i can do normal serial communication from Nodemcu to Uno
but what i trying to get is
it should receive data as soon as its generated by sender
in attached image u can see node mcu sending data lineraly (right serial monitor COM4) but its not accepted by uno (left serial monitor COM 3)
it will be helpful to me if anyone knows hot to achieve as per my reuirement
Thank you !
Note : 1.I tried with different baud rate (ofcourse same on both side on each trial)
2.It work well and in sync also ,when data is sent from uno to node mcu
is it possible to send data from uno to nodemcu wirelessly(without serial communication) as it required connection with computer port
