Waveshare LED matrix 64x32 brightness problem
Hello everyone,
I have a question about how to set a higher brightness. I have read dozens and dozens of discussions. I have a Waveshare 64x32 LED matrix HUB75 with ICN2037BP chips connected to ESP32. I am using the library GitHub - mrcodetastic/ESP32-HUB75-MatrixPanel-DMA: An Adafruit GFX Compatible Library for the ESP32, ESP32-S2, ESP32-S3 to drive HUB75 LED matrix panels using DMA for high refresh rates. Supports panel chaining., everything works fine, but I would need to increase the brightness. If I set the color for example dma_display->color444(15, 15, 15) and dma_display->setBrightness8(255) then I get the maximum brightness. However, the display is used behind a semi-transparent mirror and this brightness is not sufficient.
Normally, I would think that the display can't light more, but I found that when the ESP32 is disconnected from PC and I leave only the LED matrix power connected (5V, 5A power supply) and touch the ground on disconnected ESP32, some random pixels on the display light up (random digital noise is displayed), but they light up much more. I left the display in the "error" state for over 24 hours to verify that the LEDs wouldn't overheat and destroy and everything was fine. Does anyone have any ideas how to get more brightness out of that display? It's obvious that it can do it, but I don't know what to change where to do it in the source code/library.
Below is an image of brightness at maximum RGB brightness and setBrightness8(255). And below that is the "error" state when I touch the ground of PC-disconnected ESP32 and the random pixels light up and are much brighter.
Many thanks for any help
Ensure all devices share a common ground reference. Show your wiring.
I don't think you can. As it seems, the microcontroller and the display work in multiplexing mode, and when you turn on the LED, it is brighter because they are static.
@majk33
The correct answer is a multiplexing, as mentioned by @flashko.
Your matrix has 1/16 scan, it means that it divided by 16 parts, switched one after another, so every pixel lit only 1/16 part of total time.
When you switch on the matrix without mcu, some random pixels lights statically and its brightness 16 times more than in normal mode.
Although it seems obvious to you that this is possible, it is not so.
Many thanks @flashko and @b707 for you answer, this makes sense. I just ordered a new high brightness outdoor panel so hopefully it will work.
Could you show the link?
Yes sure here is the link
I don’t want to upset you, but its brightness is unlikely to be significantly greater. You had the one with 16 scans and this one too... Although there may be different type of LEDs here...
In addition, I advise you to ask the seller about the type of driver that is used in the panel - not all outdoor panels are compatible with Arduino libraries
Unfortunately it is 1/16 too but I believe there are used different LEDs for outdoor panels or they are pulse overloaded to increase the brightness. Pulse overload should be safe for most LEDs. There is no documentation for this, the seller warns that it will arrive with different drivers every time "Different company led module or buy them at different time, they are not compatible", so I risked $40 that's not so much :see_no_evil:
If I understand well what you mean - you can't use pulse overload with such panel, because the led's current is limited internally in the driver.
I meant that the panel is already made in such a way that it itself uses pulse overloading to increase the brightness for outdoor purposes. If the manufacturer increased the brightness in this way, I will have to be careful not to leave the display in an "error" state to prevent the LEDs from overheating :grin: As soon as the panel arrives, I'll let you know how it turned out :wink:
Hi guys,
the new display has arrived and is much more bright. So the problem is solved. Thank you all again for your help :blush:
