I'm trying to hook multiple buttons into one analog input in order to minimize the IO pin usage of my project.
I've setup the circuit as shown in the JPG; hooking a 220Ohm resistor to between Ground and the Analog pin #5; then I've setup 5 buttons with different resistors between 5V and the same analog pin in order to get different value depending on which button I was going to press.
The code is very simple:
pinMode(A5, INPUT);
int val = analogRead(A5);
Serial.println(val);
delay(10);
However, the reading are all weird....
| | | Read from A5 | | Comment |
| No button pressed | | ~0 | | Expected. |
| S1 pressed | | ~530 | | A bit low... but seems fine. |
| S2 pressed | | ~20 | | What???. It's only a 1K resistor |
| S3 pressed | | ~100 | | Now it's really weird; a 2K resistor reads a value between the 220 and the 1K resistors???. |
| S4 pressed | | ~40 | | Hu???. |
| S5 pressed | | ~960 | | Now I'm completely lost. |
Your circuit is a bit primitive, but it should work, at least as an approach.
Revise all the connections, may be something makes a loose contact.
Modify your software to accept an input only if it repeats two consecutive inputs.
Regards.
Yeah, I agree; it's very primitive, the circuit doesn't even have proper debounce system. I'm very new to this,
trying to build a Yahtzee game for my daughter Hence the 5 buttons.
Yeah, I guess I should redo the whole button circuit, one button at a time.
I wish I had pins for the multimeter to plug straight in the breadboard. That would seriously help the debugging.
I think you've mixed up some of your switches, and one of them has a 12 ohm, not 1k resistor?(*)
The values you should see are 500, 200, 100, 40, 20, and you are missing 200
the codes could be mirror images for this combination:
1k = brown black red brown
12R = brown red blank brown
MarkT:
This is very unlikely as:
I don't have 12 ohm resistors; the smallest one I got right now is 100 Ohm.
I measured all resistors twice with a multimeter; I wanted to make sure I did not accidentally swap them; as it would have been an obvious reason for this results.
I did grab brand new resistors for this; I verified their value before using them.
That said, that was my first thought as well: wrong resistors.
I'm however not sure what you mean by: "I think you've mixed up some of your switches"?
Unless you're thinking that I mixed up the resistors order with the switches; which I tested against it.
Re-think about your resistor-network so that you can rationally use VREF = 1.1 V (INTERNAL) for all the voltages of the above chart. You will get good quality measurements with VREF = INTERNAL rather than VREF = DEFAULT (5V). For example: with VREF = 5V, S5 will be seen as count 21; with VREF = 1.1V, S5 will be seen as count 99.
The arduino 5v out is used to reference the a/d, so the absolute voltage value doesn't matter if you also use it to power the resistor network string - the ratios remain unchanged.
And your odd results can only be through a wiring error or a faulty analog input - try another one
Found one of the issue; some of the "breadboard wires" I was using were faulty....
After changing the wires; and redoing the whole circuit, thing worked as expected.
Thanks for the help.
Few last questions:
I've noticed that changing the "ground" resistor affect the range of value I'm getting; in my first post, the ground resistor was 220Ohm, and the S1 resistor was also 220, I was getting a reading of ~530.
Changing the ground resistor to 100K Ohm change the reading to ~1020.
For my circuit, I found that 2K was the best choice since it gave me a decent range (> 100) between each button to compensate for error reading.
Q1: Is it because the Arduino has a internal resistor on each Analog pin which causes the current to be split between ground and the arduino pin?
Q2: If so, do we know what is the internal resistor value? Is there a good way to pick a ground resistor other than try/error?
Q3: Should I consider putting a capacitor to "debounce" the button? and if so, how would I wire it and choose its capacitance?
