Is it possible to use Arduino to function my kitchen as in Wallace & Gromit ?
Thanks
Thanks
Hi, yes but only if you can find an Adruino made out of modelling clay.
PaulRB:
He could try using Wensleydale cheese instead.
lioonel_dg:
Do you want it to do something useful (if so, please tell us what that is)
OR
Do you want it to make you laugh?
...R
The Arduino UNO should be used as a Wallace but you can only use the Due as a Gromit.
Grumpy_Mike:
Yes. It's not possible to get a Uno into quadrupedal mode.
The level of complexity to ensure the correct trousers are fitted could prove too memory intensive to be implemented. This is a regular source of errors.
KenF:
And drop-outs, whilst the fly is being done up, are also likely to cause major problems.
The footwear can be applied with bootstrapping.
