Want to make a project but ideas are blank
Hi everyone! My name is Mikey. I have owned an Arduino for a while now and made some projects with it but I am out of inspiration!
here are the parts the I have
  • Real Time Clock Module
  • LCD I2C Display
  • some 8 Digit Display
  • Arduino Giga
  • Arduino Uno R3(x2)
  • UltraSonic Distance Sensor(x4)
  • Wires
  • RFID-522 Key card Sensor
  • ESP32
  • ESP8266
  • Bluetooth Module
  • HL-83 Rain Sensor
  • Arduino Giga Display
  • A Laptop(for coding)
  • DC Motor w/ Encoder(x2)
  • Servo
  • DC Motor(x2)
  • Door latch solenoid
  • Relays(x10)
  • Batteries
  • Nuts n' Bolts
  • Cardboard(for mounting)
  • MQ-3 Alcohol Sensor
  • Rocker Switch(x10)
  • Push Button(x20)
  • potentiometer(x2)
  • Buzzer(no idea how to use it)
  • IR Remote
  • IR receiver
  • FingerPrint Sensor
I hope all of you can help me find a project to make with these. I also have a budget of about $50 that I would be willing to spend on more supplies but generally I think I would like to make something with these. the buzzer that I listed earlier just clicks when I send power to it. I think I'm just sending to much but I'm not entirely sure!
Thanks you prior!,
Mikey
I have had 3 for a month and have ran out of ideas too! The projects in the kits got boring and project hub uses components I don't have.
With the buzzer you need to generate a frequency using the Arduino.
  • I made 5 of these a while back, quite useless.
not exactly what I'm looking for. I want something I can impress my friends with!
relatable!
Keep on your toes
Many of these <<<<. will involve USB, power supplies, battery holders, or power switching components. (transistors, FETs etc) to be used.
Choose carefully for voltage and current consideration.
Your teacher should have covered Voltage and Current in the first couple of classes.
I'm an electrical engineer for Microsoft. why would I have a teacher. I'm just getting started and want to know how...
here is my overcomplicated chasing led code if you want it.
  Blink
  Turns an LED on for one second, then off for one second, repeatedly.
  Most Arduinos have an on-board LED you can control. On the UNO, MEGA and ZERO
  it is attached to digital pin 13, on MKR1000 on pin 6. LED_BUILTIN is set to
  the correct LED pin independent of which board is used.
  If you want to know what pin the on-board LED is connected to on your Arduino
  model, check the Technical Specs of your board at:
  https://www.arduino.cc/en/Main/Products
  modified 8 May 2014
  by Scott Fitzgerald
  modified 2 Sep 2016
  by Arturo Guadalupi
  modified 8 Sep 2016
  by Colby Newman
  This example code is in the public domain.
  https://www.arduino.cc/en/Tutorial/BuiltInExamples/Blink
int LEDPIN1 = 1;
int LEDPIN2 = 2;
int LEDPIN3 = 3;
int LEDPIN4 = 4;
int LEDPIN5 = 5;
// the setup function runs once when you press reset or power the board
  // initialize digital pin LED_BUILTIN as an output.
  pinMode(LEDPIN1, OUTPUT);
  pinMode(LEDPIN2, OUTPUT);
  pinMode(LEDPIN3, OUTPUT);
  pinMode(LEDPIN4, OUTPUT);
  pinMode(LEDPIN5, OUTPUT);
// the loop function runs over and over again forever
  digitalWrite(LEDPIN1, HIGH);
  digitalWrite(LEDPIN2, LOW);
  digitalWrite(LEDPIN3, LOW);
  digitalWrite(LEDPIN4, LOW);
  digitalWrite(LEDPIN5, LOW);
  delay(100);
  digitalWrite(LEDPIN1, LOW);
  digitalWrite(LEDPIN2, HIGH);
  delay(100);
  digitalWrite(LEDPIN3, HIGH);
  delay(100);
  digitalWrite(LEDPIN4, HIGH);
  delay(100);
  digitalWrite(LEDPIN5, HIGH);
  delay(100);
I used the blink sketch because I had it open teaching my dad the concept of arduino
thank you! i will use this! but i still want other ideas!
Maybe try a rain alarm using the rain sensor or a weather station if you have the DHT11
yeah I have a dht11!
thanks
Use the dht11 and rain sensor to make a weather station that can tell you the temperature and humidity and tell you if it's raining.
From yours and others earlier posts here , you come across as newbies or junior technicians.
Sorry.
  • Here is your sketch done a different way, try it out.
  • Ask questions.
Use pins 2, 3, 4, 5, 6
const byte LEDPIN1               = 2;  //do not use pin 0 or 1 as these are for communications
const byte LEDPIN2               = 3;
const byte LEDPIN3               = 4;
const byte LEDPIN4               = 5;
const byte LEDPIN5               = 6;
//index                             0  1  2  3  5
const byte ledArray[]            = {2, 3, 4, 5, 6};
const byte pattern               = 0b00000001;
byte myChaser;
//Timing stuff
unsigned long ledChaserTime;
//                                           s e t u p ( )
  //initialize LED pins as output
  for (byte x = 0; x < sizeof(ledArray); x++)
    pinMode(ledArray[x], OUTPUT);
  myChaser = pattern;
} //END of   setup()
//                                           l o o p ( )
  //========================================================================  T I M E R  ledChaser
  //is it time to advance the chase pattern ?
  if (millis() - ledChaserTime >= 200ul)
    //restart this TIMER
    ledChaserTime = millis();
    digitalWrite(LEDPIN1, bitRead(myChaser, 0));
    digitalWrite(LEDPIN2, bitRead(myChaser, 1));
    digitalWrite(LEDPIN3, bitRead(myChaser, 2));
    digitalWrite(LEDPIN4, bitRead(myChaser, 3));
    myChaser = myChaser << 1;
    if(myChaser == 0b00010000)
      myChaser = pattern;
  //       Other non blocking code goes here
} //END of   loop()
idem
Why would you need to ask for ideas?
cause i've never worked with Arduino.
I doubt you ever worked for Microsoft, either.
