Could someone please help me out with this, I am unable to get the F() macro compiled on FreeBSD.
I am using avr-gcc and the arduino 1.0 codebase.
The following line
Serial << F("This is a test string");
throws up an error by the compiler which says
flash_streaming.cpp:210:13: error: reinterpret_cast from type 'const char*' to type '__FlashStringHelper*' casts away qualifiers
I apologize for cross posting, but I already asked the same question in an earlier post - but didn't make any headway
The command I am issuing is -
avr-gcc tst.cpp -mmcu=atmega328p -DF_CPU=16000000UL -Os -w -Wl,--gc-sections -ffunction-sections -fdata-sections -DARDUINO=100 -I /home/rr/code/arduino//include/arduino/ -I . -c -o tst.o
It has nothing to do with the << operator, even Serial.print(F("Hello World")) has the same problem.
Serial.print(F("Hello World"));
gives
tst.cpp:19:18: error: reinterpret_cast from type 'const char*' to type '__FlashStringHelper*' casts away qualifiers
I have a medium sized multi-file sketch compiling and functioning using avr-gcc, so there is no problem in general with compiling/linking etc. But this particular issue has me puzzled.
The compiler says
tst.cpp:31:7: error: statement-expressions are not allowed outside functions nor in template-argument lists
Maybe I should try using the flash library and use a variable to hold that string in PROGMEM
Do you really need to store data in FLASH? Doing so isn't "free." You will pay a performance penalty in terms of the time it takes to read from FLASH as well as the complexity in terms of the code necessary to access FLASH.
mkwired:
It's not that bad. In terms of time, the processor can read flash memory quickly. After all, it is getting instructions from it at the rate of a byte every clock cycle. Compare:
The only difference is changing "ld" to "lpm". The LPM instruction takes 3 clock cycles compared to 2 for LD. So, you lose one clock cycle (62.5 nS) per byte copied.
