WeMos D1 Mini problemi in caricamento sketch
Buongiorno chiedo il vostro aiuto, sto tentando di inserire questo codice su una scheda WeMos D1 mini e sensore DHT11 ma mi da errore "Errore durante la compilazione per la scheda WeMos D1 R1" vorrei capire perché visto che con altri sketch si programma grazie
//Temperature sensor
 * This example shows how value can be pushed from Arduino to
 * the Blynk App.
 * WARNING :
 * For this example you'll need SimpleTimer library:
 *   https://github.com/jfturcot/SimpleTimer
 * and Adafruit DHT sensor library:
 *   https://github.com/adafruit/DHT-sensor-library
 * App project setup:
 *   Value Display widget attached to V5
 *   Value Display widget attached to V6
#define BLYNK_PRINT Serial    // Comment this out to disable prints and save space
#include <SPI.h>
#include <ESP8266WiFi.h>
#include <BlynkSimpleEsp8266.h>
#include <SimpleTimer.h>
#include <DHT.h>
// You should get Auth Token in the Blynk App.
// Go to the Project Settings (nut icon).
char auth[] = "       "; //Enter the Auth code which was send by Blink
// Your WiFi credentials.
// Set password to "" for open networks.
char ssid[] = "     ";  //Enter your WIFI Name
char pass[] = "     ";  //Enter your WIFI Password
#define DHTPIN 2          // Digital pin 4
// Uncomment whatever type you're using!
#define DHTTYPE DHT11     // DHT 11
//#define DHTTYPE DHT22   // DHT 22, AM2302, AM2321
//#define DHTTYPE DHT21   // DHT 21, AM2301
DHT dht(DHTPIN, DHTTYPE);
SimpleTimer timer;
// This function sends Arduino's up time every second to Virtual Pin (5).
// In the app, Widget's reading frequency should be set to PUSH. This means
// that you define how often to send data to Blynk App.
void sendSensor()
  float h = dht.readHumidity();
  float t = dht.readTemperature(); // or dht.readTemperature(true) for Fahrenheit
  if (isnan(h) || isnan(t)) {
    Serial.println("Failed to read from DHT sensor!");
    return;
  // You can send any value at any time.
  // Please don't send more that 10 values per second.
  Blynk.virtualWrite(V5, h);  //V5 is for Humidity
  Blynk.virtualWrite(V6, t);  //V6 is for Temperature
  Serial.begin(9600); // See the connection status in Serial Monitor
  Blynk.begin(auth, ssid, pass);
  dht.begin();
  // Setup a function to be called every second
  timer.setInterval(1000L, sendSensor);
  Blynk.run(); // Initiates Blynk
  timer.run(); // Initiates SimpleTimer
errore.txt (70.6 KB)
Ma possibile che non possiate estrarre le poche righe d'errore da tutte le righe della compilazione ? ? ? :o :o :o
\arduino_build_829777\\sketch\\sketch_oct22g.ino.cpp" -o "C:\\Users\\LIDIAN~1\\AppData\\Local\\Temp\\arduino_build_829777\\sketch\\sketch_oct22g.ino.cpp.o"
In file included from C:\Program Files (x86)\Arduino\libraries\Blynk\src/Blynk/BlynkApi.h:17:0,
                 from C:\Program Files (x86)\Arduino\libraries\Blynk\src/BlynkApiArduino.h:14,
                 from C:\Program Files (x86)\Arduino\libraries\Blynk\src/BlynkSimpleEsp8266.h:24,
                 from C:\Users\Lidiano_win7\Documents\Arduino\sketch_oct22g\sketch_oct22g.ino:36:
C:\Program Files (x86)\Arduino\libraries\Blynk\src/Blynk/BlynkTimer.h:36:21: error: redefinition of 'class BlynkTimer'
 #define SimpleTimer BlynkTimer
C:\Users\Lidiano_win7\Documents\Arduino\libraries\SimpleTimer/SimpleTimer.h:10:7: note: in expansion of macro 'SimpleTimer'
 class SimpleTimer {
C:\Program Files (x86)\Arduino\libraries\Blynk\src/Blynk/BlynkTimer.h:36:21: error: previous definition of 'class BlynkTimer'
C:\Program Files (x86)\Arduino\libraries\Blynk\src/Blynk/BlynkTimer.h:41:7: note: in expansion of macro 'SimpleTimer'
 class SimpleTimer {
... cosa che permette, a chi legge il post, di individuare rapidamente quale è il problema ... e poi poter cercare una soluzione ... ::slight_smile:
Guglielmo
Hai ragione, scusatemi
