Also cant tell if it has PSRam ..how to tell?
Thanks
It is in the part number N16R8 indicates 16MB flash 8MB PSRAM.
See page 3
This of course assumes they are telling the truth in the description.
Note that the 8MB PSRAM is octal mode so you loose some I/O pins.
still trying to figure out if I have the right board...this is what I picked
but I get exceptions so not sure its right
what exceptions?
copy any output as text and post it using code tags </> plus any code
Perhaps:
ESP32S3 Dev Module
or maybe:
ESP32S3 Dev Module Octal (WROOM2) ?
The later has a config option for enabling PSRAM.
i tried dozens of boards with a simple program that printed a line...
the first one to work was ESP32-S3-USB-OTG
When I tried code dealing with a camera
#include "esp_camera.h"
Serial.println("setup");
// Configure camera settings
camera_config_t config;
config.ledc_channel = LEDC_CHANNEL_0;
config.ledc_timer = LEDC_TIMER_0;
config.pin_d0 = 5;
config.pin_d1 = 18;
config.pin_d2 = 19;
config.pin_d3 = 21;
config.pin_d4 = 36;
config.pin_d5 = 39;
config.pin_d6 = 34;
config.pin_d7 = 35;
config.pin_xclk = 0;
config.pin_pclk = 22;
config.pin_vsync = 25;
config.pin_href = 23;
config.pin_sccb_sda = 26;
config.pin_sccb_scl = 27;
config.pin_reset = -1;
config.pin_pwdn = 32;
config.xclk_freq_hz = 20000000;
config.pixel_format = PIXFORMAT_JPEG;
config.frame_size = FRAMESIZE_SVGA;
config.jpeg_quality = 12;
config.fb_count = 1;
// Initialize the camera
esp_err_t err = esp_camera_init(&config);
if (err != ESP_OK) {
Serial.printf("Camera init failed with error 0x%x", err);
return;
Serial.printf("Camera init OK 0x%x", err);
delay(10000); // Keep loop alive
I got the following error
Rebooting...
ESP-ROM:esp32s3-20210327
Build:Mar 27 2021
rst:0xc (RTC_SW_CPU_RST),boot:0x8 (SPI_FAST_FLASH_BOOT)
Saved PC:0x40379156
SPIWP:0xee
mode:DIO, clock div:1
load:0x3fce3818,len:0x109c
load:0x403c9700,len:0x4
load:0x403c9704,len:0xb50
load:0x403cc700,len:0x2fe4
entry 0x403c98ac
setup
Guru Meditation Error: Core 1 panic'ed (LoadProhibited). Exception was unhandled.
Core 1 register dump:
PC : 0x42018ad9 PS : 0x00060430 A0 : 0x82011e14 A1 : 0x3fcebde0
A2 : 0x3fc984cc A3 : 0x3fcebed8 A4 : 0x3c033ed8 A5 : 0xffff8fff
A6 : 0x00000001 A7 : 0x00000000 A8 : 0x80376fef A9 : 0x3fcebdf0
A10 : 0x00000016 A11 : 0x00000000 A12 : 0x00000008 A13 : 0x00000060
A14 : 0x00ff0000 A15 : 0xff000000 SAR : 0x00000018 EXCCAUSE: 0x0000001c
EXCVADDR: 0x00000000 LBEG : 0x400570e8 LEND : 0x400570f3 LCOUNT : 0x00000000
Backtrace: 0x42018ad6:0x3fcebde0 0x42011e11:0x3fcebe30 0x420119ce:0x3fcebe60 0x42002365:0x3fcebec0 0x420042da:0x3fcebf60 0x4037d2b6:0x3fcebf80
having trouble figuring out the procedure to isolate the problem.
I'll admit the code came from chatGPT so could be all wrong.
try Tools>Board ESP32S3 Dev Board with PSRAM: "OPI PSRAM" enabled?
try a simple program such as blink?
Most likely wrong.
You need to look at the pinout diagram for the board you have and find a matching pinout in the 'camera_pins.h' file which is part of the ESP32 core for the Arduino IDE.
incorrect pin definitions can certainly cause the ESP32S3 to throw exceptions
have a look at Real-Time-Display-of-ESP32-CAM-Camera
the microcontroller ESP32-S3 WROOM looks similar to the photos in your post 1
the code camera-to-tft.ino may assist with the pin definitions
Thanks for the great advice.... i found GitHub - mihvoi/ESP32S3CamTimeLapse: Fix timelapse also for ESP32-S3 boards
which in fact has the ESP32S3 Dev Board (as you said) AND had you set OPI PSRAM enabled (as your said). With the code the guy shared, I am able to use the camera.
I'm so impressed with the support on this forum. Thanks again.
Thanks for the suggestion about the pin definitions...i did not know enough to even think of that... so much to learn. Thanks again.
When selecting an Arduino board, it's essential to match the device’s pinout, GPIO count, and communication requirements with the board's capabilities. Understanding the board’s features, libraries, and documentation can help avoid issues later. Each project may need a different set of resources, so considering these factors upfront is key.
