I used this program to test the various ways to access PSRAM under the Arduino IDE.
The Arduino IDE can ONLY access 4MB of PSRAM, the himem library does not work in the Arduino IDE to toggle bank switching.
#include "esp_system.h" //This inclusion configures the peripherals in the ESP system.
#include "esp32-hal-psram.h"
#include "esp_himem.h"
// #include "esp_spiram.h"
// #include "rom/cache.h"
extern "C"
#include <esp_spiram.h>
const int SerialDataBits = 115200;
struct stuTime
int iSeconds = 0;
int iMinutes = 0;
int iHours = 0;
// Serial.begin(115200);
// Serial.println("========================================");
// Serial.printf("PSRAM total size : %u \n", esp_spiram_get_size());
// Serial.println("----------------------------------------");
// Serial.printf("PSRAM first 4MB size : %u \n", ESP.getPsramSize());
// Serial.printf("PSRAM first 4MB free : %u \n", ESP.getMaxAllocPsram());
// Serial.printf("PSRAM HI-MEM size : %u \n", esp_himem_get_phys_size());
// Serial.printf("PSRAM HI-MEM free : %u \n", esp_himem_get_free_size());
// Serial.printf("Internal RAM size : %u \n", ESP.getHeapSize());
// Serial.printf("Internal RAM free : %u \n", ESP.getFreeHeap());
// Serial.println("Testing the free memory of PSRAM HI-MEM ...");
// test_region(esp_himem_get_free_size(), 0xaaaa);
// Serial.println("Done!");
esp_spiram_init();
vTaskDelay(1);
// esp_himem_handle_t mh; //Handle for the address space we're using
// esp_himem_rangehandle_t rh; //Handle for the actual RAM.
// esp_himem_alloc( 1024, &mh);
// Serial.begin( SerialDataBits );
// psramInit();
// vTaskDelay(3);
// esp_spiram_init();
// vTaskDelay(1);
// log_i("Total heap: %u", ESP.getHeapSize());
// log_i("Free heap: %u", ESP.getFreeHeap());
// log_i("Total PSRAM: %u", ESP.getPsramSize());
// log_i("Free PSRAM: %d", ESP.getFreePsram());
// log_i("spiram size %u", esp_spiram_get_size());
// log_i("himem free %u", esp_himem_get_free_size());
// log_i("himem phys %u", esp_himem_get_phys_size());
// log_i("himem reserved %u", esp_himem_reserved_area_size());
// int *ptr, *ptr1;
// int n, n1, i, sum = 0;
// float *ptrFloat;
// // Get the number of elements for the array
// n = 10;
// n1 = 20;
// log_i("Number of elements ptr: %d", n);
// log_i("Number of elements ptr1: %d", n1);
// log_i("Number of elements ptr1: %d\n", n1);
// // Dynamically allocate memory using malloc()
// // ptr = (int*)ps_malloc(n * sizeof(int)); //works
// ptr = (int*)ps_calloc( n, sizeof(int) ); // works
// ptr1 = (int*)ps_calloc( n1, sizeof(int) ); // works
// // Check if the memory has been successfully
// // allocated in ps_ram
// ptrFloat = (float*)ps_calloc( n, sizeof(float) ); // works
// if (ptr == NULL) {
// log_i(" ptr memory not allocated.\n");
// exit(0);
// if (ptr1 == NULL)
// log_i("ptr1 memory not allocated.\n");
// exit(0);
// else
// // Memory has been successfully allocated
// // log_i("ps_ram memory successfully allocated using ps_calloc.");
// // put elements into ps_ram array
// for (i = 0; i < n; ++i)
// ptr[i] = i + 1;
// for (i = 0; i < n1; ++i)
// ptr1[i] = i + 2;
// ptrFloat[i] = (float)i + 1.06555f;
// // Print the elements of the array
// log_i("The elements of the ptr array are: ");
// for (i = 0; i < n; ++i) {
// log_i("%d, ", ptr[i]);
// log_i("The elements of the ptr1 array are: ");
// for (i = 0; i < n1; ++i) {
// log_i("%d, ", ptr1[i]);
// log_i("The elements of the ptrFloat array are: ");
// log_i("%f, ", ptrFloat[i]);
// // put a structure into psram. Works.
// struct stuTime *ptrStuTime;
// log_i("size of structure: %d", sizeof(struct stuTime) );
// ptrStuTime = (struct stuTime *)ps_malloc(sizeof(struct stuTime));
// log_i("Free PSRAM after structure: %d", ESP.getFreePsram());
// ptrStuTime->iSeconds = 10;
// ptrStuTime->iMinutes = 60;
// ptrStuTime->iHours = 100;
// log_i("Seconds: %d Minutes: %d Hours: %d", ptrStuTime->iSeconds, ptrStuTime->iMinutes, ptrStuTime->iHours );
// free(ptr);
// free(ptr1);
// free(ptrStuTime);
// // works
// log_i("Free PSRAM before String: %d", ESP.getFreePsram());
// char *str;
// char OneChar = 'a';
// char TwoChar = 'b';
// char ThreeChar = 'c';
// str = (char *)ps_calloc(300, sizeof(char) );
// log_i("Free PSRAM after String: %d", ESP.getFreePsram());
// // concantenate one char variable to end of char array to the str
// strncat( str, &OneChar, 1 ); //works
// strncat( str, &TwoChar, 1 );
// strncat( str, &ThreeChar, 1 );
// //*(str+0) = 'G'; // works
// //*(str+1) = 'f';
// //*(str+2) = 'G';
// //*(str+3) = '\0';
// log_i("%s", str );
// free(str);
//size_t memfree=esp_himem_get_free_size();
//log_i( "himemFree %d", memfree );
// int memcnt=esp_himem_get_phys_size();
// int memfree=esp_himem_get_free_size();
// log_i( "SpiRamPhysSize %d", memcnt );
// log_i( "SpiRamFree %d", memfree );
// esp_himem_get_phys_size(void)
// esp_err_t intError = esp_himem_alloc( 4095, &mh);
// log_i( "%s", esp_err_to_name( intError) );
// log_i( "Handle %d", mh );
} // setup()
void loop() {}
