VU METER lcd 20x4
D_K_VU_METER_MONO.ino (3,8 KB)
Hello, I have this code but I don't know how to make the bar appear on another line (4, 3) I would like to..
Thank you very much.
I moved your topic to an appropriate forum category @danykas.
In the future, when creating a topic please take some time to pick the forum category that best suits the subject of your topic. There is an "About the _____ category" topic at the top of each category that explains its purpose.
This is an important part of responsible forum usage, as explained in the "How to get the best out of this forum" guide. The guide contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
@danykas
you have one call to
drawBar(volL, leftPeak, 0);
this will write on row 0. Change that.
ok but i want to 4, 3 ?
what does it mean ? do you want the graph to be on line 4 and starts at the 3rd character?
3 line 4 haracter
First step, bring it to the correct line.
When you want a shorter bar, you need to adopt more code. The
My library - GitHub - RobTillaart/I2C_LCD: Arduino library for I2C LCD displays e.g. 20x4
has examples with VU bar’s both horizontal and vertical.
These include performance optimized code to only draw / wipe what is needed.
Be aware that if you start at position 4, your max length is 0..80 instead of 0..100.
So your math from zero to full throttle needs to be adjusted too.
// every character is 5 columns so 20 chars = 100 columns, and 16 chars = 80 columns.
I think you want the left channel on line zero, so the right channel can be on the last line.
The math to translate the potentiometer to an 18-character display still needs work, and it could be made more compact using functions.
// https://forum.arduino.cc/t/vu-meter-lcd-20x4/1403043
#include <LiquidCrystal.h>
byte Bar[8]          = {B11111, B00000, B11111, B11111, B11111, B11111, B00000, B11111};
byte L[8]            = {B00111, B01000, B10100, B10100, B10100, B10111, B01000, B00111};
byte R[8]            = {B00111, B01000, B10110, B10101, B10110, B10101, B01000, B00111};
byte EndMark[8]      = {B10000, B01000, B00100, B00100, B00100, B00100, B01000, B10000};
byte EmptyBar[8]     = {B11111, B00000, B00000, B00000, B00000, B00000, B00000, B11111};
byte peakHoldChar[8] = {B11111, B00000, B01110, B01110, B01110, B01110, B00000, B11111};
byte Smile1[8]       = {B00000, B00000, B00000, B00000, B00000, B00000, B10010, B00000};
byte Smile2[8]       = {B10010, B01100, B00000, B00000, B00000, B00000, B00000, B00000};
const int numReadings = 5;  //Refresh rate. Lower value = higher rate. 5 is the defaul
const int screenHeight = 4; // 4 rows
const int screenWidth = 20; // 20 columns
int left;                   //Variables to  store and calculate the channel levels
int indexL = 0;             //Actual channel index
int totalL = 0;             //Total  channel data
int maxL = 0;               //Maximal level
int inputPinL = A0;  //Input pin for LEFT  channel
int volL = 0;
int leftAvg = 0;
int leftPeak = 0;
int right;                   //Variables to  store and calculate the channel levels
int indexR = 0;             //Actual channel index
int totalR = 0;             //Total  channel data
int maxR = 0;               //Maximal level
int inputPinR = A1;  //Input pin for RIGHT  channel
int volR = 0;
int rightAvg = 0;
int rightPeak = 0;
long peakHoldTime = 1000;  //peak hold time in miliseconds
long peakHold = 0;
long decayTime = 0;
long actualMillis = 0;
LiquidCrystal lcd(12, 10, 5, 4, 3, 2);  //lcd configuration
  lcd.begin(20, 4);  //Setting up LCD. 16 chars and 2 rows
  lcd.createChar(1, Bar);
  lcd.createChar(2, L);
  lcd.createChar(3, R);
  lcd.createChar(4, EmptyBar);
  lcd.createChar(5, EndMark);
  lcd.createChar(6, peakHoldChar);
  lcd.createChar(7, Smile1);
  lcd.createChar(8, Smile2);
  drawLeftChannels();
  decayTime = millis();
void drawLeftChannels() {
  lcd.setCursor(0, 0);   //L channel index
  lcd.write(2);          //L  symbol
  lcd.setCursor(screenWidth / 2, screenHeight / 2 - 1);
  lcd.write(7);
  lcd.setCursor(screenWidth / 2, screenHeight / 2);
  lcd.write(8);
  lcd.setCursor(0, screenHeight - 1);   //R channel index
  lcd.write(3);          //R  symbol
  lcd.setCursor(screenWidth - 1, 0);  //closing tag / end mark index 1
  lcd.write(5);          //closing tag / end mark
  lcd.setCursor(screenWidth - 1, screenHeight - 1);  //closing tag / end mark index 1
  actualMillis = millis();
  // totalL = map(analogRead(inputPinL), 0, 1023, 1, screenWidth - 1);
  // totalR = map(analogRead(inputPinR), 0, 1023, 1, screenWidth - 1);
  totalL = analogRead(inputPinL);
  totalR = analogRead(inputPinR);
  if (totalL > maxL) {
    maxL = totalL;
  } indexL++;
  if (totalR > maxR) {
    maxR = totalR;
  } indexR++;
  if (indexL >= numReadings) {
    indexL = 0;
    left = maxL;
    maxL = 0;
  if (indexR >= numReadings) {
    indexR = 0;
    right = maxR;
    maxR = 0;
  volL = left / 2;
  if (volL > 18) {
    volL = 18;
  volR = right / 2;
  if (volR > 18) {
    volR = 18;
  if (volL < (leftAvg - 2)) {
    if (decayTime < actualMillis)
      leftAvg--;
    volL = leftAvg;
  } else if (volL > (leftAvg + 2)) {
    volL = (leftAvg + 2);
    leftAvg = volL;
    leftAvg = volL;
  if (volL > leftPeak) {
    leftPeak = volL;
  if (volR < (rightAvg - 2)) {
      rightAvg--;
    volR = rightAvg;
  } else if (volR > (rightAvg + 2)) {
    volR = (rightAvg + 2);
    rightAvg = volR;
    rightAvg = volR;
  if (volR > rightPeak) {
    rightPeak = volR;
  drawBar(volR, rightPeak, screenHeight - 1);
    decayTime = (millis() + 50);
  if (peakHold < actualMillis) {
    peakHold = (millis() + peakHoldTime);
    leftPeak -= 1;
    // leftPeak = -1;
    rightPeak -= 1;
void drawBar(int data, int peakData, int row) {
  if (peakData < 2) {
    peakData = -1;
  for (int col = 1; col < 19; col++) {
    lcd.setCursor(col, row);
    if (col < data) {
      lcd.write(1);
    } else if (peakData == col) {
      lcd.write(6);  //write the peak marker
      lcd.write(4);  //write  "empty"
