Hi Team,
In this post regarding VL6180x proximity sensor, the sensor is detecting the address(0x29) but the readings are receiving as 255 value even the object it detected in front of sensor. for reference purpose go through this code snippet wrote in arduino IDE for ESP32-WROVER-IE.
What might be the problem?
Regards,
#include <Wire.h>
#include "Adafruit_VL6180X.h"
#define SDA 23
#define SCL 22
Adafruit_VL6180X vl;
Serial.println("Starting I2C...");
Wire.begin(SDA, SCL);
delay(100);
Serial.println("VL6180X test");
if (!vl.begin()) {
Serial.println("Failed to find VL6180X");
while (1);
Serial.println("VL6180X found!");
//Serial.println("hi");
uint8_t range = vl.readRange();
uint8_t status = vl.readRangeStatus();
// if (status == VL6180X_ERROR_NONE) {
Serial.print("Range: ");
Serial.println(range);
//delay(500);
