I had tried without the breadboard completely and it still won't display anything
Below is the image of the serial monitor:
That displays everything as expected, there is a do{}while function between the power on and power off:
initDisplay();
do
drawCurrentConditions(owm_onecall.current, owm_onecall.daily[0],
owm_air_pollution, owm_onecall.hourly[0]);
drawForecast(owm_onecall.daily, timeInfo);
drawLocationDate(CITY_STRING, dateStr);
drawOutlookGraph(owm_onecall.hourly, timeInfo);
#if DISPLAY_ALERTS
drawAlerts(owm_onecall.alerts, CITY_STRING, dateStr);
#endif
drawStatusBar(statusStr, refreshTimeStr, wifiRSSI, batteryVoltage);
} while (display.nextPage());
powerOffDisplay();
and a small snippet of that code is below:
void initDisplay()
SPI.begin(PIN_EPD_SCK,
PIN_EPD_MISO,
PIN_EPD_MOSI,
PIN_EPD_CS);
display.init(115200, true, 2, false);
display.setRotation(0);
display.setTextSize(1);
display.setTextColor(GxEPD_BLACK);
display.setTextWrap(false);
//display.fillScreen(GxEPD_WHITE);
display.setFullWindow();
display.firstPage(); // use paged drawing mode, sets fillScreen(GxEPD_WHITE)
return;
} // end initDisplay
/* Power-off e-paper display
void powerOffDisplay()
display.hibernate(); // turns powerOff() and sets controller to deep sleep for
// minimum power use
digitalWrite(PIN_EPD_PWR, LOW);
return;
/* This function is responsible for drawing the current conditions and
* associated icons.
void drawCurrentConditions(const owm_current_t ¤t,
const owm_daily_t &today,
const owm_resp_air_pollution_t &owm_air_pollution,
const owm_hourly_t &hourly)
String dataStr, unitStr;
const float moonPhase = today.moon_phase;
// current weather icon
display.drawInvertedBitmap(0, 0,
getCurrentConditionsBitmap196(current, today),
196, 196, GxEPD_BLACK);
// current temp
#ifdef UNITS_TEMP_KELVIN
dataStr = String(static_cast<int>(round(current.temp)));
unitStr = TXT_UNITS_TEMP_KELVIN;
#endif
#ifdef UNITS_TEMP_CELSIUS
dataStr = String(static_cast<int>(round(kelvin_to_celsius(current.temp))));
unitStr = TXT_UNITS_TEMP_CELSIUS;
#endif
#ifdef UNITS_TEMP_FAHRENHEIT
dataStr = String(static_cast<int>(round(kelvin_to_fahrenheit(current.temp))));
unitStr = TXT_UNITS_TEMP_FAHRENHEIT;
#endif
// FONT_**_temperature fonts only have the character set used for displaying
// temperature (0123456789.-\xB0)
display.setFont(&FONT_48pt8b_temperature);
#if defined(DISP_BW_V2) || defined(DISP_3C_B) || defined(DISP_7C_F)
drawString(196 + 164 / 2 - 20, 196 / 2 + 69 / 2, dataStr, CENTER);
#elif defined(DISP_BW_V1)
drawString(156 + 164 / 2 - 20, 196 / 2 + 69 / 2, dataStr, CENTER);
#endif
display.setFont(&FONT_14pt8b);
drawString(display.getCursorX(), 196 / 2 - 69 / 2 + 20, unitStr, LEFT);
// current feels like
dataStr = String(TXT_FEELS_LIKE) + ' '
+ String(static_cast<int>(round(current.feels_like)));
#endif
kelvin_to_celsius(current.feels_like))))
+ '\xB0';
#endif
kelvin_to_fahrenheit(current.feels_like))))
+ '\xB0';
#endif
display.setFont(&FONT_12pt8b);
drawString(196 + 164 / 2, 98 + 69 / 2 + 12 + 17, dataStr, CENTER);
drawString(156 + 164 / 2, 98 + 69 / 2 + 12 + 17, dataStr, CENTER);
#endif
// line dividing top and bottom display areas
// display.drawLine(0, 196, DISP_WIDTH - 1, 196, GxEPD_BLACK);
// current weather data icons
display.drawInvertedBitmap(0, 204 + (48 + 8) * 0,
wi_sunrise_48x48, 48, 48, GxEPD_BLACK);
display.drawInvertedBitmap(0, 204 + (48 + 8) * 1,
wi_strong_wind_48x48, 48, 48, GxEPD_BLACK);
display.drawInvertedBitmap(0, 204 + (48 + 8) * 2,
wi_day_sunny_48x48, 48, 48, GxEPD_BLACK);
display.drawInvertedBitmap(0, 204 + (48 + 8) * 3,
air_filter_48x48, 48, 48, GxEPD_BLACK);
if(moonPhase == 0 || moonPhase == 1){
display.drawInvertedBitmap(0, 204 + (48 + 8) * 4,
wi_moon_alt_new_48x48, 48, 48, GxEPD_BLACK);
} else if (moonPhase<0.25){
wi_moon_alt_waxing_crescent_3_48x48, 48, 48, GxEPD_BLACK);
} else if (moonPhase == 0.25){
wi_moon_alt_first_quarter_48x48, 48, 48, GxEPD_BLACK);
} else if(moonPhase<0.5){
wi_moon_alt_waxing_gibbous_3_48x48, 48, 48, GxEPD_BLACK);
} else if(moonPhase == 0.5){
wi_moon_alt_full_48x48, 48, 48, GxEPD_BLACK);
} else if (moonPhase<0.75){
wi_moon_alt_waning_gibbous_3_48x48, 48, 48, GxEPD_BLACK);
}else if (moonPhase == 0.75){
wi_moon_alt_third_quarter_48x48, 48, 48, GxEPD_BLACK);
}else {
wi_moon_alt_waning_crescent_5_48x48, 48, 48, GxEPD_BLACK);
#endif
display.drawInvertedBitmap(170, 204 + (48 + 8) * 0,
wi_sunset_48x48, 48, 48, GxEPD_BLACK);
display.drawInvertedBitmap(170, 204 + (48 + 8) * 1,
wi_humidity_48x48, 48, 48, GxEPD_BLACK);
display.drawInvertedBitmap(170, 204 + (48 + 8) * 2,
wi_barometer_48x48, 48, 48, GxEPD_BLACK);
display.drawInvertedBitmap(170, 204 + (48 + 8) * 3,
visibility_icon_48x48, 48, 48, GxEPD_BLACK);
display.drawInvertedBitmap(170, 204 + (48 + 8) * 4,
wi_raindrops_48x48, 48, 48, GxEPD_BLACK);
#endif
// current weather data labels
display.setFont(&FONT_7pt8b);
drawString(48, 204 + 10 + (48 + 8) * 0, TXT_SUNRISE, LEFT);
drawString(48, 204 + 10 + (48 + 8) * 1, TXT_WIND, LEFT);
drawString(48, 204 + 10 + (48 + 8) * 2, TXT_UV_INDEX, LEFT);
drawString(48, 204 + 10 + (48 + 8) * 3, TXT_AIR_QUALITY_INDEX, LEFT);
drawString(48, 204 + 10 + (48 + 8) * 4, "Moon Cycle", LEFT);
#endif
drawString(170 + 48, 204 + 10 + (48 + 8) * 0, TXT_SUNSET, LEFT);
drawString(170 + 48, 204 + 10 + (48 + 8) * 1, TXT_HUMIDITY, LEFT);
drawString(170 + 48, 204 + 10 + (48 + 8) * 2, TXT_PRESSURE, LEFT);
drawString(170 + 48, 204 + 10 + (48 + 8) * 3, TXT_VISIBILITY, LEFT);
drawString(170 + 48, 204 + 10 + (48 + 8) * 4, "Hourly Rain", LEFT);
#endif
// sunrise
char timeBuffer[12] = {}; // big enough to accommodate "hh:mm:ss am"
time_t ts = current.sunrise;
tm *timeInfo = localtime(&ts);
_strftime(timeBuffer, sizeof(timeBuffer), TIME_FORMAT, timeInfo);
drawString(48, 204 + 17 / 2 + (48 + 8) * 0 + 48 / 2, timeBuffer, LEFT);
// wind
#ifdef WIND_INDICATOR_ARROW
display.drawInvertedBitmap(48, 204 + 24 / 2 + (48 + 8) * 1,
getWindBitmap24(current.wind_deg),
24, 24, GxEPD_BLACK);
#endif
#ifdef UNITS_SPEED_METERSPERSECOND
dataStr = String(static_cast<int>(round(current.wind_speed)));
unitStr = TXT_UNITS_SPEED_METERSPERSECOND;
#endif
#ifdef UNITS_SPEED_FEETPERSECOND
meterspersecond_to_feetpersecond(current.wind_speed) )));
unitStr = TXT_UNITS_SPEED_FEETPERSECOND;
#endif
#ifdef UNITS_SPEED_KILOMETERSPERHOUR
meterspersecond_to_kilometersperhour(current.wind_speed) )));
unitStr = TXT_UNITS_SPEED_KILOMETERSPERHOUR;
#endif
#ifdef UNITS_SPEED_MILESPERHOUR
meterspersecond_to_milesperhour(current.wind_speed) )));
unitStr = TXT_UNITS_SPEED_MILESPERHOUR;
#endif
#ifdef UNITS_SPEED_KNOTS
meterspersecond_to_knots(current.wind_speed) )));
unitStr = TXT_UNITS_SPEED_KNOTS;
#endif
#ifdef UNITS_SPEED_BEAUFORT
dataStr = String(meterspersecond_to_beaufort(current.wind_speed));
unitStr = TXT_UNITS_SPEED_BEAUFORT;
#endif
drawString(48 + 24, 204 + 17 / 2 + (48 + 8) * 1 + 48 / 2, dataStr, LEFT);
#else
drawString(48 , 204 + 17 / 2 + (48 + 8) * 1 + 48 / 2, dataStr, LEFT);
#endif
display.setFont(&FONT_8pt8b);
drawString(display.getCursorX(), 204 + 17 / 2 + (48 + 8) * 1 + 48 / 2,
unitStr, LEFT);
#if defined(WIND_INDICATOR_NUMBER)
dataStr = String(current.wind_deg) + "\xB0";
drawString(display.getCursorX() + 6, 204 + 17 / 2 + (48 + 8) * 1 + 48 / 2,
dataStr, LEFT);
#endif
#if defined(WIND_INDICATOR_CPN_CARDINAL) \
|| defined(WIND_INDICATOR_CPN_INTERCARDINAL) \
|| defined(WIND_INDICATOR_CPN_SECONDARY_INTERCARDINAL) \
|| defined(WIND_INDICATOR_CPN_TERTIARY_INTERCARDINAL)
dataStr = getCompassPointNotation(current.wind_deg);
dataStr, LEFT);
#endif
// uv and air quality indices
// spacing between end of index value and start of descriptor text
const int sp = 8;
// uv index
uint uvi = static_cast<uint>(std::max(round(current.uvi), 0.0f));
dataStr = String(uvi);
drawString(48, 204 + 17 / 2 + (48 + 8) * 2 + 48 / 2, dataStr, LEFT);
dataStr = String(getUVIdesc(uvi));
int max_w = 170 - (display.getCursorX() + sp);
if (getStringWidth(dataStr) <= max_w)
{ // Fits on a single line, draw along bottom
drawString(display.getCursorX() + sp, 204 + 17 / 2 + (48 + 8) * 2 + 48 / 2,
dataStr, LEFT);
{ // use smaller font
display.setFont(&FONT_5pt8b);
{ // Fits on a single line with smaller font, draw along bottom
dataStr, LEFT);
{ // Does not fit on a single line, draw higher to allow room for 2nd line
drawMultiLnString(display.getCursorX() + sp,
204 + 17 / 2 + (48 + 8) * 2 + 48 / 2 - 10,
dataStr, LEFT, max_w, 2, 10);
// air quality index
int aqi = getAQI(owm_air_pollution);
dataStr = String(aqi);
drawString(48, 204 + 17 / 2 + (48 + 8) * 3 + 48 / 2, dataStr, LEFT);
dataStr = String(getAQIdesc(aqi));
drawString(display.getCursorX() + sp, 204 + 17 / 2 + (48 + 8) * 3 + 48 / 2,
dataStr, LEFT);
dataStr, LEFT);
204 + 17 / 2 + (48 + 8) * 3 + 48 / 2 - 10,
// moon cycle
drawString(48, 204 + 17 / 2 + (48 + 8) * 4 + 48 / 2, getMoonPhase(moonPhase), LEFT);
#endif // defined(DISP_BW_V2) || defined(DISP_3C_B) || defined(DISP_7C_F)
// sunset
memset(timeBuffer, '\0', sizeof(timeBuffer));
ts = current.sunset;
drawString(170 + 48, 204 + 17 / 2 + (48 + 8) * 0 + 48 / 2, timeBuffer, LEFT);
// humidity
dataStr = String(current.humidity);
drawString(170 + 48, 204 + 17 / 2 + (48 + 8) * 1 + 48 / 2, dataStr, LEFT);
"%", LEFT);
// pressure
#ifdef UNITS_PRES_HECTOPASCALS
dataStr = String(current.pressure);
unitStr = TXT_UNITS_PRES_HECTOPASCALS;
#endif
#ifdef UNITS_PRES_PASCALS
hectopascals_to_pascals(current.pressure) )));
unitStr = TXT_UNITS_PRES_PASCALS;
#endif
#ifdef UNITS_PRES_MILLIMETERSOFMERCURY
hectopascals_to_millimetersofmercury(current.pressure) )));
unitStr = TXT_UNITS_PRES_MILLIMETERSOFMERCURY;
#endif
#ifdef UNITS_PRES_INCHESOFMERCURY
dataStr = String(round(1e1f *
hectopascals_to_inchesofmercury(current.pressure)
) / 1e1f, 1);
unitStr = TXT_UNITS_PRES_INCHESOFMERCURY;
#endif
#ifdef UNITS_PRES_MILLIBARS
hectopascals_to_millibars(current.pressure) )));
unitStr = TXT_UNITS_PRES_MILLIBARS;
#endif
#ifdef UNITS_PRES_ATMOSPHERES
dataStr = String(round(1e3f *
hectopascals_to_atmospheres(current.pressure) )
/ 1e3f, 3);
unitStr = TXT_UNITS_PRES_ATMOSPHERES;
#endif
#ifdef UNITS_PRES_GRAMSPERSQUARECENTIMETER
hectopascals_to_gramspersquarecentimeter(current.pressure)
unitStr = TXT_UNITS_PRES_GRAMSPERSQUARECENTIMETER;
#endif
#ifdef UNITS_PRES_POUNDSPERSQUAREINCH
dataStr = String(round(1e2f *
hectopascals_to_poundspersquareinch(current.pressure)
) / 1e2f, 2);
unitStr = TXT_UNITS_PRES_POUNDSPERSQUAREINCH;
#endif
drawString(170 + 48, 204 + 17 / 2 + (48 + 8) * 2 + 48 / 2, dataStr, LEFT);
drawString(display.getCursorX(), 204 + 17 / 2 + (48 + 8) * 2 + 48 / 2,
unitStr, LEFT);
// visibility
#ifdef UNITS_DIST_KILOMETERS
float vis = meters_to_kilometers(current.visibility);
unitStr = TXT_UNITS_DIST_KILOMETERS;
#endif
#ifdef UNITS_DIST_MILES
float vis = meters_to_miles(current.visibility);
unitStr = TXT_UNITS_DIST_MILES;
#endif
// if visibility is less than 1.95, round to 1 decimal place
// else round to int
if (vis < 1.95)
dataStr = String(round(10 * vis) / 10.0, 1);
dataStr = String(static_cast<int>(round(vis)));
if (vis >= 10) {
#endif
if (vis >= 6) {
#endif
dataStr = "> " + dataStr;
drawString(170 + 48, 204 + 17 / 2 + (48 + 8) * 3 + 48 / 2, dataStr, LEFT);
drawString(display.getCursorX(), 204 + 17 / 2 + (48 + 8) * 3 + 48 / 2,
unitStr, LEFT);
//rain volume per hour
dataStr = String(hourly.rain_1h, 1);
drawString(170 + 48, 204 + 17 / 2 + (48 + 8) * 4 + 48 / 2, dataStr, LEFT);
drawString(display.getCursorX(), 204 + 17 / 2 + (48 + 8) * 4 + 48 / 2,
"mm", LEFT);
return;
} // end drawCurrentConditions
/* This function is responsible for drawing the five day forecast.
void drawForecast(owm_daily_t *const daily, tm timeInfo)
// 5 day, forecast
String hiStr, loStr;
for (int i = 0; i < 5; ++i)
int x = 398 + (i * 82);
int x = 318 + (i * 64);
#endif
// icons
display.drawInvertedBitmap(x, 98 + 69 / 2 - 32 - 6,
getForecastBitmap64(daily[i]),
64, 64, GxEPD_BLACK);
// day of week label
display.setFont(&FONT_11pt8b);
char dayBuffer[8] = {};
_strftime(dayBuffer, sizeof(dayBuffer), "%a", &timeInfo); // abbrv'd day
drawString(x + 31 - 2, 98 + 69 / 2 - 32 - 26 - 6 + 16, dayBuffer, CENTER);
timeInfo.tm_wday = (timeInfo.tm_wday + 1) % 7; // increment to next day
// high | low
drawString(x + 31, 98 + 69 / 2 + 38 - 6 + 12, "|", CENTER);
hiStr = String(static_cast<int>(round(daily[i].temp.max)));
loStr = String(static_cast<int>(round(daily[i].temp.min)));
#endif
hiStr = String(static_cast<int>(round(kelvin_to_celsius(daily[i].temp.max)
))) + "\xB0";
loStr = String(static_cast<int>(round(kelvin_to_celsius(daily[i].temp.min)
))) + "\xB0";
#endif
hiStr = String(static_cast<int>(round(kelvin_to_fahrenheit(daily[i].temp.max)
))) + "\xB0";
loStr = String(static_cast<int>(round(kelvin_to_fahrenheit(daily[i].temp.min)
))) + "\xB0";
#endif
drawString(x + 31 - 4, 98 + 69 / 2 + 38 - 6 + 12, hiStr, RIGHT);
drawString(x + 31 + 5, 98 + 69 / 2 + 38 - 6 + 12, loStr, LEFT);
return;
} // end drawForecast
That do{}while function is not doing what it is supposed to be doing which is initialising the display, projecting the information onto it and then hibernatin. Currently I believe it just turns on and off
