Web page interface not showing with ESP8266
I try to modify one's source code of esp8266 flight controller, but I can't access the IP address and web page interface to update PID tuning not showing at the IP address I decided.
I can ping via windows cmd. It replied.
Please let me know what makes it error (not showing anything). It is the third day and perhaps, the code goes terrible. Please help
#include <Wire.h>
#include <ESP8266WiFi.h>
#include <ESP8266WebServer.h>
#include <WiFiUdp.h>
WiFiUDP UDP;
char packet[7];
boolean recvState;
IPAddress apIP(192, 168, 1, 1);
ESP8266WebServer server (80);
const char* ssid = "QuadX";
const char* password = "12345678";
#define D5 14
#define D6 13
#define D7 12
#define D8 15
// Minimize unstable drone in yaw
double desired_yaw = 0.0;  // The target yaw angle
double current_yaw = 0.0;  // The actual yaw angle measured by the sensor
double last_yaw_error = 0.0;
double integrateYawError(double yaw_error) {
    static double yaw_error_sum = 0;
    yaw_error_sum += yaw_error;
    return yaw_error_sum;
int ESCpin_1, ESCpin_2, ESCpin_3, ESCpin_4;
int input_PITCH = 50;
int input_ROLL = 50;
int input_YAW;
int input_THROTTLE = 1050;
int state1, state2, state3, state4;
// IMU Variables
int16_t gyro_x, gyro_y, gyro_z, acc_x, acc_y, acc_z, temperature, acc_total_vector;
float angle_pitch, angle_roll, angle_yaw;
boolean set_gyro_angles;
float angle_roll_acc, angle_pitch_acc;
float angle_pitch_output, angle_roll_output;
float elapsedTime;
long Time, timePrev, time2;
long gyro_x_cal, gyro_y_cal, gyro_z_cal;
// PID Variables
float pitch_PID, roll_PID, yaw_PID;
float roll_error, roll_previous_error, pitch_error, pitch_previous_error, yaw_error;
float roll_pid_p, roll_pid_d, roll_pid_i, pitch_pid_p, pitch_pid_i, pitch_pid_d, yaw_pid_p, yaw_pid_i;
float roll_desired_angle, pitch_desired_angle, yaw_desired_angle;
// PID Parameters
double twoX_kp = 5;
double twoX_ki = 0.003;
double twoX_kd = 2;
double yaw_kp = 3;
double yaw_ki = 0.002;
double yaw_kd = 0.0;
    pinMode(D5, OUTPUT);
    pinMode(D6, OUTPUT);
    pinMode(D7, OUTPUT);
    pinMode(D8, OUTPUT);
    delay(1300);
//  WiFi.softAPConfig(apIP, apIP, IPAddress(255, 255, 255, 0));
    WiFi.softAP(ssid,password);
    IPAddress myIP = WiFi.softAPIP();
        GPOS = (1 << 14); GPOS = (1 << 12); GPOS = (1 << 13); GPOS = (1 << 15);
        delayMicroseconds(1000);
        GPOC = (1 << 14); GPOC = (1 << 12); GPOC = (1 << 13); GPOC = (1 << 15);
        yield();
    // Set up routes
    server.on("/", handleRoot);
    server.on("/updatePID", handleUpdatePID);
    Serial.println(WiFi.softAPIP());
    UDP.begin(9999);
    Wire.begin();
    Wire.setClock(400000);
    Wire.beginTransmission(0x68);
    Wire.write(0x6B);
    Wire.write(0x00);
    Wire.endTransmission();
    Wire.write(0x1C);
    Wire.write(0x10);
    Wire.write(0x1B);
    Wire.write(0x08);
    for (int cal_int = 0; cal_int < 2000; cal_int++) {
        if (cal_int % 125 == 0) Serial.print(".");
        Wire.write(0x3B);
        Wire.requestFrom(0x68, 14);
        while (Wire.available() < 14);
        acc_x = Wire.read() << 8 | Wire.read();
        acc_y = Wire.read() << 8 | Wire.read();
        acc_z = Wire.read() << 8 | Wire.read();
        temperature = Wire.read() << 8 | Wire.read();
        gyro_x = Wire.read() << 8 | Wire.read();
        gyro_y = Wire.read() << 8 | Wire.read();
        gyro_z = Wire.read() << 8 | Wire.read();
        gyro_x_cal += gyro_x;
        gyro_y_cal += gyro_y;
        gyro_z_cal += gyro_z;
        yield();
    gyro_x_cal /= 2000;
    gyro_y_cal /= 2000;
    gyro_z_cal /= 2000;
    Time = micros();
    timePrev = Time;
    Time = micros();
    elapsedTime = (float)(Time - timePrev) / (float)1000000;
    Wire.write(0x3B);
    gyro_x -= gyro_x_cal;
    gyro_y -= gyro_y_cal;
    gyro_z -= gyro_z_cal;
    angle_pitch += gyro_x * elapsedTime * 0.01526717557;
    angle_roll += gyro_y * elapsedTime * 0.01526717557;
    angle_yaw += gyro_z * elapsedTime * 0.01526717557;
    angle_pitch += angle_roll * sin(gyro_z * 0.000001066);
    angle_roll -= angle_pitch * sin(gyro_z * 0.000001066);
    acc_total_vector = sqrt((acc_x * acc_x) + (acc_y * acc_y) + (acc_z * acc_z));
    angle_pitch_acc = asin((float)acc_y / acc_total_vector) * 57.296;
    angle_roll_acc = asin((float)acc_x / acc_total_vector) * -57.296;
    angle_pitch_acc += 0;
    angle_roll_acc += 0;
    if (set_gyro_angles) {
        angle_pitch = angle_pitch * 0.9996 + angle_pitch_acc * 0.0004;
        angle_roll = angle_roll * 0.9996 + angle_roll_acc * 0.0004;
        angle_pitch = angle_pitch_acc;
        angle_roll = angle_roll_acc;
        set_gyro_angles = true;
    angle_pitch_output = angle_pitch_output * 0.9 + angle_pitch * 0.1;
    angle_roll_output = angle_roll_output * 0.9 + angle_roll * 0.1;
    roll_desired_angle = 3 * ((float)input_ROLL / (float)10 - (float)5);
    pitch_desired_angle = 3 * ((float)input_PITCH / (float)10 - (float)5);
    yaw_desired_angle = 0;
    roll_error = angle_roll_output - roll_desired_angle;
    pitch_error = angle_pitch_output - pitch_desired_angle;
    yaw_error = angle_yaw - yaw_desired_angle;
    roll_pid_p = twoX_kp * roll_error;
    roll_pid_i = roll_pid_i + (twoX_ki * roll_error);
    roll_pid_d = twoX_kd * ((roll_error - roll_previous_error) / elapsedTime);
    pitch_pid_p = twoX_kp * pitch_error;
    pitch_pid_i = pitch_pid_i + (twoX_ki * pitch_error);
    pitch_pid_d = twoX_kd * ((pitch_error - pitch_previous_error) / elapsedTime);
    yaw_pid_p = yaw_kp * yaw_error;
    yaw_pid_i = yaw_pid_i + (yaw_ki * yaw_error);
    yaw_pid_i = constrain(yaw_pid_i, -100, 100);
    yaw_pid_p = constrain(yaw_pid_p, -400, 400);
    roll_PID = roll_pid_p + roll_pid_i + roll_pid_d;
    pitch_PID = pitch_pid_p + pitch_pid_i + pitch_pid_d;
    yaw_PID = yaw_pid_p + yaw_pid_i;
    // Motor adjustments
    state1 = input_THROTTLE - roll_PID - pitch_PID + yaw_PID;
    state2 = input_THROTTLE - roll_PID + pitch_PID - yaw_PID;
    state3 = input_THROTTLE + roll_PID + pitch_PID + yaw_PID;
    state4 = input_THROTTLE + roll_PID - pitch_PID - yaw_PID;
    state1 = constrain(state1, 1050, 2000);
    state2 = constrain(state2, 1050, 2000);
    state3 = constrain(state3, 1050, 2000);
    state4 = constrain(state4, 1050, 2000);
    ESCpin_1 = state1;
    ESCpin_2 = state2;
    ESCpin_3 = state3;
    ESCpin_4 = state4;
    analogWrite(D5, ESCpin_1);
    analogWrite(D6, ESCpin_2);
    analogWrite(D7, ESCpin_3);
    analogWrite(D8, ESCpin_4);
    roll_previous_error = roll_error;
    pitch_previous_error = pitch_error;
    yield();
    server.handleClient();
void handleRoot() {
    String html = "<h1>PID Tuning Interface</h1>";
    html += "<form action=\"/updatePID\">";
    html += "twoX_kp: <input type=\"text\" name=\"twoX_kp\" value=\"" + String(twoX_kp) + "\"><br>";
    html += "twoX_ki: <input type=\"text\" name=\"twoX_ki\" value=\"" + String(twoX_ki) + "\"><br>";
    html += "twoX_kd: <input type=\"text\" name=\"twoX_kd\" value=\"" + String(twoX_kd) + "\"><br>";
    html += "yaw_kp: <input type=\"text\" name=\"yaw_kp\" value=\"" + String(yaw_kp) + "\"><br>";
    html += "yaw_ki: <input type=\"text\" name=\"yaw_ki\" value=\"" + String(yaw_ki) + "\"><br>";
    html += "yaw_kd: <input type=\"text\" name=\"yaw_kd\" value=\"" + String(yaw_kd) + "\"><br>";
    html += "<input type=\"submit\" value=\"Update PID\">";
    html += "</form>";
    server.send(200, "text/html", html);
void handleUpdatePID() {
    // Update PID values based on input from the web page
    if (server.hasArg("twoX_kp")) twoX_kp = server.arg("twoX_kp").toFloat();
    if (server.hasArg("twoX_ki")) twoX_ki = server.arg("twoX_ki").toFloat();
    if (server.hasArg("twoX_kd")) twoX_kd = server.arg("twoX_kd").toFloat();
    if (server.hasArg("yaw_kp")) yaw_kp = server.arg("yaw_kp").toFloat();
    if (server.hasArg("yaw_ki")) yaw_ki = server.arg("yaw_ki").toFloat();
    if (server.hasArg("yaw_kd")) yaw_kd = server.arg("yaw_kd").toFloat();
    String message = "PID values updated: \n";
    message += "twoX_kp: " + String(twoX_kp) + "\n";
    message += "twoX_ki: " + String(twoX_ki) + "\n";
    message += "twoX_kd: " + String(twoX_kd) + "\n";
    message += "yaw_kp: " + String(yaw_kp) + "\n";
    message += "yaw_ki: " + String(yaw_ki) + "\n";
    message += "yaw_kd: " + String(yaw_kd) + "\n";
    server.send(200, "text/plain", message);
This section tests for connection of the esp8266 in STA mode. Basically it is waiting to connect to a network, but you have never told it to try and do that.
You have only told it to become an Access Point. Which although it will show up, and you can connect to it most likely, the ESP will be stuck in the infinite loop and so the server never gets started and never gets handled either.
Comment out the section waiting for a connection, and even when you re-add it after making it connect to a network, make sure there is a time-out.
After double check, I guess you're right. But still not working. Then I try uploading Example Sketch on arduino IDE but still not working:
Here's the example sketch:
#include <WiFiClient.h>
#ifndef APSSID
#define APSSID "ESPap"
#define APPSK  "123456789"
#endif
/* Set these to your desired credentials. */
const char *ssid = APSSID;
const char *password = APPSK;
ESP8266WebServer server(80);
/* Just a little test message.  Go to http://192.168.4.1 in a web browser
   connected to this access point to see it.
void handleRoot() {
  server.send(200, "text/html", "<h1>You are connected</h1>");
  Serial.print("Configuring access point...");
  /* You can remove the password parameter if you want the AP to be open. */
  WiFi.softAP(ssid, password);
  Serial.print("AP IP address: ");
  Serial.println(myIP);
  server.begin();
  Serial.println("HTTP server started");
I use arduino IDE 1.8.18 and esp8266 2.5.0 core & library.
No problem with my previous arduino projects, I also asked in this forum with closely similar to this in here and it worked and it showed the web page interface.
