Hi. Recently I am working on a project which measure and display the temperature and pressure of water tube ( Max Pressure - 3 bar; Max Temperature - 65 Celsius). Firstly a prototype has been built.
To measure the temperature I have used DS18B20 and it shows temp. values precisely.
But I couldn't find a good pressure sensor. Please help me with this issue.
(Is HK1100c pressure sensor good for this?)
Sensors like that only do pressure, using 2 sensors is the best way IMHO.
To calibrate the pressure sensor, connect to Arduino analog input pin and read the ADC value at zero pressure, (let's say it's 100), apply maximum pressure and read the result (5 bar = 800) pressure will be (current result - zero result) / (max result - zero result) * max pressure.
Lets say , after calibration, you apply pressure and read result of 450, pressure would be, (450 - 100) = 350 / (800 - 100) = 0.5 * 5 = 2.5 bar.
