Hello, I just started thinking about a project and I need a very large distance sensor, The project it's about a "GPS gun" Its function is tell me the GPS coordinates, altitude and distance where I'm aiming. I will need a GPS module, a gyrocope, an OLED screen and the distance sensor. I can get all the data I need with a bit of trigonometry.
The problem starts looking for distance modules, there is one called LIDAR-Lite but is very expensive and only reaches 40m. Also I need that be a handheld device so it can't be so big. Ideas?
Henradrie:
You might want an accelerometer as well. Gyroscopes tend to wander as they are not fixed to any reference such as gravity or magnetic field.
If orientation is what you want to measure then magnetometers and accelerometers would be better options.
And still the question remains unanswered: how long is "very long"?
I want that to reach 100m or more, a distance that isn't easy to reach by walking, and if I get a commercial laser rangefinder and I put the data manually into the arduino it won't as efficient as I want, I want that to be fast and very straightforward
hi i added to this post, iam looking for a large range proximity sensor for arduino. the idea is detect car proximity suficient enough to stop.
i thing 100mts should be enough.
is there such a sensor.
Thanks
mako1978:
Thanks
mako
100 metres maximum, or 100 metres minimum?
In what environment?
Was it really necessary to necro a three year old thread?
