I've got a school project and I need to find a way to program receiving a high enough input from a vibration sensor to take a photo immediately, then a minute after that and one the following minute after that (and to upload it all to google drive and maybe).
Well the actual task is to design a method a project that can help aid in solving rural crimes (e.g. theft of livestock) with the bulk of the task being a report we have to write on the design and other things (this part is only a small bit).
Our teacher said we have to design something on the scale/complexity like this however has not reached us any audino code or really much to do with audinos. I asked if he could help us but he said he couldn't but instead we should check on the internet.
And what we are meant to learn about is design thinking and the design process (the class is STEM) of solving real-life issues using engineering. And also the main part is actually reflecting on the idea (not creating it)
This would probably be an ideal job for an ESP32CAM module (although it would need to have wifi access to upload to a google drive unless you attached a GSM module and did it via the cellphone network)
A 'sw-420' mercury switch module would be the easiest way to do vibration sensing, with these you can set a threshold above which it triggers.
here is the outline of a state machine that does what you want:
const byte sensorPin = 2;
const byte ledAlertPin = LED_BUILTIN;
unsigned long startTime;
const unsigned long timeBetweenPictures = 60000ul; // ∆t between pictures = 1 minute in ms
enum : byte {NOMINAL, ALERT_PICTURE_TWO, ALERT_PICTURE_THREE, WAIT_ALERT_END} currentState;
void takePictureAndUplaod(int pictureNumber)
Serial.print(F("Taking and uploading picture #"));
Serial.println(pictureNumber);
// returns true if alert is triggered
bool alert() {
return (digitalRead(sensorPin) == LOW); // simulate alert triggering with a button
void alertManagement() {
switch (currentState) {
case NOMINAL:
if (alert()) { // alert triggered
Serial.println(F("*** ALERT ***"));
digitalWrite(ledAlertPin, HIGH); // turn the alert LED ON (or whatever is on that pin)
startTime = millis();
takePictureAndUplaod(1);
currentState = ALERT_PICTURE_TWO;
case ALERT_PICTURE_TWO:
if (millis() - startTime >= timeBetweenPictures) {
takePictureAndUplaod(2);
currentState = ALERT_PICTURE_THREE;
case ALERT_PICTURE_THREE:
takePictureAndUplaod(3);
currentState = WAIT_ALERT_END;
case WAIT_ALERT_END:
if (!alert()) {
Serial.println(F("*** END OF ALERT ***"));
digitalWrite(ledAlertPin, LOW); // turn the alert LED OFF (or whatever is on that pin)
currentState = NOMINAL;
pinMode(ledAlertPin, OUTPUT);
pinMode(sensorPin, INPUT_PULLUP); // will go low when alert triggered (simulated with a button)
Serial.println(F("*** MONITORING ACTIVATED ***"));
alertManagement();
The state machine is pretty simple to read. We start in state NOMINAL
we wait for an alert to be triggered, in which case we take picture #1 and go to next state
timeBetweenPictures ms later we take picture #2 and go to next state
timeBetweenPictures ms later we take picture #3 and go to next state
where we await until the alert signal to be turned off and we start over
if you run it Serial Monitor (@ 115200 bauds) will show (here I triggered twice)
*** ALERT ***
Taking and uploading picture #1
Taking and uploading picture #2
Taking and uploading picture #3
*** ALERT ***
you will have to provide code for
the setup() to configure correctly your system
write the alert() function so that it really reads your sensor
write the takePictureAndUplaod() function so that it really takes a picture and upload to GDrive
