vibrating servos,erratic movements
Hi
I have looking through many posts, with similar problems but I think that my problem is a bit different...
I will explain to you the wiring
I have 3 servos like this one
3 signals to 3 digital arduino pins
A 7.4V and 2200 mAh battery, powering directly the three servos.
Besides, the battery goes to the Vin pin and ground of my arduino.
I just want to move the three servos together
My code is:
#include <Servo.h>
// Variables estáticas
Servo servoc1;
Servo servoc2;
Servo servoc3;
// Variables dinámicas
 servoc1.attach(4); //servo derecha
 servoc2.attach(5); // servo izquierda
 servoc3.attach(6); //servo arriba
   servoc1.write(50);
    servoc2.write(50);
     servoc3.write(50);
   delay(2000);
    servoc1.write(110);
     servoc2.write(110);
      servoc3.write(110);
   delay(2000);
My problem is that servos moves erratic, it moves from one to another position, but sometimes during the delay they move like vibrating, other times the movement from 50 to 110 happens in two steps, like if it goes to 80 and then to 110.
Sometimes they move fine...but those are the less.
I don't know where is the problem... I tried powering just one servo... and the problem is thesame...
Any ideas? Thanks
You shared GND between Arduino and servos?
try just putting the battery on the breadboard rails and sharing arduinos ground with it.
It is shared...
GND of the servos goes to a switch
GND of the arduino goes to a switch
Switch goes to the battery gnd
I thought an option could be having two different batteries... one for arduino and othe rfor the servos... But it doesn't seem logic
Why are you switching gnd?
Can you please post a picture of your project?
What model arduino are you using?
Do you have a DMM?
Thanks.. Tom.. :slight_smile:
Sorry about my drawing skills...
This is how I did the wiring
I think that the code is ok, so ... it has to be or a problem on how I did the wiring, or malfunction servos...
Thanks in advance
What size wire are you using?
Do you have a DMM to measure the battery voltage while you move the servos.
Are you batteries charged?
Please put the switch in the positive wire of the battery, instead of the gnd.
It is a standard that everybody uses and ensures that interconnection with other equipment will be reliable.
Connect ALL gnds together at the battery terminal.
