Hello Guys,
I am new to arduino... I wante dto make a voice controlled RC car using arduino.... I followed tutorial on the internet,.... According to the tutorial i desoldered the RX-2B IC from RC car and soldered wires on the pins 2,6,7,10,11... I connected the Pin 2 to GND on the arduino , Pin 6 to Pin 9 on the arduino, Pin 7 to Pin 10 on the arduino and Pin 10 to Pin 11 on the arduino and Pin 11 to Pin 12 on the arduino..... I use a HC-06 bluetooth module to connect the arduino to my android phone.... I connected the VCC to +5V on the Arduino, Tx-->RX and RX-->TX and GND to GND on the power section of the arduino.... I use this app to send commands https://play.google.com/store/apps/details?id=robotspace.simplelabs.amr_voice&hl=en
Here is my code:
#include<SoftwareSerial.h>
SoftwareSerial BT(1,0); //RX,TX
String readvoice; // To read data from Android
BT.begin(9600);
pinMode(9,OUTPUT);
pinMode(10,OUTPUT);
pinMode(11,OUTPUT);
pinMode(12,OUTPUT);
void loop ()
while(BT.available()) //To check if there is any data from HC-05 BM
{ delay(10); //Delay to avoid unstable data reads
char c=BT.read(); // To read
readvoice +=c; // To make strings
if(readvoice.length()>0)
Serial.println(readvoice);
if(readvoice=="*forward#")
digitalWrite(9,HIGH);
digitalWrite(10,LOW);
digitalWrite(11,LOW);
digitalWrite(12,LOW);
delay(7000);
digitalWrite(9,LOW);
else if(readvoice=="*backward#")
digitalWrite(10,HIGH);
delay(3000);
else if(readvoice=="*forward left turn#")
digitalWrite(11,HIGH);
delay(5000);
else if(readvoice=="*forward right turn#")
digitalWrite(12,HIGH);
delay(3000);
else if(readvoice=="*reverse left turn#")
delay(5000);
else if(readvoice=="*reverse right turn")
delay(5000);
else if(readvoice=="*stop#")
I can connect to the HC-06 send commands but nothing seems to work..>! PLs help... How do I know if the bluetooth module is receiving data correctly from the app...>?
P.S: I included the '*' at the beginning of the each command and '#' at the end of each command bcos it was said to do so by the developer....!
Pls help....
I just got 2 more days to submit my project...
