VrtualwWre.h and Servo.h using same Timer1..
Hi, I'm a newbie in these stuffs.I want to use VirtualWire and Standard Servo library in the same sketch,But they both use Timer1,I tried ServoTimer2.h(Slow refreshing) but didn't solved my problem. Please help me. Thanks..
If ServoTimer2 uses timer2 and VirtualWire uses timer1, then there must be something else at fault. If you need help you will need to provide full details (your code, the actual versions of each library). And a lot more detail than "didn't solve my problem".
I’m sorry about that.
Here is the code that i’m working on…
#include <VirtualWire.h>
#include <ServoTimer2.h>  // the servo library
// define the pins for the servos
#define rollPin  2
#define pitchPin 3
#define yawPin   4
ServoTimer2 servoRoll;    // declare variables for up to eight servos
ServoTimer2 servoPitch;
ServoTimer2 servoYaw;
const int receive_pin = 11;
  vw_set_rx_pin(receive_pin);
  vw_setup(2000); // Bits per sec
  vw_rx_start();       // Start the receiver PLL running
  servoRoll.attach(rollPin);     // attach a pin to the servos and they will start pulsing
  servoPitch.attach(pitchPin);
  servoYaw.attach(yawPin);
// this function just increments a value until it reaches a maximum
int incPulse(int val, int inc) {
  if ( val + inc  > 2000 )
    return 1000 ;
    return val + inc;
  int val;
  val = incPulse( servoRoll.read(), 1);
  servoRoll.write(val);
  val =  incPulse( servoPitch.read(), 2);
  servoPitch.write(val);
  val = incPulse(servoYaw.read(), 4);
  servoYaw.write(val);
  delay(10);
And here is the error what i’m getting…
Arduino: 1.6.3 (Windows 7), Board: "Arduino Uno"
In file included from sketch_apr09a.ino:3:0:
C:\Program Files (x86)\Arduino\libraries\ServoTimer2/ServoTimer2.h:41:17: error: conflicting declaration 'typedef uint8_t boolean'
 typedef uint8_t boolean;
In file included from C:\Program Files (x86)\Arduino\libraries\VirtualWire/VirtualWire.h:146:0,
                 from sketch_apr09a.ino:1:
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Arduino.h:117:14: error: 'boolean' has a previous declaration as 'typedef bool boolean'
 typedef bool boolean;
Error compiling.
  enabled in File > Preferences.
Here is the ServoTimer2.h
 ServoTimer2.h - Interrupt driven Servo library for Arduino using
 This library uses Timer2 to drive up to 8 servos using interrupts so no refresh activity is required from within the sketch.
 The usage and method naming is similar to the Arduino software servo library http://www.arduino.cc/playground/ComponentLib/Servo
 except that pulse widths are in microseconds.
 A servo is activated by creating an instance of the Servo class passing the desired pin to the attach() method.
 The servo is pulsed in the background to the value most recently written using the write() method
 Note that analogWrite of PWM on pins 3 and 11 is disabled when the first servo is attached
 The methods are:
  ServoTimer2 - Class for manipulating servo motors connected to Arduino pins.
  attach(pin )  - Attaches a servo motor to an i/o pin.
  attach(pin, min, max  ) - Attaches to a pin setting min and max values in microseconds
   default min is 544, max is 2400
  write()     - Sets the servo pulse width in microseconds.
  read()      - Gets the last written servo pulse width in microseconds.
  attached()  - Returns true if there is a servo attached.
  detach()    - Stops an attached servos from pulsing its i/o pin.
The library takes about 824 bytes of program memory and 32+(1*servos) bytes of SRAM.
The pulse width timing is accurate to within 1%
// ensure this library description is only included once
#ifndef ServoTimer2_h
#define ServoTimer2_h
#include <inttypes.h>
typedef uint8_t byte;
#define MIN_PULSE_WIDTH       750        // the shortest pulse sent to a servo
#define MAX_PULSE_WIDTH      2250        // the longest pulse sent to a servo
#define DEFAULT_PULSE_WIDTH  1500        // default pulse width when servo is attached
#define FRAME_SYNC_PERIOD   20000        // total frame duration in microseconds
#define NBR_CHANNELS 8                   // the maximum number of channels, don't change this
typedef struct  {
     uint8_t nbr        :5 ;  // a pin number from 0 to 31
     uint8_t isActive   :1 ;  // false if this channel not enabled, pin only pulsed if true
  } ServoPin_t   ;
typedef struct {
 ServoPin_t Pin;
 byte counter;
 byte remainder;
}  servo_t;
class ServoTimer2
 public:
     // constructor:
     ServoTimer2();
     uint8_t attach(int);     // attach the given pin to the next free channel, sets pinMode, returns channel number or 0 if failure
                              // the attached servo is pulsed with the current pulse width value, (see the write method)
     uint8_t attach(int, int, int); // as above but also sets min and max values for writes.
   void detach();
   void write(int);         // store the pulse width in microseconds (between MIN_PULSE_WIDTH and MAX_PULSE_WIDTH)for this channel
   int read();                    // returns current pulse width in microseconds for this servo
     boolean attached();      // return true if this servo is attached
private:
      uint8_t chanIndex;      // index into the channel data for this servo
// the following ServoArrayT2 class is not implemented in the first version of this library
class ServoArrayT2
 public:
     // constructor:
     ServoArrayT2();
                              // channels are assigned consecutively starting from 1
   void detach(int);        // detach the servo on the given channel
     void write(int,int);     // store the pulse width in microseconds (between MIN_PULSE_WIDTH and MAX_PULSE_WIDTH)for the given channel
   int read(int);                    // returns current pulse width in microseconds for the given channel
     boolean attached(int);   // return true if the servo on the given channel is attached
private:
#endif
and here is ServoTimer2.cpp
/* ServoTimer2.cpp*/
extern "C" {
 // AVR LibC Includes
 #include <avr/interrupt.h>
 #include "WConstants.h"
#include <wiring.h>
#include "ServoTimer2.h"
static void initISR();
static void writeChan(uint8_t chan, int pulsewidth);
#define FRAME_SYNC_INDEX   0             // frame sync delay is the first entry in the channel array
#define FRAME_SYNC_DELAY   ((FRAME_SYNC_PERIOD - ( NBR_CHANNELS * DEFAULT_PULSE_WIDTH))/ 128) // number of iterations of the ISR to get the desired frame rate
#define DELAY_ADJUST       8             // number of microseconds of calculation overhead to be subtracted from pulse timings
static servo_t servos[NBR_CHANNELS+1];    // static array holding servo data for all channels
static volatile uint8_t Channel;   // counter holding the channel being pulsed
static volatile uint8_t ISRCount;  // iteration counter used in the interrupt routines;
uint8_t ChannelCount = 0;          // counter holding the number of attached channels
static boolean isStarted = false;  // flag to indicate if the ISR has been initialised
ISR (TIMER2_OVF_vect)
 ++ISRCount; // increment the overlflow counter
 if (ISRCount ==  servos[Channel].counter ) // are we on the final iteration for this channel
     TCNT2 =  servos[Channel].remainder;   // yes, set count for overflow after remainder ticks
 else if(ISRCount >  servos[Channel].counter)
     // we have finished timing the channel so pulse it low and move on
     if(servos[Channel].Pin.isActive == true)           // check if activated
         digitalWrite( servos[Channel].Pin.nbr,LOW); // pulse this channel low if active
       Channel++;    // increment to the next channel
     ISRCount = 0; // reset the isr iteration counter
     TCNT2 = 0;    // reset the clock counter register
     if( (Channel != FRAME_SYNC_INDEX) && (Channel <= NBR_CHANNELS) ){           // check if we need to pulse this channel
            digitalWrite( servos[Channel].Pin.nbr,HIGH); // its an active channel so pulse it high
     else if(Channel > NBR_CHANNELS){
        Channel = 0; // all done so start over
ServoTimer2::ServoTimer2()
  if( ChannelCount < NBR_CHANNELS)
     this->chanIndex = ++ChannelCount;  // assign a channel number to this instance
     this->chanIndex = 0;  // todo      // too many channels, assigning 0 inhibits this instance from functioning
uint8_t ServoTimer2::attach(int pin)
     if( isStarted == false)
      initISR();
     if(this->chanIndex > 0)
      //debug("attaching chan = ", chanIndex);
      pinMode( pin, OUTPUT) ;  // set servo pin to output
      servos[this->chanIndex].Pin.nbr = pin;
      servos[this->chanIndex].Pin.isActive = true;
     return this->chanIndex ;
void ServoTimer2::detach()
   servos[this->chanIndex].Pin.isActive = false;
void ServoTimer2::write(int pulsewidth)
  writeChan(this->chanIndex, pulsewidth); // call the static function to store the data for this servo
int ServoTimer2::read()
 unsigned int pulsewidth;
  if( this->chanIndex > 0)
     pulsewidth =  servos[this->chanIndex].counter * 128 + ((255 - servos[this->chanIndex].remainder) / 2) + DELAY_ADJUST ;
      pulsewidth  = 0;
  return pulsewidth;
boolean ServoTimer2::attached()
   return servos[this->chanIndex].Pin.isActive ;
  // calculate and store the values for the given channel
  if( (chan > 0) && (chan <= NBR_CHANNELS) )   // ensure channel is valid
     if( pulsewidth < MIN_PULSE_WIDTH )                // ensure pulse width is valid
         pulsewidth = MIN_PULSE_WIDTH;
     else if( pulsewidth > MAX_PULSE_WIDTH )
         pulsewidth = MAX_PULSE_WIDTH;
       pulsewidth -=DELAY_ADJUST;                   // subtract the time it takes to process the start and end pulses (mostly from digitalWrite)
     servos[chan].counter = pulsewidth / 128;
     servos[chan].remainder = 255 - (2 * (pulsewidth - ( servos[chan].counter * 128)));  // the number of 0.5us ticks for timer overflow
     for(uint8_t i=1; i <= NBR_CHANNELS; i++) {  // channels start from 1
        writeChan(i, DEFAULT_PULSE_WIDTH);  // store default values
     servos[FRAME_SYNC_INDEX].counter = FRAME_SYNC_DELAY;   // store the frame sync period
     Channel = 0;  // clear the channel index
     ISRCount = 0;  // clear the value of the ISR counter;
     /* setup for timer 2 */
     TIMSK2 = 0;  // disable interrupts
     TCCR2A = 0;  // normal counting mode
     TCCR2B = _BV(CS21); // set prescaler of 8
     TCNT2 = 0;     // clear the timer2 count
     TIFR2 = _BV(TOV2);  // clear pending interrupts;
     TIMSK2 =  _BV(TOIE2) ; // enable the overflow interrupt
     isStarted = true;  // flag to indicate this initialisation code has been executed
I downloaded the virtualwire.h from this page…
https://www.pjrc.com/teensy/td_libs_VirtualWire.html
Thanks for the quick reply…
Try the latest version of VirtualWire.
I tried using it with standard Servo.h.
Here is th code
#include <VirtualWire_Config.h>
#include <Servo.h>
Now I’m getting this error
Servo\avr\Servo.cpp.o: In function `__vector_11':
C:\Program Files (x86)\Arduino\libraries\Servo\src\avr/Servo.cpp:81: multiple definition of `__vector_11'
VirtualWire\VirtualWire.cpp.o:C:\Program Files (x86)\Arduino\libraries\VirtualWire/VirtualWire.cpp:591: first defined here
collect2.exe: error: ld returned 1 exit status
Error compiling.
Why did you not try ServoTimer2?
Please see this post from the starting…
Please see this post from the starting.
Yes, and you are now back to the problem that VirtualWire and the standard servo library both use Timer1.
Yes,The same problem again, :disappointed_relieved: :disappointed_relieved: Please help me
Use ServoTimer2.
