one of the tutorials that explains the 50 steps how to configure the standard ESP-flash-tool which is the opposite of
only do
connect USB-cable
choose comport
choose *.bin-file
click flash
done
this requires to
  • install python. because esptool.py is a python-script
  • learn where download.config is located
If I look up the folder with the *.bin-file I only see
But I have found now such a tool myself
for windows it is this file
https://github.com/marcelstoer/nodemcu-pyflasher/releases/download/v5.0.0/NodeMCU-PyFlasher.exe
best regards Stefan
