Mega 2560 - unchanged. Selected under Tools.Board.
Version 2 arrived when I downloaded the Arduino IDE to the newer laptop and I straight away got the same problem, so I searcehd for an older IDE and selected the oldest before ver 2.
Please excuse my lack of skill & memory! This code was written years ago.
Full sketch and full error message below.
#include <avr/wdt.h>
#include <SD.h>
#include <Wire.h>
#include <SPI.h>
#include <Adafruit_MCP23017.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_BME280.h>
#include <RTClib.h>
#include <Time.h>
#include <TimeAlarms.h>
#include <Adafruit_RGBLCDShield.h>
#include <PinChangeInt.h>
#define PIN 3 // the pin for button/ rain gauge
#define STOP_SWITCH 2
// Suspect these 3 lines became necessary with SD_Master update
// set up variables using the SD utility library functions:
Sd2Card card;
SdVolume volume;
SdFile root;
bool stopped = false;
RTC_DS1307 RTC;
time_t syncProvider() //this does the same thing as RTC_DS1307::get() but it is only a definition.
//. Copied the next line from an Alarm example.
//setSyncProvider(syncProvider); //reference our syncProvider function instead of RTC_DS1307::get()
//This tells the Time library to sync the Arduino time to the RTC.
return RTC.now().unixtime();
uint32_t syncTime = 0; // time of last sync()
// for the data logging shield, we use digital pin 10 for the SD cs line
const int chipSelect = 10;
// the logging files
File logfile;
File rainfile;
void error(char *str)
Serial.print("error: ");
Serial.println(str);
while (1);
long mon = 0;
int dy = 0;
int hr = 0;
int mn = 0;
int sec = 0;
volatile int flag = 0;
int nflag;
int Run = 1;
int test = 1;
int nutim = 0;
int oldtim = 0;
int First = 0;
int Diff = 0;
char Dirn = 'N';
int prX = 1000;
int prN = 1000;
int pr2X = 1000;
int pr2N = 1000;
Adafruit_RGBLCDShield lcd = Adafruit_RGBLCDShield();
Adafruit_BME280 bme;
float temp;
float maxT;
float minT = 90;
float maxTy;
float minTy;
float rh = 0;
float rhX = 0;
float rhXY = 0;
float rhN = 90;
float rhNY = 90;
float pr = 0;
float prr = 1000;
byte _status;
long zerosec = millis();
unsigned long delayTime;
bool status;
status = bme.begin();
if (!status) {
Serial.println("Could not find a valid BME280 sensor, check wiring!");
while (1);
/* Serial.println("-- Sensor Test --");
delayTime = 1000;
delay(100); // let sensor boot up
Serial.print("Temperature = ");
temp = (bme.readTemperature());
Serial.print(temp, 2);
Serial.println(" *C");
Serial.print("Pressure = ");
pr = bme.readPressure();
Serial.print(pr, 2);
Serial.println(" hPa");
Serial.print("Humidity = ");
rh = bme.readHumidity();
Serial.print(rh);
Serial.println(" %");
*/// set up the LCD's number of columns and rows:
lcd.begin(16, 2);
Wire.begin();
RTC.begin();
if (! RTC.isrunning()) {
// following line sets the RTC to the date & time this sketch was compiled so if it is used other than
//on load time, the RTC time will be set back to whatever time and date compilation occured.
// this can be improved by issuing warning if RTC time is behind arduino time using an If.
RTC.adjust(DateTime(__DATE__, __TIME__));
//RTC.adjust(DateTime(__DATE__, __TIME__)); //Comment this once local time has been set.
//configure pin2 as an input and enable the internal pull-up resistor
pinMode(STOP_SWITCH, INPUT_PULLUP);
// initialize the SD card
Serial.print("InitSD");
// make sure that the default chip select pin is set to
// output, even if you don't use it:
pinMode(53, OUTPUT); //53 required for Mega
// see if the card is present and can be initialized:
if (!SD.begin(10, 11, 12, 13))
error("Cd fail");
Serial.println("cdinit.");
// create a new file
char filename[] = "LOGGER00.CSV";
for (uint8_t i = 0; i < 100; i++)
filename[6] = i / 10 + '0';
filename[7] = i % 10 + '0';
if (! SD.exists(filename)) {
// only open a new file if it doesn't exist
logfile = SD.open(filename, FILE_WRITE);
break; // leave the loop!
if (! logfile) {
error("No lgfile");
Serial.print("Log to ");
Serial.println(filename);
char filename2[] = "RAINEY00.CSV";
filename2[6] = i / 10 + '0';
filename2[7] = i % 10 + '0';
if (! SD.exists(filename2)) {
rainfile = SD.open(filename2, FILE_WRITE);
//This should work but does not - why?
/* if (! rainfile) {
error("couldnt create rnfile");
Serial.println(filename2);
/* DateTime now = RTC.now(); // to test that the time is correct.
mon = now.month();
dy = now.day();
hr = now.hour();
mn = now.minute();
Serial.print(mon);
Serial.print(";");
Serial.print(hr);
Serial.print(':');
Serial.print(mn);
pinMode(PIN, INPUT); //set the pin to input
digitalWrite(PIN, LOW); //1 Megohm physical to -ve
attachInterrupt(digitalPinToInterrupt(3), burpcount, RISING);
// attach an Interrupt to our pin for the rising edge.
// and execute the function burpcount when that pin changes.
/*Information on :- attachInterrupt(digitalPinToInterrupt(pin), ISR, mode);
interrupt: the number of the interrupt (int)
pin: the pin number (Arduino Due, Zero, MKR1000 only)
ISR: the ISR to call when the interrupt occurs; this function must take no parameters and return
nothing. This function is sometimes referred to as an interrupt service routine.
mode: defines when the interrupt should be triggered. Four constants are predefined as valid values:
LOW to trigger the interrupt whenever the pin is low,
CHANGE to trigger the interrupt whenever the pin changes value
RISING to trigger when the pin goes from low to high,
FALLING for when the pin goes from high to low.
*/ // and execute the function burpcount when that pin changes.
//2 line to kick off imediately.
//Repeat3(); //Loggs Midnight max & Min and Monthly heading on 1st.
Repeats(); //Main half-hourly logging of Temp, RH & Pressure. This calls Time now for testing
Repeat2(); // 8 second update display on LCD - 3 separete pages. This calls Time now for testing
Alarm.timerRepeat(8, Repeat2); // LCD display, 8 seconds.
Alarm.alarmRepeat(0, 1, 0, Repeat3); // One minute past Midnight date and Max/Min.
while (minute() != 0) //Prog holds here until the hour so that logging is on the hour and the half hour.
Serial.print(" setup minute ");
Serial.println(minute(), DEC);
Alarm.timerRepeat(1800, Repeats); //Main half-hourly logging of Temp, RH & Pressure. All Alarms run outside the loop.
wdt_enable(WDTO_8S); // Watch Dog timer set to 8 seconds.
if (LOW == digitalRead(STOP_SWITCH)) {
logfile.flush();
rainfile.flush();
Serial.println("flush");
delay(10); //switch debounce interval
while (LOW == digitalRead(STOP_SWITCH)) { //stick here until stop switch is turned off.
stopped = true;
wdt_reset(); // prevents a sketch restart while stop switch is in use.
stopped = false; //stop switch currently turned off
Alarm.delay(0); // wait 0 seconds - something needed here or alarm does not work
if (flag != nflag) {
mon = now.month();
dy = now.day();
hr = now.hour();
mn = now.minute();
sec = now.second();
nutim = mn;
if ((nutim - oldtim) >= 2) {
test = 1;
oldtim = mn;
rainfile.print(flag);
rainfile.print(";");
rainfile.print(dy);
rainfile.print("/");
rainfile.print(mon);
rainfile.print(hr);
rainfile.print(':');
rainfile.print(mn);
rainfile.print(sec);
rainfile.println();
if (test == 1) {
rainfile.flush();
Serial.println(F("flushed"));
test = 0;
nflag = flag;
wdt_reset();
void Repeats() { // Every 30 minutes.
logfile.print(now.day(), DEC);
logfile.print("/");
logfile.print(now.month(), DEC);
logfile.print("/");
logfile.print(now.year(), DEC);
logfile.print(",");
logfile.print(now.hour(), DEC);
Serial.print(now.hour(), DEC);
logfile.print(":");
logfile.print(now.minute(), DEC);
Serial.println(now.minute(), DEC);
logfile.print(", ");
logfile.print(" RH ");
logfile.print(rh);
logfile.print(",");
logfile.print("T ");
logfile.print(temp);
logfile.print(",");
logfile.print("P ");
Serial.print("P ");
logfile.print(pr, 1);
Serial.println(pr, 1);
//logfile.print(";");
logfile.println();
logfile.flush();
void Repeat2() {
//LCD pressure, rain,Temp & Line 2 humidity.
rh = (bme.readHumidity());
pr = (bme.readPressure());
maxT = max(temp, maxT); // these Max & Mins work for all readings of temp, until reset after midnight.
minT = min(temp, minT);
rhX = max(rh, rhX);
rhN = min(rh, rhN);
pr = pr / 100;
pr = round (pr);
/* Serial.print(F("Rpt2 minute "));
Serial.println(minute());
Serial.print("prr = ");
Serial.println(prr );
*/ if (minute() == 0) {
prr = pr;
pr2X = pr;
pr2N = pr;
// prr is 7 or 8 readings of Pressure taken during minute 0, top of the hour.
pr2X = max(pr, pr2X); // These two lines collect the max & Min of 60 minute readings.
pr2N = min(pr, pr2N);
prX = max(pr, prX); // These two lines collect the max & Min of 24h readings.
prN = min(pr, prN);
if (pr2X > (prr + 1)) { // this block compares the hour reading with the max or min during the hour every 8 seconds
Diff = (pr2X - prr);
Dirn = 'D';
else if (pr2N < (prr - 1)) {
Diff = (prr - pr2N);
Dirn = 'U';
else {
Diff = 0;
Dirn = '=';
switch (Run) {
case 1:
lcd.setCursor(0, 0);
lcd.print(F(" "));
lcd.print(F("P"));
lcd.print(pr, 0);
lcd.print(" ");
lcd.print(Dirn);
lcd.print(Diff); //Change since last hour point.Ex 16 characters: P1009 U99 Rn9999
//lcd.setCursor(10, 0);
lcd.print(F(" Rn"));
lcd.print(flag);
lcd.setCursor(0, 1); // 2nd row
lcd.print(F("Temp")); //Ex 16 char Temp29.1 RH 88.1
lcd.print(temp, 1);
lcd.print(F(" RH "));
lcd.println(rh, 1);
Run ++ ;
case 2:
lcd.setCursor(0, 0);// LCD Max & Min temp and Yesterdays Max and Min temp line 2
lcd.print(F(" ")); // Wipes line clean, otherwise previous data remains.
lcd.print(F("Max")); //Ex 16 characters Max33.5 Min17.5
lcd.print(maxT, 1);
lcd.print(F(" "));
lcd.print(F("Min"));
lcd.print(minT, 1);
lcd.print(F(" "));
lcd.print(F("Yx ")); //16 characters Yx 15.5 Yn 13.2
lcd.print(maxTy, 1);
lcd.print(F(" Yn "));
lcd.print(minTy, 1);
Run ++ ;
case 3:
lcd.setCursor(0, 0);// LCD max and Min RH and Yesterdays Max & Min RH line 2.
lcd.print(F("RHX")); // 16 characters RHX60.1 RHN 45.3
lcd.print(rhX, 1); // RH Max
lcd.print(F(" "));
lcd.print(F("RHN "));
lcd.print(rhN, 1); // RH Min
lcd.print(F(" "));
lcd.print(F("RMY")); // Ex 16 characters RMY88.9 RNY 44.5
lcd.print(rhXY, 1); // Yesterday RH Max
lcd.print(F(" RNY "));
lcd.print(rhNY, 1); // Yesterday RH Min
Run = 1;
void Repeat3() {
if (now.day() == 1 && now.month() == 1) {
logfile.println(now.year());
logfile.print(",");
logfile.println(F("January"));
if (now.day() == 1 && now.month() == 2)
logfile.print(F("February"));
if (now.day() == 1 && now.month() == 3)
logfile.print(F("March"));
if (now.day() == 1 && now.month() == 4)
logfile.print(F("April"));
if (now.day() == 1 && now.month() == 5)
logfile.print(F("May"));
if (now.day() == 1 && now.month() == 6)
logfile.print(F("June"));
if (now.day() == 1 && now.month() == 7)
logfile.print(F("July"));
if (now.day() == 1 && now.month() == 8)
logfile.print(F("August"));
if (now.day() == 1 && now.month() == 9)
logfile.print(F("September"));
if (now.day() == 1 && now.month() == 10)
logfile.print(F("October"));
if (now.day() == 1 && now.month() == 11)
logfile.print(F("November"));
if (now.day() == 1 && now.month() == 12)
logfile.print(F("December"));
logfile.print(";");
logfile.print(";");
logfile.print(";");
logfile.print(";");
logfile.print(";");
logfile.print(";");
logfile.print(";");
logfile.print("TMax ");
logfile.print(maxT, 2);
logfile.print(" TMin ");
logfile.print(minT, 2);
logfile.print(" RH Max ");
logfile.print(rhX, 2);
logfile.print(" RH Min ");
logfile.print(rhN, 2);
logfile.println();
logfile.flush();
maxTy = maxT;
minTy = minT;
maxT = 0;
minT = 99;
rhXY = rhX;
rhNY = rhN;
rhX = 0;
rhN = 90;
void burpcount()
flag++;
Arduino: 1.8.18 (Windows 10), Board: "Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)"
In file included from C:\Users\User\Documents\Arduino\Codes\BME280WeaStn230718\BME280WeaStn230718.ino:11:0:
C:\Users\User\Documents\Arduino\libraries\TimeAlarms/TimeAlarms.h:71:31: error: 'timeDayOfWeek_t' does not name a type
AlarmID_t alarmRepeat(const timeDayOfWeek_t DOW, const int H, const int M, const int S, OnTick_t onTickHandler); // as above, with day of week
C:\Users\User\Documents\Arduino\libraries\TimeAlarms/TimeAlarms.h:75:29: error: 'timeDayOfWeek_t' does not name a type
AlarmID_t alarmOnce(const timeDayOfWeek_t DOW, const int H, const int M, const int S, OnTick_t onTickHandler); // as above, with day of week
C:\Users\User\Documents\Arduino\Codes\BME280WeaStn230718\BME280WeaStn230718.ino: In function 'void setup()':
BME280WeaStn230718:113:3: error: 'Wire' was not declared in this scope
Wire.begin();
C:\Users\User\Documents\Arduino\Codes\BME280WeaStn230718\BME280WeaStn230718.ino:113:3: note: suggested alternative: 'Dirn'
Wire.begin();
Dirn
C:\Users\User\Documents\Arduino\Codes\BME280WeaStn230718\BME280WeaStn230718.ino:136:20: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
error("Cd fail");
C:\Users\User\Documents\Arduino\Codes\BME280WeaStn230718\BME280WeaStn230718.ino:153:22: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
error("No lgfile");
BME280WeaStn230718:218:10: error: 'minute' was not declared in this scope
C:\Users\User\Documents\Arduino\Codes\BME280WeaStn230718\BME280WeaStn230718.ino:218:10: note: suggested alternative: 'minTy'
minTy
BME280WeaStn230718:224:18: error: 'minute' was not declared in this scope
C:\Users\User\Documents\Arduino\Codes\BME280WeaStn230718\BME280WeaStn230718.ino:224:18: note: suggested alternative: 'minTy'
minTy
C:\Users\User\Documents\Arduino\Codes\BME280WeaStn230718\BME280WeaStn230718.ino: In function 'void Repeat2()':
BME280WeaStn230718:328:9: error: 'minute' was not declared in this scope
C:\Users\User\Documents\Arduino\Codes\BME280WeaStn230718\BME280WeaStn230718.ino:328:9: note: suggested alternative: 'minTy'
minTy
Multiple libraries were found for "Adafruit_MCP23017.h"
Used: C:\Users\User\Documents\Arduino\libraries\Adafruit_MCP23017_Arduino_Library_master
Not used: C:\Users\User\Documents\Arduino\libraries\Adafruit_RGB_LCD_Shield_Library_master
exit status 1
option enabled in File -> Preferences.
