What is Top of TIP120 connected to ? Emitter, or Collector?
I'm failing to see this info in the datasheet.
Secondary question: are all transistors with metal tops connected as well?
Any info appreciated, thanks
The "top" is the heat sink tab and on most devices of this type it is connected to the center lead, or in your case, the collector.
Due_unto:
Thank you. I had scrapped a broken mixer of mine, and inside I found a cool heatsink designed for 2 transistors. So I thought I would put it to use and control two separate devices from the two transistors I hooked to the heatsink... NOT! It took me an hour to figure out it had nothing to do with my code :X
Thanks again!
Some of the datasheets are strangely silent about that, but I found one at http://www.onsemi.com/pub_link/Collateral/TIP120-D.PDF that makes it clear that it is the collector:
Some TO-220 case components do have an insulated tab, but they usually state the fact.
SCR and TRIACs can come in insulated and live tabs.
Tom.. ![]()
In transistor manufacturing process after die is sliced from Wafer, the die is attached to a lead frame. All transistors will have large collector area. Hence large area, that is collector is die-attached to the lead frame using Lead preform.
KevinGulling:
Thank you. I had scrapped a broken mixer of mine, and inside I found a cool heatsink designed for 2 transistors. So I thought I would put it to use and control two separate devices from the two transistors I hooked to the heatsink... NOT! It took me an hour to figure out it had nothing to do with my code :XThanks again!
If you want to mount 2 transistors on the same heatsink, you can get mounting kits to prevent the collecters from being in electrical contact with the heatsink (and each other).
The figure in the upper right of the first page of the datasheet shows that the collector (#4) is connected to the tab.
Thanks all, great answers! [quote author=Nick Gammon link=msg=3054713 date=1482549789]
[/quote]
Nice I see in this one they actually labeled it with a 4. The other Chinese sheet I had only labeled 1-3.
Thanks everyone for the great answers, I am smarter today than I was yesterday
Karma all around!
KevinGulling:
I'm failing to see this info in the datasheet.Secondary question: are all transistors with metal tops connected as well?
The tab is the centre pin, at least in my experience. As always if in doubt a multimeter
can be used to check out the continuity.
